Backing up entire computer
Old Nov 19, 2010 | 07:47 PM
r3mix3r's Avatar
So my friend calls me up and tells me the logo he was making for me was lost, because his entire hard drive crashed
I've heard many stories about this before, and then thought to myself my computer is really old, makes weird noises, and I have half my life on here. I've never backed up a single thing, or even thought about it until now.
Everything I read when I googled it, says don't back up tomorrow, back up now!
What's the best method to back up an entire hard drive? I want my entire computer backed up...My HD is 80GB, so not too large. What's the best affordable external HD? Also what's the best/easiest program to use? Does anyone know how long it takes to back up an entire computer, and how easy/difficult it is?
Thanks guys
Old Nov 19, 2010 | 07:55 PM
#1 STUNNA's Avatar
Sanest Florida Man
Id just buy an external drive and read the box and get the one that comes with backup software. Most external drives do, it's pretty much a standard feature now a days. Then install and run that and you should be good
The little western digital passport drives come with backup software and start at about $50
Old Nov 19, 2010 | 07:57 PM
csmeance's Avatar
with black friday, you can get a 1TB external hard-drive for less than 100 dollars! Thats more than 10x the size of your current HD! Use it for backups and other things as you see fit!
Old Nov 19, 2010 | 07:58 PM
Whiskers's Avatar
Go Giants
floppy.....
Old Nov 19, 2010 | 08:02 PM
hornyleprechaun's Avatar
Bent = #1
Originally Posted by Whiskers
floppy.....
Winrar your files into 3.5mb each and copy them to floppy drives
Old Nov 19, 2010 | 08:10 PM
jupitersolo's Avatar
nnInn
I use two externals ; one just a drive another is from clickfree.
nnInn
floppy.....
Five inch not 3.5
Old Nov 19, 2010 | 08:12 PM
r3mix3r's Avatar
What exactly causes a hd to crash? Also are the external HD's less probable to crash? I could only imagine backing all my stuff, only to have the back up crash!
Old Nov 19, 2010 | 08:17 PM
Whiskers's Avatar
Go Giants
platters.
Old Nov 19, 2010 | 08:20 PM
fsttyms1's Avatar
Just pick up either a new Internal or portable HD. They are very cheap now days. Most come with back up software or you can Copy and Paste.
Old Nov 19, 2010 | 08:22 PM
stogie1020's Avatar
Needs more Lemon Pledge
r0dxx,
Have two backups and either do them both at the same time or rotate them every other time.
Drives crash mainly due to heat these days. Circuitry on the controller cards gets cooked or the mechanics in the read write swing arm return mechanism get funked up. Older drives can have the bearings or lube in the bearings go south, but this is more commonly found on drives that sit idle or off for long periods.
Also, file system corruption from the OS can cause you to lose data and people often think of this as a "crash" too, when in fact it's only a hard core communication problem between the drive and the computer.
I use Cobain Backup 9, but really any one will be fine. Acronis is another good one. Ghost is a technical program that also does a good job.
Also, although I am not a fan (control freak) take a look at online services too, like Carbonite.com.
Old Nov 19, 2010 | 08:24 PM
Anachostic's Avatar
Hard drives are mechanical. Anything mechanical will fail at some point. Hard drives aren't maintainable like car engines, so the longer you have your data not backed up, the longer you are tempting fate.
Storage is SO cheap now there is absolutely no reason not to have at least one backup on a separate drive.
Old Nov 19, 2010 | 08:26 PM
Anachostic's Avatar
I thought that software was dead. Or is it just an older version of Ghost?
fsttyms1's Avatar
Drop Box is another decent online service. I have their 50gb service for my photos just as a added backup. I had a power surge kill my computer and the backup HD even with a nice powersurge protector once and lost just about everything.
Old Nov 19, 2010 | 08:28 PM
stogie1020's Avatar
Shoot. I am outdated! V10 available...
http://download.cnet.com/Cobian-Back...-10071828.html
CNET Editors:
Cobian Backup offers multiple help venues, including an index, a tutorial, and support forums. However, even the most novice users will be able to jump in with very little, if no, guidance. We highly recommend this program for all users.
Old Nov 19, 2010 | 11:10 PM
AZuser's Avatar
_
floppy.....
Probably better to just print everything out. Then you'll have a hard copy of everything on the HDD
Old Nov 20, 2010 | 01:05 AM
#1 STUNNA's Avatar
Sanest Florida Man
r0dxx,
So do you just take a drive with you so you have an off site backup?
Old Nov 20, 2010 | 01:07 AM
#1 STUNNA's Avatar
Sanest Florida Man
Windows Live SkyDrive gives you 25Gb of online storage for free. that usually enough for pics and music but not your porn collection.
http://skydrive.live.com
Old Nov 20, 2010 | 07:25 AM
SouthernBoy's Avatar
Registered Member
I use three backup devices for my PC. One is a hard drive which powers off of a USB port and backsup the entire system. The other two are flash drives (aka memory sticks) and I use them for my personal files and directorys (hate the term "folder"). I have my machine configured so that this is quite simple which makes me more prone to doing backups more frequently.
