Question about two Samsung DLP models...
Old Mar 28, 2005 | 03:56 PM
JarodL's Avatar
I am looking at the two following TV's.
5063
I know the first one has the "newer" chip. I looked at both side by side and really couldn't tell a difference. Its 700 more, I don't mind the money, but not if its not really doing anything. Also, the 5067 (not shown) is the same as the 5063 except for the built in HD tuner, what about the 5065?
Old Mar 28, 2005 | 04:01 PM
doopstr's Avatar
Check both for the "rainbow effect". The "new chip" is supposed to mostly fix that.
Rainbow means that if you move your head while looking at the screen you will see a rainbow image on the screen. Annoying. You may be able to find a demo video via. of what rainbow looks like.
Old Mar 28, 2005 | 04:12 PM
JarodL's Avatar
Thanks, they are both third generation, so that is pretty much eliminated.
Old Mar 28, 2005 | 04:27 PM
mc_yanzo's Avatar
Masshole
Is there a 5065? I know there is a 5085 (the "Captain Kirk" TV). That one is the 4th generation Samsung. I think has it?
I'm looking at the Samsungs, I'm leaning towards the 4674 when the new ones come out later this year.
Old Mar 28, 2005 | 04:55 PM
JarodL's Avatar
Thanks, when are they releasing the new versions? I thought it was sometime in April?
Old Mar 29, 2005 | 07:58 AM
JarodL's Avatar
anyone?
Old Mar 29, 2005 | 09:27 AM
mc_yanzo's Avatar
Masshole
Maybe in May?
Check www.avsforum.com
Old Mar 29, 2005 | 10:18 AM
Lung Fu Mo Shi's Avatar
Registered AssHat
Here we go:
The HLP 5063 uses the HD3 DLP chip at 0.55". This provides seamless 720p resolution with a 1500:1 contrast ratio.
The other two you mentioned use the HD2+ DLP chip at 0.8". This also provides 720p resolution, but at a higher 2500:1 contrast. The downside is that there is a bit of screen door effect with this particular chip.
The HL-R6477 also has a slower 6 segment color wheel, while the HLPs have a faster 7 segment wheel. I would imagine the rainbow effect is more readily seen with the HLR.
The HLP5063 is also 14" deep versus at least 20" deep for the other models.
The HLP5085 also comes with it's own stand (typically about $300-$400 extra).
Old Mar 29, 2005 | 11:10 AM
JarodL's Avatar
Thanks, what about the HLN5065?
Old Mar 29, 2005 | 11:39 AM
mc_yanzo's Avatar
Masshole
I'm pretty sure that HLP > HLN.
Old Mar 29, 2005 | 12:06 PM
JarodL's Avatar
Thanks, so what is the difference between HD Capable with optional set top box and HDMI Input. That is the difference between the 63 and 67.
Old Mar 29, 2005 | 12:17 PM
mc_yanzo's Avatar
Masshole
I believe that it means that it is HD Ready but will not work with standard antennas. So, in order to get HD you need to get a cable box that has HD compatibility.
HDMI is an input similar to DVI. Very high quality, used for HD cable boxes and DVD players. It provides better picture/sound than say composite or s-video.
Old Mar 29, 2005 | 02:36 PM
JarodL's Avatar
I was under the impression that when you get HD service you rent a box from your service provider, if you buy one, it may work or may not.
Old Mar 29, 2005 | 02:55 PM
Thorin78's Avatar
Previous Owner
Most cable boxes do not come with HDMI, I just bought the 5085 a few weeks ago. Looks great btw.
read this place to get familiar with the chips and such
http://www.digiupdate.com/105_DLP_RPTV.html
Old Mar 29, 2005 | 03:02 PM
esCarbonie's Avatar
TimeWarner's new Scientific Atlantic 8300HD does. just picked it up last week.
Old Mar 29, 2005 | 03:26 PM
JarodL's Avatar
Thanks, the 63 has the HDMI input, just not the tuner. Anyone know when these new chips or models are coming out? Some say May, some say later this year??
Old Mar 29, 2005 | 03:35 PM
Registered AssHat
Who knows. The HLP series was delayed by a few months due to the delay in the DLP chips from TI (only manufacturer currently).
But figure this...they are going to make damn sure they get new TVs out for the Thanksgiving/X-mas buying season.
Old Mar 29, 2005 | 03:38 PM
Registered AssHat
Correct. HLP is the newer generation. The HD2 HLNs and HD3 HLPs offer similar picture quality, but the HLP uses a cheaper DLP chip (0.55" vs. 0.8"), no screen door effect, and a higher speed 7-seg. color wheel.
They will probably similar priced, but the HLP "value" series will look better.
That said, there are HLPs powered by the higher end HD2+ chip. These are still 0.8", but offer superior contrast ratios. They might be a bit brighter as well. They'll be about $500-700 more than the HD3 powered TVs. This is the disparity between the HLP5063 and HLP5085 for example.
Old Mar 29, 2005 | 03:41 PM
Registered AssHat
And if it doesn't, but has DVI, you can buy a conversion cable (DVI to HDMI).
HDMI is the exact same as DVI except it has a few more pins for audio, and the internal transmission paths require copy protection (no unprotected digital signals allowed). That said, if you plan to use a home theatre, you'll have an optical or coax audio out and can jsut use the video segment of the HDMI (i.e. DVI with a different connector).
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
