Aarg... computer help please.
Vista Home on my laptop. Often, when I click on the Favorite link, nothing. Hit Escape a couple times, most time it frees up and I can get into my Favorite links. I have tried deleting some links, reset and deleting cookies & saved links. No cure. Any thing else I can try?
Thanks.
Thanks.
Sanest Florida Man
Egg way to technical to walk you through, have someone look at it.
Sanest Florida Man
try resetting internet explorer, disabling add-ons, running IE in no-add-on mode to see if the problem still exists. Also this may be one sign of many of a failing hard drive especially if you're running a vista aged PC. is this the only issue you're having with your PC or is it slow to load webpages, launch apps and respond to your mouse clicks and keyboard presses?
Eggplant-EX (11-01-2012)
Go Giants
The sizzle in the Steak
Windows 8 mofo!
Osx!
FML!!
Sanest Florida Man
Well if you have data on it that you want to save then you better back it up now before it dies. It's NOT going to get better it will only get worse, the clock is ticking....
Depending on how bad it is it might be clonable which only takes a few hours and is relatively hands-off process (so should be cheaper labor wise). But usually in my experience performance has to be REALLY bad for a normal user (you) to speak up about it and if it is that bad it's probably best not to clone the failing drive.
I got two PCs right now with bad hard drives (I've had six in the past two months) and one they waited until the drive was so dead that computer didn't even know it was plugged in and the other won't even finish booting up. They just keep using it and not saying anything to anyone until it's too late.
Someone?? Does Vista have the W7 harddrive testing software in it?
Sanest Florida Man
Check disk? Yes. 7 has a memory diagnostic built-in, so does Vista
Thanks.
Thanks.
Do you have Vista Service Pack 2 installed?
What IE add ons are installed? Try resetting IE:
http://support.microsoft.com/kb/923737
perform a disk health check and get a SMART utility to check for any values that are abnormal. If the drive checks out and SMART shows no abnormalities, then do the following:
1. Schedule a disk check and have it check for bad sectors and come back about 2 hours later
2. Clean up IE settings (delete temp files and whatnot)
3. Disk Cleanup
4. defrag hdd
3. Disk Cleanup
4. defrag hdd
If your only issue is with IE favorites, highly doubt it's a bad hard drive/file system..
^ hdd in the laptop is creeping up on 3.5 years old (if you use RTM date for Win 7) and it would not be too far fetched to see a drive failure at this time......
Also when troubleshooting pausing issues like that, you have to rule out the physical media first...
the overexplainer
If it's hard drive related it may be logged in the event viewer.
Start > search for Event Viewer > Administrative Events
disk errors will show up under "ntfs" or "disk". HDs can test clean with their built in SMART self tests (DPS Self Test) and still have issues. I had one this past week that tested clean with a fresh deployment but when we installed Acrobat X Pro it never worked right. Repair installations kept failing.
I went into the Admin Events and clicked around. Looked at the Events and suddenly, the screen went blank and started doing a download followed by a scan. After I booted the computer back up, the computer seems to be working fine and faster.
Just for future reference. If you want to give that old lappy some life. Put a samsung ssd in it, 840 series just came out 128 gb is around $109. Couple that with windows 8 and it will be a whole new machine.
You can prob do the whole switch for less than $150 depending on what you pay for win8. once you go solid state, you will never go back.
Sanest Florida Man
sounds like you have a virus. Something popped on your screen while you were in event viewer and started downloading and scanning!? That sounds like a fake virus program. What was the name of the program that was downloading and scanning. Event viewer doesn't download or scan anything....
Bonjour Service . I googled this but it is tied to Itunes. I did delete it anyway as it said if Itunes needed it, it would download a new one.
It still locks up but with less frequency. I will live with it for now....
Thanks all.
Thanks all.
What anti-virus program do you have installed?
Try running TDSS killer in default mode and see if it finds anything. If it finds something and there is a "cure" option, then tell it to go ahead and "cure" the issue. If it does not have a "cure" option, then skip it and report back here what the issue was.
http://support.kaspersky.com/downloa...tdsskiller.exe
Go Giants
Bonjour service is ok.
I also recommend an external hard drive for backing up those hard to replace files after you get the issue resolved. That way if the system ever crashes again you can reload all the important stuff.
Sanest Florida Man
:ibwhiskers:
Reporting simply because of file sharing is against their TOS.
I can't find a link anywhere online. But it should be in the disclaimer on the paperwork you sign.
Edit: At least it was 7+ years ago when I was a "geek".
They specifically allow reporting in their privacy policy:
"We also reserve the right to report to law enforcement agencies any activities that we, in good faith, believe to be unlawful."
http://www.geeksquad.com/policy-for-privacy.aspx
Also, FWIW, the GS TOS for their support plan:
http://www.geeksquad.com/uploadedFil...ortPlanTOS.pdf
Go Giants
I didnt actually work directly for GS, just contracted for them,, but we saw a lot of shit, porn, file sharing, etc. but unless we saw child porn or something very illegal we weren't reporting anything.
Wow, you're making a statement based off of foggy memory from over 7 years ago?? Next time, please don't.
Who said something I remember from 7 years ago was a foggy memory? Lol
I could have a 1000 movies on my computer. That does not, however, make it "unlawful". The extent they would have to go to prove that is quite large. Think about what they would have to do to prove such things. It's not worth their time.
Oh I found their TOS and their Privacy Policy. Any idiot can Google those, obviously. I was looking for something a bit more...specific. Which, last I looked, was on the back on the paperwork you sign in the store (like I already said).
As I said before, there has to be more to that story. Because the only thing that EVER prompted a red flag was child pornography.
Bottom line, there's nothing in the GS TOS that limits reporting illegal activity...
Sorry OP. Joke turns into pissing contest...my bad.
^^^^ Saved by the "edit" function
Mr Marco (11-05-2012)
