Excelerate Performance: XLR8 ISC Coilover Special!!!
Old Sep 19, 2013 | 01:04 PM
Excelerate's Avatar
Former Sponsor
Excelerate Performance is proud to announce a special sale on our XLR8 ISC coilover line for the Acura lineup. We have worked closely with ISC suspension to design coilovers for the Acura TL (2nd, 3rd and 4th gen), TSX (1st and 2nd gen), RSX, and NSX. We have become the exclusive distributor in North America for the Acura models, thus making them XLR8 coilovers manufactured by ISC. So what are ISC coilovers and what are the benefits?
ISC Suspension has been present in Asia and Australia for over 13 years and expanded to the North American market in 2008. With roots in motorsports like Formula Drift, ISC is geared towards the performance enthusiast in mind who demands adjustability and reliability. ISC Suspension North America caters to Japanese and European import performance vehicles, attracting both street car enthusiast and race car enthusiast alike. All customer support, rebuilds and service work is done in house in their USA facility (New Hampshire). With a 5 year warranty surpassing industry standards. Featuring products filled with features and benefits ISC Suspension has a strong presence in today's market.
The N1 coilover can be lowered approximately 3-3.5 inches lower then standard ride height. The spring rates are set up specifically to suit your car and therefore will improve handling and stability dramatically. We can make packages for track/rally/drag and of course street. Our lineup will specifically be designed towards the street/sport customer. However, to offer more flexibility we will offer the option for custom spring rates at no extra charge. This will require extra time.
ISC N1 Coilover
Features:
Damper Adjustment
  • Rebound/Compression adjusted in unison via 32 step adjustment.
Pillowball Uppermount (RSX) or Aluminum Upper Mounts
  • Adjustable camber allows more/less on road track for all conditions (RSX only)
Piston Rod Design
  • Strengthened steel piston rods
  • Meets race/sport standards
Sports Spring
  • Made from high quality SAE9254 steel Dyno tested over 500,000 times on compression inspection with less than 5% deformation.
  • Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free). Spring rates are typically as follows for the Acura models: Street Comfort 10/6 Street/Sport 12/8 Track/Race is 14/10.
Ride Height Adjustable
  • Full length height adjustable
  • Pre-load adjustable with separate spring locks
  • High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
  • Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
  • Specially anodized surface to prevent internal corrosion and surface rust
  • On various models camber can also be adjusted via the bracket as well as the camber tops (RSX only)
Single Cylinder Design
  • Larger cylinder and piston design to advance driving stability and dexterity
Thrust Bearing
  • Improves steering and creates a smoother ride
  • $55 upgrade included for free on all our coilover kits with Macpherson style struts
SO WHAT IS THE SPECIAL SALE?
Excelerate Performance will be offering a free front or rear camber/toe kit with the purchase of every XLR8 ISC coilover kit!!!* This is a $125-$160 value free of charge with your new purchase of XLR8 ISC coilovers. Please specify which camber kit you want in the Customer Comment box when checking out.
So what camber kit will you get? Likely it will be as follows:
2G CL/TL - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
3G TL - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
4G TL - INGALLS Front Ball Joints or INGALLS Rear Toe Kit
RSX - INGALLS SmartArm™ Adjustable Rear Link
1G TSX - INGALLS Front Ball Joints or INGALLS Rear Camber/Toe Kit
2G TSX - INGALLS Front Ball Joints or INGALLS Rear Toe Kit
*The brand of camber kit will be at our discretion. Market value on our website is not to exceed $160. Cannot be combined with any other special or coupon.
ORDER HERE: http://store.excelerateperformance.c...s/g-65477.aspx
Old Sep 19, 2013 | 02:07 PM
99blackhatch's Avatar
2004 Carbon Gray 3.5RL
No love for the 3.5RL...
Boooooring.
Old Sep 24, 2013 | 02:07 PM
Excelerate's Avatar
Former Sponsor
We may have something for you. Shoot us a PM.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
