*Quick* Need PC help, my laptop wont boot!
Old Sep 10, 2009 | 06:05 PM
Dem1K's Avatar
Got a Job!
Unhappy *Quick* Need PC help, my laptop wont boot!
So I'm in the restroom, and I come out to go back to my laptop and finish up some work, and the damn thing shut off. So I went to turn it on, and it goes straight to "a disk read error occured, hit CTRL+ALT+DEL etc." Ok.....
So I look it up, and I figure something minor must have happened. The steps that I come across are as follows:
Everybody's situation and hardware here is slightly different and there is a variety of issues that could cause the "disk read error press crtl-alt-del to restart" .
Depending on the cause and how long the computer has been properly functioning before this happened, the solution(s) differ.
My answer here is based Primarily an EIDE hard drive interface with Windows XP Pro as the OS and requires an XP Pro installation CD and in the worst case, a valid license.
Critical Background: In order for a Hard Drive to be the Boot device of a computer, the BIOS parameters and physical placement (installation) of the drive must be correct.
*****Section A*****
1.)The drive jumpers must be positioned properly...ie: set to the Master position or master with slave if there is a slave drive attached to the same channel.
**note** if the drive and Motherboard support 'cable select', that is a good choice as well, but in either case, be sure to have the drive installed on the end of the cable if it is a master, and the middle connection if it is a slave. THIS IS IMPORTANT and ABSOLUTELY CRITICAL
2.)The drive must be installed on either the Primary SATA or IDE channel, and the BIOS must be configured to Boot from which ever interface you have installed the drive.
Ok now, having ensured that all of that is correct, it is probably a good idea to verify that you are using the latest BIOS version available for your motherboard, even if the machine has been running for years, with the amount and frequency of OS updates, it is possible for a conflict to arise seemingly out of nowhere.
One thing to note , there are issues with older motherboards accessing Large Hard Drives, so if this is a new drive on an old board, there is the possibility of requiring an IDE controller card for access to this drive. A drive connected to a controller card may or may not be bootable based on the limitations of the Motherboard and BIOS.
If all of those conditions are correct, you can begin the long and frustrating process of getting this damn thing bootable again!
*****Section B*****
1.)Load the XP Recovery console from the CD
2.)At the prompt, choose the installation # of the OS (usually just 1) and enter the Administrator PW. If you do not have the PW, you must reset it using a linux tool, and I'm sorry but that explanation is better left in a different forum
3.)At the command prompt, type FIXMBR , this will repair the Master Boot Record of the Drive. Don't worry about the warnings, this won't make the situation an worse than it already is - I promise
4.)Then type FIXBOOT , this will repair the boot sector and make sure that the files required to boot up are present.
5.)Now type EXIT and the PC should reboot - if it doesn't, go hard and do it yourself the old fashioned way
In most cases Windows should now load. If it still won't boot.......
*****Section C*****
1.)Load the Recovery Console again
2.)At the command prompt, type CHKDSK /P , this should correct any errors on the drive or orphaned/corrupt files/directories
3.)Now perform the FIXMBR and FIXBOOT commands again
*****Section D*****
If Windows still will not bot up........The steps here are a variation of a new installation of Windows XP and will require a Valid Installation Key for XP activation
1.)Boot the computer from the CD again, but instead of loading the Recovery Console, choose to set up Windows Xp. The install wizard will search for previous installations and when it finds yours, it will prompt to either continue installing a fresh copy of windows or Repair this Windows Installation . Choose to Repair Windows.
2.)The wizard will now run through several operations deleting the existing boot data and some system files
3.)Run through the installation prompts
4.)After the installation wizard is finished, Windows should now boot up to the existing installation with the exception that windows will have to be reactivated.
If you still cannot get the Hard Drive to Boot........
*****Section E*****
The hard drive is most likely not compatible with the PC Hardware and/or there is a problem with the Processor, Memory, and/or Motherboard or components of those.
This was the case in my latest situation. The Drive needed to be installed into a newer System (post 2005 motherboard) and the steps in Section D were used to solve the issue. I hope this helps most of you
from Another IT Guy
Anyway, I pop in my XP Pro cd, and it gets to the Setup screen, and it shows my C: Partition as 76309 MB (I have an 80gb hd in my laptop) -- WTF?! And obviously, I can't hit R to recover the OS because apparently there is no OS there! Can someone please tell me wtf happened? I've had this laptop for 4 years now btw (It's an Asus Z70VA). Please if you could help me out I would REALLY appreciate it, thanks!!!!!!!
`John
Old Sep 10, 2009 | 06:11 PM
Dem1K's Avatar
Got a Job!
Oh and I forgot to mention, it makes weird sounds here and there!
Old Sep 10, 2009 | 07:06 PM
Anachostic's Avatar
A & B probably won't help. C & D might. Depending on where the corruption is on the hard drive, you may be able to salvage your data. The hard drive is toast and you can consider this a recovery mission.
You may be able to boot to a command prompt using the Windows CD and copy the files you want to a USB stick. That hard drive is PATA, so you'd need a notebook drive adapter to connect it to another computer to salvage the data if you chose to pull it out.
Old Sep 10, 2009 | 07:12 PM
Vector02's Avatar
Either slave that drive to another machine or use the advise above to archive data asap. If the HDD is clicking or making noises, don't trust it anymore. Replace it before you clean load the OS.
Old Sep 10, 2009 | 07:30 PM
Dem1K's Avatar
Got a Job!
But I can't get to the Recovery Console, hitting R does nothing. I need to know what exactly are my options, as I've never physically worked on a laptop before, only desktops(in terms of taking them apart).
