Macbook pro + wireless HP printer = stumped!
The sizzle in the Steak
Long story short:
Less than 6 month old Macbook pro.
Less than 1 year old HP wireless all-in-on printer.
Worked flawlessly for 6 months.
Now all of the sudden it does not print. Nothing was modified or recently installed to cause a problem. Printer works fine from other PC's within the network.
Says something to the extent of "not detected or not on network."
...but I can print a test page directly from the macbook, but cannot print from any other app/program. Go figure
I added an additional new printer manually inputting the printer's IP address to see if that would fix the problem. Nope. Same result.
I will add the the printer was installed on the macbook pro during the original out of the box setup process when it asked if there was a wireless printer.
Any thoughts - advice?
Sometimes you ahve to install via usb on a computer then setup the wireless setup on the computer.
If not try resintalling on the mac while wireless. Ill check back here to see whats going on in a few days
What's strange is that it worked flawlessly with the wifi printer setup via the OG macbook pro setup process.
Now all of the sudden the printer & mac don't communicate.
The Third Ball
Received 4,850 Likes
Have you tried deleting the printer entirely and trying the set up again.
I think apple and HP are notorious for this little hick up. I had it happen on an older computer a long time ago. I can't remember what I had to do to fix it, but it finally started working again.
Usually, anytime something like this occurs I just delete the printer and re-add it.
Received 2,329 Likes
My father-in-law had the exact same issue recently
Macbook, HP printer, wifi.
Ok then I will delete all the printers, and try again.
I seem to remember receiving a HP printer software update within the last week via Software Update.
Sanest Florida Man
Or most likely if you ha d power outage and your router restarted it gave the wireless printer a different ip address so now your Mac can't find it. Fix this by either giving the printer a static ip outside of the routers dhcp range or a dhcp reservation.
I see this all the time on supportspace with wsklar and stogie
The Third Ball
I "reset" (deleted) the printer(s) and added a new one via bonjour.
Seems to be working fine now.
Go figure.
I thought this crap only happened on PC's.
Sanest Florida Man
you're right! helps if I fully read the thread.
Sanest Florida Man
Either way it's a good thing to do. It's just a matter of time before your router restarts for a variety of reasons and gives your printer a different ip address.
Yep, I always set an IP reservation for printers if the router supports it. Otherwise, I'll go the static route in the printer setup/web interface.
emailnatec
29
09-28-2018 04:27 PM
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
AcuraKidd
09-25-2015 11:18 PM
4drviper
09-23-2015 07:42 PM
