Need NEXTEL HELP?? COME ON IN...
Alright, For i95 models and below all you need is a data cable, the data cable needs to use a serial connection if you are using Windows XP. If you have you have anything below XP you can use either connection, serial or USB. but again if you have XP you can only use a serial connection, and you also need the software. thats it,
for i730 u need to PayPal this guy $5 inorder to get a user name and password. This is the 1st time they are asking for a donation. All other netxel phones I95 and below use IJAL7, and/or a different version of WebJal.
Now, for the i730, you need to use the program that requires a $5 donation. after you donate $5, you will have unlimited lifetime access to the software, and once you get all that done; you need to have a data cable. I recomend geting a USB Data cable for the I95. the one for the i730 is too expensive. Once you get the i95 data cable you will need to break off a small tab with tweezers for it to work propperly on your i730.
AFTER alllll that is done. You need to download .wav files and .midi files for ringtones, .wav are actuall songs(with words) , while .midi are beats (no words) .wavfiles shouldnot be longer than 30seconds. .midi files could be 1 minute long.
For wallpaper, you need .gif files, the size should be 126X130 Pixels. (not too sure bout the size)
For Java Apps (games) you can just get them all from ideninsider.com
I HOPE THIS HELPS, Post here for further explination.
