Cusco Strut Braces and Lower Subframe Braces *** In Stock!
Old 07-17-2007, 04:01 AM
  #161
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
As noted above and in Marcus new-revised sig on his post-
the FASTEST way to reach him is on the phone 1-949-295-1668 pacific time
or email him direct marcus@heeltoeauto.com
the forums are last on the list to get read after all the other emails
When I talked to him recently there were AS but no OS in stock
either works on our cars
Old 07-17-2007, 04:10 AM
  #162
01tl4tl's Avatar
Also include year model- type, so he knows what you want!
See the constantly improving website with several new jdm whole body bars
** for the TSX only
sorry gen 2 TL I am bummed too
www.heeltoeauto.com
Old 07-17-2007, 07:05 PM
  #163
Laxdog3421's Avatar
Cusco
Hey Marcus, just wonderin if you had any Front strut bars for the 05 TSX in stock. thanks
Old 07-17-2007, 09:29 PM
  #164
01tl4tl's Avatar
I talked to Marcus this morning, you are the 3rd person in 2 days wanting the same part and there are basically none on the country right now.
An order is in enroute from Japan- but it's a slow boat
If you place your order online- when the shipment arrives your bar gets sent out first
If you wait till they come in- they are gone!
Old 07-20-2007, 09:31 AM
  #165
Laxdog3421's Avatar
Thanks a lot marcus, ordered it yesterday. See it in a couple of weeks!!
Old 07-20-2007, 11:30 PM
  #166
mestizoracer310's Avatar
Payment sent for Cusco OS Strut brace for my '02 TL Type S....
Old 07-30-2007, 09:50 PM
  #167
01tl4tl's Avatar
Cusco bars in hand
Talked to Marcus today
He has in his physical possession- a small number of each upper and lower Cusco bar for the TL-CL and TSX
If you want one- grab it quick or wait for another month when the next shipment arrives from Japan
Old 07-31-2007, 08:34 AM
  #168
ABPTSX's Avatar
so if i wanna order the upper strut bar from him i can just order it from his website since he def has it in stock
Old 07-31-2007, 10:10 AM
  #169
01tl4tl's Avatar
Things go fast, as others have found, always call to check in stock supply
1-949-295-1668 gets you Marcus
Old 08-03-2007, 06:45 PM
  #170
Laxdog3421's Avatar
got my strut bar today, am about to install it. Thanks marcus. and thank you tom for the hookup
Old 08-03-2007, 06:49 PM
  #171
Former Sponsor
MrHeeltoe's Avatar
order away guys
Old 08-03-2007, 08:41 PM
  #172
01tl4tl's Avatar
A little education
To help new ziners or those new to suspension mods- here are the basics of the bars and why they work:
When you look under the car in the front, you see 2 frame rails running up from the mid point of the car to the engine area.
The lower Cusco bar fixes these 2 rails together near the lower suspension mounts, thus keeping the lower suspension and steering in line with itself under cornering loads and drastic lane change type manuevers
This substanially reduces the delay in steering response
Looking under the hood you see a bar going across and under the firewall edge.
That ties the body panels to the firewall- keeping them located in relation to each other, but doing very little to keep the upper mounts for the suspension steady.
The Cusco upper bar attaches to the upper strut mount at the body and connects the top of the strut towers as a solid unit
With the 2 bars in place substanially reduce flex from the frame and suspension mount area
Good handling begins with the shocks and steering staying in one place in the space time continuem.
With flex- you get delay
In a situation where you make a sudden lane change- you feel how the car initially rolls one direction while the wheels are pointed the other, or on that long sweeper off camber freeway on-off ramp- you feel the car gets a little unstable or has delayed response and tire squeal to changes in your line thru the corner.
