Excel Help!
Old Nov 30, 2011 | 06:32 AM
hornyleprechaun's Avatar
Bent = #1
Excel Help!
A1 = VLOOKUP for Value of "1"
B1 = VLOOKUP for Value of "2"
C1 = VLOOKUP for Value of "3"
Col E --- Col F
1113 --- 1
1113 --- 2
1113 --- 3
If I do VLOOKUP(1113,E1:F3,2,FALSE) it returns a Value of "1"
How do I write the VLOOKUPs so I can lookup either of the 3 values for 1113?
Old Nov 30, 2011 | 06:48 AM
rza49311's Avatar
This might help.
http://www.get-digital-help.com/2009...okup-in-excel/
Old Nov 30, 2011 | 07:10 AM
Whiskers's Avatar
Go Giants
4?
Old Nov 30, 2011 | 09:50 AM
The Dougler's Avatar
Unofficial Goat
Possibly using the match function.
Old Nov 30, 2011 | 12:00 PM
oo7spy's Avatar
The syntax of the function is (value, range, return column, exact match)
So you are asking for it to look for 1113, in the cells E1:F3, return the second column, and look for an exact match of 1113. Since it found 1113 in E1 and was an exact match, it returned the value of F1 which corresponds to the second column.
Why are all the E values 1113? That is what is stopping you.
You will likely have to use a different function if you cannot change "1113" for each cell.
Old Nov 30, 2011 | 01:25 PM
svtmike's Avatar
If you're trying to VLOOKUP the values in columns A,B,C based on the value in Column D and a column number in column E, you have to get the columns in a different order; the lookup column has to be the first in the range. Either re-arrange the columns, or set formulas in G=A, H=B, I=C, and then the third argument of your VLOOKUP should be F+2.
Old Nov 30, 2011 | 01:34 PM
oo7spy's Avatar
This is what I see while reading your suggestion.
Old Nov 30, 2011 | 01:39 PM
svtmike's Avatar
That's kind of what I see when trying to discern what he's trying to do.
Old Nov 30, 2011 | 01:41 PM
oo7spy's Avatar
Yes, he has three y values for one x value. The vertical line test fails, he doesn't have a true function, and inherently, the computer is doing the best it can.
He's doomed.
Old Dec 1, 2011 | 07:35 PM
65 Fury Convert's Avatar
I use the vlookup function all the time. From what I know it won't do what you're trying it to get it to do. A vlookup matches data in a cell range and copies it to data on another spreadsheet.
Old Dec 1, 2011 | 07:40 PM
Are you just trying to search for the cells that contain 1113? If so you could do a control "f", type in 1113 and it will find the 1113's for you
Dec 7, 2020 05:39 PM
Aug 15, 2019 12:58 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
