Any Microsoft Excel Experts?
#41
Needs more Lemon Pledge
NVM, got it using =INDIRECT
#42
takin care of Business in
Received 4,732 Likes
here is how I imagine:
sheet1 column A has numbers, sheet1 column B has text/desc.
sheet2 column A has numbers, and you want the text from sheet 1 column B in sheet2 column B
=VLOOKUP(A1,Sheet1!A:B,2,FALSE)
EDIT: sorry, misread your question and replied..
glad you were able to figure it out...Indirect is similar to '=' but if you insert/delete rows, EXCEL adjusts '=' but indirect does not get adjusted!
so if you have in sheet1 col A row 1, say the number 3500...in sheet 2, col A row1 put "=indirect(sheet1!a1)" and in col B row1 put "=sheet1!a1"...now go to sheet1 and insert a row above the 3500, excel will adjust the formula in sheet2 col B, but indirect which was fetching the value 3500 will now fetch 0. Try it out!
stogie1020 (05-27-2015)
#43
Good to know about the adjustment with vlookup versus INDIRECT, thanks! Once I had the formula results, I copied and pasted as values since the initial listing of 3500 items will never change.
I tried it with vLookup and eventual got that to work, too. I know so little about the deeper ways to use excel... I had trouble with the vlookup initially because I didn't have column A set to sequential numbers, I just had the actual values (in this case email addresses) so the vlookup was not working. Once I added a column A with 1, 2, 3, etc. it worked like a charm,
Thanks!
#44
Stoges you could also use =INDEX(). Cool thing about that is your array could be two dimensional.
#45
I will have to check that out, thanks!
EDIT: Mike, Index would have been perfect before I added the sequential numbers column to the list for the vlookup.
Dammit, there are three ways to do what I wanted!
#46
^^^ +1
you can use INDEX along with MATCH...
MATCH returns the column/row number of the string it matches. You can feed that into INPUT to get the contents of the cell.
I think vlookup is your best option unless you want to manipulate cells
#47
OK, slightly more complex question now...
In column 1 I have a list of names of people who came into an office. Each name can appear multiple times as they may have come in more than once.
In column 2 I have a second name, of the person the 'column one' name saw when they came into the office . Column one names can be listed with a column two name more than once due to multiple visits.
What I need to do is isolate the column one names that ONLY saw one particular column two name (no matter how many times).
In the following example, I am looking for Mike and Peter (both ONLY ever saw Jeff) but not Mary or Jane:
#48
#49
I come to the well of excel knowledge once again.
I have 7500+ rows I need to sort through. Column A has a date. Column B has a plain text (for sake of simplicity, I am showing it as the name of a color).
There are multiple instances of many dates, some with the same color and some with different colors.
Example:
What I would like to do is compile a listing that shows a single instance of each color present for each specific date.
I.e., I want to end up with:
1/4/18 blue
1/5/18 blue
1/7/18 red
1/9/18 red blue green
1/15/18 green red
1/16/18 blue
1/17/18 green
Any ideas how to do this?
Example:
1/4/18 blue
1/5/18 blue
1/7/18 red
1/15/18 green red
1/16/18 blue
1/17/18 green
#50
Forget my last post. I oversimplified it too much. Working on a better example of the actual data.
#51
OK, here is what I really need:
I need to go from multiple daily entries with varying colors to a single entry per day with ALL colors that were previously reported for any entry that day.
#52
VLOOKUP and CONCAT/TEXTJOIN will be your friend in this case:
https://www.get-digital-help.com/exc...into-one-cell/
somewhat similar use case
#53
#54
I'd use PowerQuery to unpivot the colors and then regroup the dates with a list of colors.
But I'm weird.
But I'm weird.
#55
Here's the PowerQuery script:
What this does--
- read in the data (headers are "Date" and "ColorList")
- set types on the data
- get rid of spaces so we just have comma delimiters
- split columns with more than one color into one row for each color
- group a list of distinct colors by each date
- split that list out, separated by commas and a space for readability
- get rid of the list column
and done.
Put your original data into a table called "TableIn" with column headers as mentioned above. Copy this script into the Advanced Editor under the PowerQuery Editor. Save it and have it load to a new table.
No messing around with constant recalculations or anything. Mikey doesn't believe in cleaning data with the spreadsheet. That's a pre-processing step.
If you are dealing with huge data, this will be much much faster than any array formula based solution as well.
let
Source = Excel.CurrentWorkbook(){[Name="TableIn"]}[Content],
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Date", type date}, {"ColorList", type text}}),
#"Replaced Value" = Table.ReplaceValue(#"Changed Type"," ","",Replacer.ReplaceText,{"ColorList"}),
#"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Re placed Value", {{"ColorList", Splitter.SplitTextByDelimiter(",", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "ColorList"),
#"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"ColorList", type text}}),
#"Grouped Rows" = Table.Group(#"Changed Type1", {"Date"}, {{"Colors", each List.Distinct([ColorList]), type text}}),
#"Added Custom" = Table.AddColumn(#"Grouped Rows", "Unique Colors", each Text.Combine( [Colors], ", " ), type text),
#"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Colors"})
in
#"Removed Columns"
in
#"Removed Columns"
and done.
#56
Wow, that looks awesome Mike. I will play with this today and see if I can get it to work.
Thanks!
Thanks!
#57
No VBA solution?
#58
If y'all haven't tried PowerQuery out, you should. Coding is assisted by a GUI, and debugging is a snap because you see the result as soon as you enter the new line in the script.
#60
AZ Community Team
Received 7,770 Likes
I've got two rows of data. I need to multiply the row data, then sum the products across columns. I can do it 'brute force' but I'm sure there must be an easier way. What I'm doing:
(a1*a2)+(b1*b2)+(c1*c2)+(d1*d2)+ ..... +(x1*x2)
#61
=sumproduct( a1:x1, a2:x2 )
Bearcat94 (12-21-2019)
#62
What this does--
and done.
What this does--
and done.
Ultimately, I needed to get a report out, so I re-generated the output of the data into a slightly different format that I was able to compile what I needed from.
However, I quickly saw the power of PowerQuery, and started going down the rabbit hole of trying to learn how to use it. There are a bunch of "intro's" and such, but I feel a little lost, as most I found assume serious VB skills.
Any good places to start that you recommend to learn how to use PQ?
#63
OK, so I tried to make this work. Tried.
I do have experience with quite a few programming languages though, so when I see a new one I can usually get the gist of it pretty quickly.
I used to like vb, but it is really old tech and clunky compared to the newer tools.
aunggu2002
01-06-2008 05:29 PM
