Update on Switchblade Keys...
#321
Originally Posted by Timmahh
Did you bring the template from FLB to your lock smith and/or Acura? When you complete the purchase there is a PDF that has a key diagram and indicates where to line up the current key and the blank to ensure proper cutting..
Let me ask a stupid question - does it TURN the ignition, but not start the car?
If it turns the cut is fine.. you just need to get the immobilizer chip programmed @ Acura..
#322
Not sure honestly.. maybe you should try inserting/removing the key in door lock, trunk passthrough lock, and glove box lock a few times and see if that helps.. it's possible there's just some sharp pieces that need to wear down on the key thus preventing the ignition switch from turning.. maybe the ignition has a tighter tolerance and that's the problem
#323
I finally got my keys cut and programmed
Based on recommendations from some members based in the GTA, I went to a locksmith (with FLBUSA's instructions). They cut a 'demo' key to try first. It opened the doors well, went into the ignition, but wouldn't turn it over. The initial thought was that the immobilizer was required to turn (THIS IS INCORRECT). The immobilizer only enables the car to start, without the immobilizer programmed it will turnover but will not start.
Based on the assumption that the 'demo' key would not turn in the ignition because of the chip, we proceeded to cut the mem1 key.
That went into the door AND ignition beautifully - no issues, so we proceeded with my mem2 key - same great results.
I believe the big step is to follow FLBUSA's instructions about matching the 'notch' in setting up the cutting.
I then went to a 3rd Acura dealer (the first two said it wouldnt work because of different chip technologies - eventhough they've done them already for other members here ) to program all my keys, and I have to say THIS IS THE BEST MOD FOR THE MONEY.
Thank you FLBUSA!!!!
#324
Pete,
Is there anyway I can just purchase the just the milled key (I still have the remote part and all)?? I have bought two switchblade keys from you and they were both messed up by the dealer and the locksmith but the locksmith won't refund me the money. So I now have two messed up keys and neither work. I just need the milled key and the black piece that is on there already.
#326
Originally Posted by JDMPLUS
i've pm'd you.
can people explain to me how does this work.
do we send him the payment and the key and he will switch our key on to the TL switchblade key and program it or what?
What you do is you send him the $95 dollars through Paypal. FLBusa.com is the site. You get the key, you either can bring it to a locksmith or the dealership for them to cut your key and program your key.
#329
It refers to the memory seats function. I am not sure which years support it but I know the TSX 2006+ supports that feature. If you don't have a car that supports the memory seats it's cheaper to just get the mem 1 (Memory 1) key.
Originally Posted by TL_moda
what's the difference between mem 1 and mem 2 again?
#330
Open button NOT working
I just received the switchblade key yesterday.. This thing looks awesome... I've programed the remote per instruction given on the website but the darn open button does not work... Lock, trunk and panic works just fine... except for the open button. Did anyone encounter this situation? Am I doing somthing wrong or is the key defective? I haven't cut the key or programed the immobilizer chip yet but was planning to do so today.... Guess it'll have to wait until i figure out why the open button doesn't work.
FYI, I have a 04 tsx.
Any feedback would be great.
#331
try this: https://acurazine.com/forums/showpos...&postcount=118
#334
That worked like a charm... thank you
#337
#338
Originally Posted by SoCaliTrojan
mem 2 is the cheaper key, not mem 1
lol, i got my logic switched somehow
get mem 1
#340
Delaware Residents.........DO NOT take ur key to Price Acura in Dover to have the key cut. They fuked up my key...looked like a monkey did it.
They said its to thick..blah blah and took them 2 hours to do it. Waited 1 hour and saw they just took my car in the garage. Then waited another hour and they messed up my key. Made me late for work..haha it only take 45 min...right .
Im going back tomorrow and complain.
Pete, I will email you soon and see if you can help me out...if they dont reinburse me for the key.
Im so PISSED.
Im so PISSED.
#343
Originally Posted by ImPoRtHoNdA
hey where can i buy the switchblade keyfob at now? And does anyone out here still cut the keys? i have an 05 TL
http://www.flbusa.com/switchblade_key.htm
Order the keys you want and you should be set... FLBUSA will send you detailed instructions on what to do next, once you receive his package with your new switchblade key...
Good Luck
to FLBUSA for a great mod...
#345
Originally Posted by rodneyc77
Go to the following link:
Good Luck
Good Luck
I found that today, thanks. Does FLBUSA cut the key for you? or do you have to bring it to another place to cut it and get it programed. THEN you can use it? If i have to bring it to someone else to get it cut, aprx how much do they usually chargE? thanks.
#346
It shouldn't cost you more than $60 to cut and program...
#347
Originally Posted by atrain4life
Has any body in the Detroit, MI area got their key milled yet. I want to kno where a place that would do it for a good price and is reliable.
#348
Im so PISSED.
Im so PISSED.
#349
Im so PISSED.
Im so PISSED.
wow was he blindfolded when he did this
#352
updated dealer list
Has the dealer list been updated since the p.2 version? I live in Columbus OH where the dealers have trouble spelling Acura. Any recommendations in the Midwest area? I travel alot on business and could stop by a dealer in OH/MI/IN if I knew they were recommended. Thanks.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