Installing the frame support bars eliminate that delay and give improved feel and feedback - without sacraficing ride quality or causing undue complaints from wife about ride
They really should be the first mod to the suspension- giving your high dollar coilovers and sticky tires a solid platform to do their job
next up: Sway bars and poly bushing for OE sway bars
Old 08-10-2007, 02:44 AM
  #173
01tl4tl's Avatar
Bump
Wifes current description of the Cusco bars from the passenger viewpoint-
No more boat rolling opposite direction feel when entering the freeway and flat when changing lanes and passing-
feels more stable over bumps and rough road patches
These were how much? really?? score !
Old 08-20-2007, 10:36 PM
  #174
08 Civic SI
orgnlprankster7's Avatar
order placed for lower cusco bar! cant wait to get it!
Old 08-22-2007, 11:23 PM
  #175
01tl4tl's Avatar
Its a 10 minute install- less if you have ramps
2 bolts on the subframe go thru the new braces end bracket- tighten ~80 lbs
then hold the swivel adjuster bolt end with an allen wrench, 8mm I think it was
and a regular socket on the other end- tighten- check everything again
Go test by making fast precise lane changes and your favorite cloverleaf on ramp- see how you can move in and out and pick a line at any time- fun
I describe it as feeling flat and the car takes ~a set~ better into the corner
Interested members should PM me for inside info
Old 08-23-2007, 07:40 PM
  #176
08 Civic SI
hey marcus just to let you know i sent you an email because you charged my card twice for the lower brace, once on august 20th and for some reason again on august 21st for the same amount. i would really like to get this corrected asap.
Old 08-26-2007, 05:55 AM
  #177
08 Civic SI
thanks marcus, got the brace yesterday and the money issue was resolved! i love it!
Old 08-31-2007, 06:08 PM
  #178
01tl4tl's Avatar
Amazing how a few pieces of metal can so dramatically change the handling of our car!~
I just got the upper bar installed the other day and its really solid on the bumps and on corner turn in- its very precise and predictable, under 250 for the set is a score in performance value for dollars spent
Old 08-31-2007, 10:31 PM
  #179
JCharged's Avatar
Waiting for mine to come....can't wait.
Old 09-07-2007, 08:37 PM
  #180
01tl4tl's Avatar
Inspire- get your bar installed yet?
Having too much fun with quick lane changes and passing?
Old 09-20-2007, 12:09 AM
  #181
Silvaccordex01's Avatar
Emailed! Your CL link is not working!
Old 09-21-2007, 12:42 PM
  #182
01tl4tl's Avatar
Marcus is working on new system and it many fixes
The CL and TL Cusco bar is the same part- just use TL link to purchase for now~
Old 10-03-2007, 09:59 PM
  #183
Former Sponsor
MrHeeltoe's Avatar
Right-o Thanks Tom.
Old 10-13-2007, 11:46 PM
  #184
01tl4tl's Avatar
Really enjoying the combo of upper and lower bars. My TL was so much tighter after just the lower bar, and now with some miles of having both- it was a great investment!!
Totally wife approved ride improvement on the passenger side, and quick lane change response and even quicker backroads fun for me, all from 2 pieces of metal~
The upper bar has blue mounts with a chrome bar- now I have to polish the intake manifold to match !
Old 11-16-2007, 01:56 PM
  #185
B A N N E D
Wisc Badger's Avatar
got my cusco strut tower for my TSX today
thanks Heeltoe
Old 01-02-2008, 09:11 PM
  #186
Lives On BOOST
krisdlm's Avatar
On my drop I have a 1 finger gap all around. I'm interested in the lower brace but I don't want to change the ride height. If I got the lower brace, would I be hitting the brace on speed bumps, even taking them slow?
Old 01-03-2008, 11:48 AM
  #187
JCharged's Avatar
I scrape my bar over speedbumps regardless if I take them slow. It's not so bad because I only go over speedbumps when I'm entering the neighborhood. So most likely you will scrape but the bar was well worth it for me.
Old 01-05-2008, 05:38 PM
  #188
01tl4tl's Avatar
Funny thing- my wife dragged the bar going nose first down the steep driveway in the street on stock 16s. I dont back the car into the garage anymore and solved that problem.
