Ichiba Wheel Spacers...5/10/15/20/25 Version 1 and 2 available!
Former Vendor
Ichiba Wheel Spacers...5/10/15/20/25 Both Versions available!
Looking for Spacers? Everywhere not cheap enough? Well look no further.
Shoot me a PM and I'll be more then happy to hook you guys up! Please also leave Year Make and Model of Vehicle.
![](http://i286.photobucket.com/albums/ll96/MrWongG35/IchibaSpacer.jpg)
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Note:
Sold as one pair (2pcs) with 10pcs longer studs.
Description:
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
~PM~ For Pricing too low to post!
Description:
Note:
![](http://i286.photobucket.com/albums/ll96/MrWongG35/IchibaspacersV2.jpg)
Description:
I drive a Subata.
Can I put the spacers for the stockies as well??
Site Lurker, Rare poster
I drive a Subata.
^ Really? Nice.. because my fronts are fine but the rears look just a little bit narrow.. I should measure how much i can get them out..
Hey cant PM you I guess cause I don't have many post on here...all my rep is on the other site. However I need a quote to zip 35229 for both versions for an Acura TSX (thats for 2 sets at 15mm). Thanks!
