internet router question
Old Feb 7, 2007 | 10:13 AM
  #41
studville's Avatar
Doesn't Rice His Car
I was in the exact same situation last week. I needed 265 computers connected, but my router would only allow 255.
Old Feb 7, 2007 | 11:53 AM
  #42
bz268's Avatar
Because Of You
Originally Posted by fla-tls
^^Agreed. (We're talking layer 3 here guys - the outer router has no idea what MAC addresses are behind the inner router - because of the inner router's use of NAT)
I've never tried this b4.
So... Do I need a twisted-pair cable to plug the second router to the switch and the "DSL Modem" port? or just plug the second router to the switch and the ethernet port?
Old Feb 7, 2007 | 11:59 AM
  #43
bz268's Avatar
Because Of You
Originally Posted by Kikaida
The answer to your question is yes, it will work. So long as the new cheapy router uses NAT as most do.
The main thing you will have to check is that the IP subnets are different. Most routers are set as default with the IP subnet 192.168.1.0, 255.255.255.0, with a gateway of 192.168.1.1. You must change this on one of the routers if both are set like this.
If both routers are using the same subnet address range, you will not be able to "route" out, so make sure they are different.
If your cheapy router is using NAT, only 1 MAC address will get passed along to your main router (the MAC address of the cheapy router).
Another option is to just buy more licenses. It probably costs more than the cheapy router, but less to worry about...
What kind of router is your main router? Sonicwall?
It is a eSoft. They charge everything per user. It add$ up when adding this and adding that. So, I am trying to avoid that.
So, Do I plug the second router to the switch? Don't I need a twisted-pair cable or something?
Old Feb 7, 2007 | 12:11 PM
  #44
Whiskers's Avatar
Go Giants
You shouldn't need a crossover cable....Just connect one port on the old router to the WAN port of the new one. Assign is one of the old routers IP address and then use NAT on the new one.
Old Feb 7, 2007 | 12:18 PM
  #45
bz268's Avatar
Because Of You
Thanks. will do that.
Old Feb 7, 2007 | 07:24 PM
  #46
Kikaida's Avatar
Here is a little diagram of the devices and what ports you should be plugged into. I also put in IP Subnet info you could use as an example.
INTERNET
| Phone (or Cable)
DSL (or Cable) Modem
| PC
| WAN
Main Router
| LAN
| 192.168.1.x
| WAN
Cheapy Router
| LAN
| 192.168.2.x
Switch (or Hub)
User Users Users
Like Whiskers said, you should be able to use all normal straight-thru patch cables.
By the way, you don't have any publicly accessed servers (Web, E-mail, etc) in your network do you? By that I mean servers that are in your office that people access from the internet.
Also, be aware of any devices in your network that uses Static IP's...
Old Feb 7, 2007 | 08:22 PM
  #47
bz268's Avatar
Because Of You
Thanks for the diagram. But can I plug the cheap router to the switch instead:
INTERNET
| Phone (or Cable)
| PC
| WAN
Main Router
| LAN
| 192.168.1.x
Switch (or Hub)
| Users Users
| WAN
Cheapy Router
| LAN
| 192.168.2.x
WiFi Connection for the laptops
Old Feb 8, 2007 | 04:17 AM
  #48
Kikaida's Avatar
Sure! Shouldn't be a problem. Basically all your wireless users would be taking up only 1 IP on your Main Router.
Another option is to do the opposite. Place your WAP (Wireless Access Point) between your Main Router and Cheapy Router. Unless of course the WAP is built in to your Cheapy Router.
The advantage of putting the WAP between the routers is that it would be in a sort of "DMZ" so wireless computers would not be able to access computers on your wired LAN. This would be advantageous if for example an untrusted computer (like a client, consultant, etc.) wants access to the internet from their laptop. You would not have to worry if they have viruses / malware or whatever that could spread to your office computers. It would also help if a hacker broke into your wireless connection for the same reason.
All your wired computers would take up only 1 IP. Of course your 10 license limit could become an issue again if too many wireless users connect to your WAP...
Old Feb 8, 2007 | 02:58 PM
  #49
bz268's Avatar
Because Of You
Thanks.
I will give it a try when I borrow a cheap wireless router from my friend.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
MikeJM310
Sep 24, 2015 07:24 PM
