Indy Shop Orlando area
I'm looking for a reputable indy shop for the timing belt replacement. This is for a 08 TL-S. Any help/suggestions is appreciated.
There's a shop that works on NSX's in orlando, it's called First Class Automotive. You can read about it here even though it's an old thread:
First Class Automotive---Orlando, FL
LoveMyTL-S (07-03-2017)
You must be new to Kissimmee/St. Cloud area?
If you want a proven Acura/Honda specialist to take care of your TL timing belt, the owner, Nabil, at First Class Automotive is your man.
He did my clutch/PP/flywheel and differential bearing replacement (SMR '03 CL-S6) at the end of 2015 while on an extended vacation to your very area.
The short trip up 15, then up on Goldenrod to Colonial Drive east is not that bad and definitely worth it for a piece of mind. He's right across from the Fashion Square Mall. Or, just take it up to Fountain Acura on 441 before the Florida Mall and pay the dealer price if mileage is a concern/inconvenience, .
Otherwise, believe me, if you just want to get the TB done, then 'roll the dice' and find a local Kissimmee/St. Cloud shop that will 'tell you what you want to hear'.
Good luck!
LoveMyTL-S (09-07-2017)
Good luck!
Not sure what kind of 'big city' exposure you may be coming from; however, there will be 'things' you will have to drive for living in that area. It's just the way it is.
For instance, say you need a particular kind of 'lag bolt' for a project and you take a trip to Handyman Hardware on 10th st. and Mass. Ave; because it's close, figuring it's hardware any Hardware store would carry, right? Just to find they don't carry it.
Next stop, HomeDepot over by Walmart SuperCenter on 13th, surely THEY have to have the 'lag bolt' that you need to complete your special project before the temps. soar above 95 degrees. Oh HELL no!, the hardware guy informs you they USUALLY carry them in stock; however, not today. So you ask him if he can check surrounding store stock to SEE just how far you will have to drive to the next HD, usually Kissimmee, so you can cop what you need, NOPE. The only store that has them is on Narcoossee road (15) just North of 528.
You have one more viable option, because you already called Mackinsons Hardware in Kissimmee and they fail as well, and that's the Ace Hardware on SOBT in Orlando. Thank God! you've finally found them and they have tons.
Hopefully, this won't be a common occurrence for you; however, some stuff you have to drive for because ST. Cloud is just a sleepy, backwater suburb commuter town.
Welcome.
LoveMyTL-S (07-06-2017)
First Class Automotive was incredible. They live up to their name. They had to keep the car an extra day and paid for my rental. Work was top notch and spot on. Very friendly and honest. Was able to talk directly to the mechanic. They even found a stripped stud on the wheel hub and had to drill it out to replace. I'll be using this shop again for sure. They work on everything. Noticed a 60 something Cadillac and a NSX in other work bays. I just can't say enough about this place. Thanks for the recommendation guys. The TL-S feels fantastic, the spirit is back! .
zeta (09-30-2017)
quanaman
01-09-2023 07:33 PM
DerrickW
11-15-2015 05:52 PM