If the system and application software craps out due to a drive crash, who cares. It's the personal files that are important.
Old Nov 20, 2010 | 08:18 AM
Majofo's Avatar
Originally Posted by csmeance
with black friday, you can get a 2TB external hard-drive for less than 70 dollars!
Fixxor'd
Old Nov 20, 2010 | 10:28 AM
stogie1020's Avatar
Were I worried about the power surge issue or a fire, yes, but I have little or no critical data on the home computer and no real concern about a power spike, so it sits in an internal removable bay and I can swap out a second internal drive if I like.
Old Nov 21, 2010 | 09:24 AM
doopstr's Avatar
I was going to use that to pass ISOs to friends until I found out that there is a file size limit of 50MB
Old Nov 21, 2010 | 11:59 AM
#1 STUNNA's Avatar
Sanest Florida Man
Oh yeah I forgot about that. I use depositfiles.com for stuff like that.
Old Nov 21, 2010 | 08:41 PM
mcflyguy24's Avatar
Just curious, but are solid state drives more reliable or are there other issues with them?
Old Nov 21, 2010 | 08:44 PM
stogie1020's Avatar
Well, there are no moving parts so from that angle, yes.
Only time will tell what their true life expectancy is, but any SINGLE location for data is vulnerable and should still be backed up.
Old Nov 21, 2010 | 08:48 PM
#1 STUNNA's Avatar
Sanest Florida Man
Well there's no moving parts so they should be much more reliable. I guess we don't really know yet cause they're still new compared to hard drives. But I haven't heard of any sort of failures so far. I guess the drive controller can still go bad like what happens in normal drives. They also have a limited number of writes before the flash memory goes bad but that number is getting higher and higher and more out of reach every year. The tech is still in it's infancy and things are getting cheaper and harder, better, faster, stronger all the time.
Old Nov 21, 2010 | 08:49 PM
#1 STUNNA's Avatar
Sanest Florida Man
Stogie read my mind.
Old Nov 21, 2010 | 09:47 PM
stogie1020's Avatar
Also, stop fantasizing about Maria Shriver. She looks like a man.
Old Nov 21, 2010 | 11:25 PM
#1 STUNNA's Avatar
Sanest Florida Man
Old Nov 22, 2010 | 07:47 AM
doopstr's Avatar
IMO, the performance gained from an SSD is worth the price of admission. I wouldn't use them for a backup device yet because a regular hard drive is plenty fast for that. Once a 1TB SSD can be had for a couple hundred I may change my mind on that.
Old Nov 22, 2010 | 04:29 PM
Scottman111's Avatar
1919
I have two backups of any and all important data, one stored off-site in case of a disaster.
I also use data dump/dcfldd to make an exact mirror image of my drive, so if it ever crashed I wouldn't have to reinstall all of my programs, drivers, files, etc...just stick the new drive in the PC and go. It's really easy for those that have never done it...I could post a DIY if anyone is interested.
And it still amazes me how many people still don't backup their data, and I'll never forget some of the looks I've got when I tell people they've lost everything.
Old Nov 22, 2010 | 04:33 PM
stogie1020's Avatar
You know where dcfldd came from, right?
Old Nov 22, 2010 | 04:37 PM
#1 STUNNA's Avatar
Sanest Florida Man
Some Nick dude at the Dept of Defense Computer Forensics lab
Old Nov 22, 2010 | 05:27 PM
Anachostic's Avatar
If my memory serves me right (heh), SSDs suffer from the same problems as all flash memory, namely, they wear out. The circuits that hold the memory bits can only be flipped so many times before they lose their ability to hold a charge. Supposedly, you will see this as slowly shrinking available space. In theory, though that sounds like SSDs are good for static information, but not highly-volatile data, which is counter-intuitive to what people want SSDs for.
Old Nov 22, 2010 | 05:48 PM
#1 STUNNA's Avatar
Sanest Florida Man
Yes but they last longer with each generation and I think most people are replacing them before they wear out. I think that's tied to the NAND flash that they use. I know they're exploring using other types of flash and I'm sure something new will come out in the future that doesn't have that drawback.
Old Nov 22, 2010 | 05:54 PM
#1 STUNNA's Avatar
Sanest Florida Man
For example the lifespan of the next gen Intel SSDs have doubled or quadrupled compared to the current version
http://www.anandtech.com/show/3965/i...specs-revealed
Old Nov 24, 2010 | 11:59 AM
1919
Sure do. I <3 this class I'm in
Old Nov 24, 2010 | 02:02 PM
doopstr's Avatar
Intel states MTBF of 2,000,000 hours. (over 200 years)
http://www.intel.com/design/flash/na...reme/index.htm
When a sector on an SSD is worn out it becomes read only, which makes data recovery easy. When a sector on a HD goes bad you have
SSDs evenly write to all sectors to extend the life of the drive. There is also no need to defrag an SSD.
rockyboy
Aug 4, 2024 10:35 AM
Ol'Dave
Sep 5, 2020 02:56 PM
Feb 25, 2020 09:57 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
PortlandRL
Sep 14, 2015 12:01 PM
