Excel table formula help
Old Jan 11, 2011 | 02:47 AM
mastertl's Avatar
I don't have a Ferrari in
I'm trying to get the Cumulative Column to run a continuous total and I'm able to get it to work assuming there are no blank rows. As soon as there is a blank row, the formula goes to shits. I'd like both the Total and Cumulative column to return null cells if there are no numbers, but if there is a completely empty row, is there a way to make the Cumulative column search vertically in the column to continue adding?
My current formulas (I know they are not elegant, I suck...)
For Total: =IF(SUM(C3:E3)>0,SUM(C3:E3),"") [This would be for Cell F3]
For Cumulative: =IF(F3="","",IF(F3>0,(F3+G2),)) [This would be for Cell G3]
If I skip a line, I get the #VALUE! error. Any ideas?
Old Jan 11, 2011 | 05:32 AM
rza49311's Avatar
sounds like you need to nest that inside an IF with an IsError test.
Old Jan 11, 2011 | 07:32 AM
te3point5's Avatar
Why don't you do:
in Cell G2: =sum($F$2:F2)
Then drag down
Old Jan 11, 2011 | 07:38 AM
svtmike's Avatar
The "" are what is causing you trouble.
Get rid of them and replace them with these simple formulas:
Total: =SUM(C2:E2) and fill down
Cumulative: =SUM(F$2:F2) and fill down
Go to Excel Options->Advanced, under the "Display Options for this Worksheet", uncheck "Show a zero in cells that have zero value".
Old Jan 11, 2011 | 11:08 AM
Bearcat94's Avatar
AZ Community Team
What they said.
Think of this way: If you have a blank row, the value for that day is "0". Your cumulative amount, including that day, is the previous cumulative amount + 0.
IOW - just let the cumulative amount tally on those blank rows.
Old Jan 11, 2011 | 10:14 PM
1Louder's Avatar
Old Man Yelling at Clouds
What they said too.
I think the #Value is coming from not setting a value if F3<=0:
Because you are triggering that condition, which is leaving some null value in G6 and then you're trying to add it in G7. If you did this:
IF(F3="","",IF(F3>0,(F3+G2),0))
It would work, but you'd have a zero in the cell.
Old Jan 11, 2011 | 10:21 PM
svtmike's Avatar
Originally Posted by 1Louder
What they said too.
What's happening is the "" used as the result of the IF() functions is setting up a string value in some of the cells, which the SUM() function doesn't handle -- it throws a #VALUE error instead.
I just went through an extensive redesign of a large spreadsheet to eliminate this very problem.
Old Jan 12, 2011 | 02:31 AM
mastertl's Avatar
The SUM formula worked perfectly. I think I was thinking too hard about how to make the table work. Its much simpler than what I originally had in mind.
I ended up using this in G2 and dragged down.
=IF(F2="","",SUM($F$2:F2))
The problem with unchecking the show zeroes option is that I'm not sure if it would show up when I send the spreadsheet out.
Y'all are some Excel pros
Old Jan 12, 2011 | 07:39 AM
svtmike's Avatar
That setting will stay with the spreadsheet, so it will work when you send it out.
Old Jan 12, 2011 | 12:52 PM
1Louder's Avatar
Another alternative to "show zeros" - If you ever want to get around that (or having to put strings in your cells), but don't want zeros showing up, what you can do is have your IF statements populate cells with a zero (or make it some bizarre number that would never happen, like -9999). And then set conditional formatting on the cell to turn the font white when the cell equals that value. It's not too much work and it's a good way to make unwanted place-holder data "disappear" on print outs.
knight rider
Mar 4, 2016 08:59 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Nov 11, 2015 12:19 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