Old Sep 10, 2009 | 07:39 PM
Vector02's Avatar
Laptop HDD's are usually very simple to remove. On the bottom and sides of the laptop, check all panels big enough to enclose a 2.5" drive, or look for the panel labeled with the "can." If the drive is SATA, it utilized the same cables that a desktop does for data and power. If it's ATA, you'll need to find a 2.5" to 3.5" adapter or use a converter to plug in via USB. <-- like from these guys http://www.sataadapter.com/
Old Sep 10, 2009 | 07:42 PM
Dem1K's Avatar
Got a Job!
from what I've read it's a 2.5" ide
Also...what happened? Is all my data gone?
SwervinCL's Avatar
Nom Nom Nom Nom
Send your hard drive to Jefford..
Old Sep 10, 2009 | 07:44 PM
Anachostic's Avatar
If yours is similar to this, getting the HD out is easy. The hard part will be getting the IDE adapter to make it work in a desktop.
http://www.notebookforums.com/thread153405.html
Last edited by Anachostic; Sep 10, 2009 at 07:44 PM. Reason: duh. You want this link, I suppose.
Old Sep 10, 2009 | 07:46 PM
Anachostic's Avatar
The answer is a definite maybe. At least prepare yourself for a yes. The hard drive is having mechanical problems and may have damaged a section of itself that has Windows files or maybe has your files. That is not know at this point. The goal is to get as much stuff off before it damages itself further.
Come to think of it... have you been downloading a bunch of emo MP3s lately?
Old Sep 10, 2009 | 07:49 PM
Vector02's Avatar
Barring any major hardware failure, your data is still intact and able to be pulled off the drive. It's a matter of finding out if it can be viewed and recovered easily, or you'll need to use some recovery software.
Dem1K's Avatar
Got a Job!
lol, nope, no emo over here
In fact I haven't dl'd shit in a long while, except for a couple Entrouage episodes a few weeks back
Ok cool, so what should I do at this point in time? Give me a run down, step by step please
Old Sep 10, 2009 | 07:56 PM
Vector02's Avatar
1. Find where your HDD is located and remove it from the PC.
2. Identify if the drive utilizes a ATA or SATA interface
Once that is done, we can talk about getting it hooked up to another computer.
Old Sep 10, 2009 | 08:00 PM
Dem1K's Avatar
Got a Job!
No sweat, how do I know if it's ATA or SATA? BTW it's only 2 screws holding that POS in.
Oh, and thanks for the help!!!
Old Sep 10, 2009 | 08:06 PM
Vector02's Avatar
2.5" ATA will look like this:
SATA will look like this:
Old Sep 10, 2009 | 08:26 PM
stogie1020's Avatar
Needs more Lemon Pledge
Shhhhh.........
Old Sep 10, 2009 | 08:52 PM
#1 STUNNA's Avatar
Sanest Florida Man
Bro just go spend $20-$25 and get a usb to sata/pata adapter and you can plug in any drive out there, 2.5 pata, 3.5 pata or any sata drive and it comes with all the adapter cables. I use one everyday, I couldn't do my job without one. Plug it into another PC and copy the files over.
Old Sep 10, 2009 | 09:26 PM
Dem1K's Avatar
Got a Job!
OK I kinda need this done asap, can I get this at a store such as bestbuy, or will I have ot order it online? Also, where's the best place for me to get a new HD for my laptop for cheap?
Old Sep 10, 2009 | 10:01 PM
stogie1020's Avatar
Buy what you need from newegg. Order it with next day delivery. Eat waffles. Package will arrive.
Old Sep 10, 2009 | 10:12 PM
BigLizard's Avatar
Moderator Alumnus
^Zing! I love waffles.
Old Sep 10, 2009 | 10:24 PM
#1 STUNNA's Avatar
Sanest Florida Man
I've seen them at CompUSA. If you have one still around near you then go there. Or maybe check a small computer repair place, they should have one.
Old Sep 10, 2009 | 10:26 PM
#1 STUNNA's Avatar
Sanest Florida Man
Look along the left side of the page and you can see a few different models
http://www.compusa.com/applications/...76554&csid=_21
Old Sep 10, 2009 | 10:34 PM
Vector02's Avatar
Fry's has them too. Not sure if you have one around.
Old Sep 10, 2009 | 10:42 PM
stogie1020's Avatar
You Sir, are a highly educated, worthwhile member of society!
Old Sep 10, 2009 | 11:02 PM
Dem1K's Avatar
Got a Job!
bahhhhh!!
You know what, I think I have most of my important shit backed up anyway, so I guess I oughta look for a HD right now. Does it matter if I get a 5400 or 7200rpm HD? I don't need a large HD, my 80gb was more than plenty.
Old Sep 11, 2009 | 12:04 AM
Dem1K's Avatar
Got a Job!
Best Buy has the following for fairly cheap:
WD Scorpio Blue 250gb - WD2500BEVSRTL1 for $65
WD Scorpio 160gb - WD1600VERTL $59
WD Caviar 160gb - WD1600JBRT $59
Any one better than the other (and don't say shit about the size )
BTW the Caviar is 7200rpm, not sure if that's needed or not
Old Sep 11, 2009 | 12:09 AM
#1 STUNNA's Avatar
Sanest Florida Man
7200RPM isn't needed but it's faster than the others. They're all really about the same, you won't notice a huge difference if you went 7200 vs 5400RPM
Old Sep 11, 2009 | 12:31 AM
Dem1K's Avatar
Got a Job!
good to know, thanks
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
jmaxima03
Sep 27, 2015 10:22 AM
