tein ss coilovers problem need help.
Old Mar 20, 2013 | 12:53 AM
aznandy26's Avatar
I installed my coilovers with factory tophats on them and after i installed them i always hear a big *thump* in the back(when i hit a bump) i tighten the tophats and there is no signs of leaking . i also stiffen the back to see if it work but same problem. I will be posting pics of my top hats so you guys can help me . Another question when driving at a angle going up a driveway one of my back wheel is up in the "air" is that normal?.thanks azine!
Old Mar 20, 2013 | 01:13 AM
aznandy26's Avatar
are my top-hats broken? because i dont remember taking off my stock to be that high.(the round rubber piece)
its giving me a headache on bumps....am i miss pieces to the tophat? does anyone have a diagram of what is needed for the top hat.thanks
Old Mar 21, 2013 | 12:47 AM
aznandy26's Avatar
can anyone local fix the problem? im sure its very easy...i just find out what the problem is.
Old Mar 21, 2013 | 01:51 AM
paperboy42190's Avatar
You see the black washer under the metal one? That black washer is supposed to be UNDER the tophat, you have it at the wrong place. I dunno if that is what's causing your issues but that's what I see wrong with the pic.
Old Mar 21, 2013 | 03:33 AM
is this the same set you are selling in the black market? dont sell them because they are making noises, because i know these will work fine, you just did the install incorrectly.
Old Mar 21, 2013 | 03:35 AM
I alrdy pmed you....you wont find anyone else who will work on your suspension for a better price, and plus I'm only 15 min from you lol
Old Mar 21, 2013 | 05:56 PM
aznandy26's Avatar
yes it is and ya i know i have to of those washers . one came of the tsx top hat. and one came off from mines. there is one under that top hat. but i found out the problem its the spring rate so i took them off it appears i need stiffer springs ment for the tl since its heavier than tsx.
thanks paperboy!
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
nanos
Nov 12, 2015 08:41 PM
