Excelerate Performance: XLR8 Clutch Systems Now Available!
Former Sponsor
Excelerate Performance is excited to release our XLR8 Clutch Systems!! Whether you have a Base TL or a Type S, we have a kit for you.
To view the options, simply follow the link below and enter your vehicle information.
XLR8 Clutch System - Excelerate Performance - Japanese and European Performance Specialists!!
The systems are available in the following versions:
Daily
This clutch kit was engineered for those with bolt on modifications.This kit includes a heavy duty pressure plate, which has an increased clamp load with little or no increase in pedal pressure. The organic disc material has a high metal content that increases the co-efficient of friction by two times over a stock lining and increases rotational strength up to a 12,000 RPM burst point. Overall, this clutch system maintains a stock feel while offering strength and durability. The recommended usage is for a vehicle that is driven daily, for street performance or even a moderate race application. Torque capacity will be roughly 340 ft/lbs.
Street/Strip
This clutch kit was engineered for the street/strip climate. The pressure plate is precision balanced for vibration free operation at high RPMs.The friction material is a kevlar design. The recommended usage is for a vehicle that is driven daily, for street performance or even those used for rally or endurance racing. Torque capacity will be roughly 425 ft/lbs.
Drag
This clutch kit was engineered to handle heavily modified cars and designed to function according to the specific needs of the drag strip/track. Discs are a segmented puck design (6 puck setups available), which reduces rotational mass and are assembled with all high carbon component pieces for maximum strength. The friction material used is graphite-impregnated ceramic, which is perfectly suited for drag racing because of its maximum friction co-efficient, rapid heat dissipation, and abrupt engagement characteristics. The recommended usage is for a vehicle that is used for drag racing or drifting. Torque capacity will be roughly 500 ft/lbs.
Flywheel
The XLR8 flywheels are made by AASCO Motorsports. AASCO has been manufacturing flywheels for over 20 years. Their unique ability to manufacture thousands of the highest quality OEM replacement light-weight flywheels as well as several hundred custom variations differentiates them from the competition. AASCO maintains a high level of quality control.
Former Sponsor
We have clutch kits in stock and ready to ship!!
Former Sponsor
We now offer kits without the Flywheel, for those of you who just want to resurface and reuse your OEM unit!
4G application or 3G only?
Former Sponsor
At this time our clutch kits are only for the 3G TL, 03 CL-S, and 7th gen accord V6.
Former Sponsor
We continue to stock the best clutch kits on the market for your TL/CL/Accord!
Former Sponsor
We've sold several clutch kits to Acurazine members, and are getting positive feedback across the board! Trust Excelerate Performance with your next clutch replacement!
Former Sponsor
Our XLR8 clutch kits are offered in Daily, Strip, or Drag, depending on your needs!
Former Sponsor
Our clutch kits include the updated AASCO flywheel, clutch disc, pressure plate, and now have the pilot and throw out bearings included at no additional cost!
ExcelerateRep
Sponsored Sales & Group Buys
02-11-2016 10:40 AM
ExcelerateRep
02-11-2016 10:40 AM
ExcelerateRep
02-11-2016 10:39 AM