Now dropped and on 18s, taking speed bumps straight on would be foolish.
Though it no longer handles like a boat, drive it like one crossing a wave or wake, angles of attack will save your cat! If you drag the bar- you would have taken out the cat
I feel the lower bar was the best starting point for my suspension upgrades and was major improvement- noticed by wife on first freeway exit- the car was no longer getting leaned one way then the other. She approved more mods if they would do that
Old 01-05-2008, 05:41 PM
  #189
01tl4tl's Avatar
Your not going to hurt the bar with basic scrapes- totally cosmetic- repaint it someday with rustoleum.
that thing is strong, and bolted to the frame at a major point.
Old 01-09-2008, 07:28 PM
  #190
03 CL-S MT
AC-knowledgedis's Avatar
Talking
Got My Lower Bar, Thanks Marcus. Cant Wait To Install It
Old 01-09-2008, 07:54 PM
  #191
01tl4tl's Avatar
Its just 2 bolts to remove- install bar- insert bolts and tighten! 15 minutes max
Dont recall the exact torque spec, but they were TIGHT,
I used a long extension bar over the regular breaker bar to get them loose.
Old 01-12-2008, 11:03 PM
  #192
asloudasitgets's Avatar
does anyone have a pic of thier lower brace installed on thier tl? this is like a xbrace correct? This has only a 2 point connection? not like a actuall x brace where there are 4 points where you screw bolts in?
also are pople noticing a big difference?
Old 01-13-2008, 05:05 PM
  #193
SOLOCG
telele's Avatar
How much for the CUSCO Type OS Strut Bar For 99-03 TL if you still have them instock PM me the details if you can I'm ready to buy.
Old 01-13-2008, 06:47 PM
  #194
Former Sponsor
MrHeeltoe's Avatar
This is not an X. It is a straight brace, 2 bolts.
People are definitely noticing better chassis rigidity with both the Type-1 and OS braces.
Marcus
Old 01-14-2008, 12:38 AM
  #195
does anyone have it installed on thier tl? can you post a pic of it??
also how much are the tower brace and lower brace?
the upper tower brace will clear the oem hood right?
Old 01-15-2008, 03:38 PM
  #196
01tl4tl's Avatar
I have both upper and lower bars on my 01TL
The lower one gives a noticable improvement and the upper adds to whats there from the factory- making it really strong. All this makes for flat cornering- reduced body roll etc
No issue with hood clearance-sits right next to OE bar
Will gets some pics- but all you can see under the car is a flatish bar running across the car where a frame rail crossmember would be on an old school car- right behind the engine
Totally worth the money- start with just lower if on a budget and you will quickly get the upgrade-mod bug
The lower bar was my first change to the car and my wife was very happy to sit on passenger side more stable entering freeway onramp-turns, now look at my sig,and thats not even giving away the secret mods to possible competitors
Old 01-16-2008, 01:21 AM
  #197
thanks for the response 01tl4tl, also does the lower bar come with instructions? and does all 4 wheels need to be parrallel to eachother? the reason i ask is cause when i go to install it i cant put my car on ramps cause of my front lip and im lowered and the front will not clear any ramps. i have to drive up on some homemade pieces of wood to get even clearance to get underneath my car, but even with that i have barely enought room to do my oil changes. sorry to all the tedious questions.
Old 01-16-2008, 10:23 AM
  #198
Former Sponsor
MrHeeltoe's Avatar
This is really not critical. The bars are made to be able to go on when the car is on the ground. Raising the wheels is more of an issue with adjustable bars, which these are not.
Marcus
Old 01-18-2008, 03:39 PM
  #199
hey marcus i was wondering if my bars shipped yet?
Old 01-19-2008, 01:29 PM
  #200
Quick Reply: Cusco Strut Braces and Lower Subframe Braces *** In Stock!
