Anyone know programming in java? Need help ASAP
Old Apr 24, 2012 | 01:23 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
Exclamation Anyone know programming in java? Need help ASAP
Hi guys, I was wondering if anyone knows how to program in java. I posted it in ramblings figuring there must be someone in this field.
Specifically, I need help using Dijkstra's algorithm.
The task is to determine the shortest path from a given node to each other node. I only need to track the cost, and NOT route of each path. The graph is represented by an adjacent matrix with all nodes connected.
Old Apr 24, 2012 | 01:31 PM
doopstr's Avatar
http://renaud.waldura.com/doc/java/dijkstra/
BTW, if that's what you want then you suck at interwebz and need to pick a new field
Old Apr 24, 2012 | 01:36 PM
TeknoKing's Avatar
Old Apr 24, 2012 | 02:04 PM
honda_nut's Avatar
well i knew that lol. i can google on my own.
i have written some code but don't know if it seems right. can you take a look.
public class Final_Start {
final int NODES = 6;
final int INFINITY = 65535;
final int X = INFINITY;
int[][] weights = new int[][] {
// A B C D E F
{ X, 5, 15, 3, 9, 2 },
{ 5, X, 6, 14, 11, 1 },
{15, 6, X, 8, 4, 12 },
{ 3, 14, 8, X, 13, 10 },
{ 9, 11, 4, 13, X, 7 },
{ 2, 1, 12, 10, 7, X } };
// Finds the shortest path from passed start node to all others
void shortestPath(int start)
for (int k=0; k<6; k++){
for (int i=0; i<6; i++){
for (int j=0; j<6; j++){
if(weights[i][k] != X && weights[k][j] != X && weights[i][k]+weights[k][j] < weights[i][j]){
weights[i][j] = weights[i][k]+weights[k][j];
} // end shortestPath
public void showSolution(int start) {
System.out.println("The shortest path from " + (char)('A' + start) + " to each node is:\n");
} // end showSolution
public static void main(String args[]) {
Final_Start fs = new Final_Start();
fs.shortestPath(0);
fs.showSolution(0);
Old Apr 24, 2012 | 05:14 PM
#1 STUNNA's Avatar
Sanest Florida Man
this is all I need to know about Java
Start Button > Control Panel > Programs and Features > Java Update ## > Change/Remove
Fuck that shit!
Old Apr 24, 2012 | 06:08 PM
doopstr's Avatar
Java is such crap on the workstation but it's amazing how many backend systems are running Java application servers to do serious stuff.
Old Apr 24, 2012 | 06:19 PM
honda_nut's Avatar
so can anyone tell me if i'm doing it right?
Old Apr 24, 2012 | 06:33 PM
ez12a's Avatar
the overexplainer
eh i learned a bit of java my first year but ended up declaring something else. Nothing really stuck, sorry. I know basic javascript? I know that's not even close to being the same. I can kind of read what you're doing with but i cant help Going through the array with a for loop while incrementing the array position and also nested arrays or something. Fun stuff.
Android apps are more or less java are they not? They run in a java VM.
Old Apr 24, 2012 | 06:48 PM
honda_nut's Avatar
yup, android apps are java based
Old Apr 24, 2012 | 07:27 PM
TeknoKing's Avatar
objective programming, so much fun, I don't miss it one bit.
Your objective is to recreate the existing Dijkstra class? Did you try compiling it? I'm not very excited about the nested loops, do they traverse properly? plot it out on paper (backwards).
If I'll get bored, I'll trace it (after 9 hours of staring at 3 screens, I'm not bored yet, sorry)
Old Apr 24, 2012 | 08:05 PM
honda_nut's Avatar
Actually, I don't even have to use the Dijkstra class. The task is to determine the shortest path from a given node to each other node. I only need to track the cost, and NOT route of each path. I already know what they are, but just want the program to figure it out and print them.
It compiles properly, but when I run the program it only prints this:
"The shortest path from A to each node is:"
I want this output:
Node: B - Cost: 3
Node: C - Cost: 9
Node: D - Cost: 3
Node: E - Cost: 9
Node: F - Cost: 2
P.S. If anyone can figure it out I'll send them a gift. lol
Old Apr 24, 2012 | 10:30 PM
honda_nut's Avatar
Well, I got it to work. I was missing a print statement
Only problem is that it prints out extra stuff. The stuff in red is all I want.
4 3 9 3 9 2
3 2 6 6 8 1
9 6 8 8 4 7
3 6 8 6 12 5
9 8 4 12 8 7
2 1 7 5 7 2
// A B C D E F
void shortestPath(int start) {
for (int r=0; r<6; r++) {
for (int c=0; c<6; c++) {
if(weights[r][c] == X){
System.out.print("n/a");
}else{
System.out.print(" " + weights[r][c]);
System.out.println(" ");
fs.shortestPath(0);
fs.showSolution(0);
joflewbyu2
Oct 8, 2015 11:16 AM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
