SOLD: 3G TL CF Hood, Ultra Racing, OEM Trunk Tray, Rays Lug Nuts, TE37SL Stickers & More
Category: Accessories
Price: $1
Location (State/Prov/Terr): CO
Item Condition: Used
-Build Thread
https://acurazine.com/forums/showt...7#post14778477
-First For Sale Thread
https://acurazine.com/forums/car-parts-sale-361/3g-tl-rays-volk-ignalss-p2r-flp-tein-carbon-fiber-jnc-am-type-s-aspec-more-901057/
-Second For Sale Thread
https://acurazine.com/forums/car-parts-sale-361/3g-tl-carbon-fiber-jnc-type-r-red-volk-te37-sl-rays-c-mod-grille-ultra-racing-902802/
I have explained what happened to this car and why I am selling these parts. The majority of the parts (including brakes and suspension) were on the car for 5K miles.
DO NOT PM ME ASKING FOR OTHER PARTS NOT LISTED
SOME PARTS IN THE BUILD THREAD HAVE ALREADY BEEN SOLD OR ARE NOT AVAILABLE FOR SALE
First are the descriptions
Pictures are in Post 2
Pricing is in Post 3
Exterior
New Carbon Creations Hood, Wrapped w/ 1 piece of clear bra (top corners are peeling, center has a blemish)
Suspension
H&R Front and Rear Sway Bars
Front Sway Bar 28MM STILL ON THE CAR
Rear Sway Bar 22MM
Moog Endlinks for the Rear sway bar
Ultra Chassis Bracing
Front Subframe Brace powder coated red STILL ON CAR
Side Floor Bars powder coated red
Engine Dress Up
OEM ITR Powder Coated J32A3 Valve Covers (These are one of a Kind)
Matching FLP for 04-08 TL can use with EDFC
Interior
Custom CF Wrapped OEM Interior Parts (one of a kind)
04-06 Cluster Bezel
99-08 TL, 96-04 RL or 01-03 CL Fuel Door release (was gray, can’t tell once installed)
04-08 Steering column (driver side has broken tabs, creates a small gap when installed)
04-06 Fuse Box Lid in engine Bay (has a scratch)
OEM 04-08 TL All Season Trunk Tray
Custom Fit 04-08 TL Sunshade
Engine
04-06 Gerzand PNP Intake Manifold w/ Maxbore TB (TB has machined shaft & Screws)
Comes w/ Both P2R TB & IM gasket
-Stock J32A3 Valve Springs & Retainers
-Stock J32A3 Crank
-Stock J32A3 Cams
-XLR8 Engine Mounts (65A Bushings) STILL ON THE CAR
Skunk 2 Magnetic Drain Plugs
Lights
Luminics Yellow H8 Fog Lights 12V 35W
Lug Nuts
-New Fake Rays Lug nuts in package with key
-Real Rays Lug Nuts & Valve Stems-Very Faded will need to be reanodized
-SSR Lug Nut Adapters- Allows you to use aftermarket lugs (acorn) with stock wheels (ball)
-Custom Volk TE37SL Stickers Matte Black W/ Red letters
Tires
Hankook Ventus RS3 235/40ZR18
All 4 tires have between 5-6 32nd's
All 4 tires have rubbing on the sidewalls
Included is a set of 4 replacement certificates from Discount Tire
Brakes
-Stoptech FR (For Brembo) Cross drilled and Slotted Rotors
-127.40062RL with Silver Anti Corrosion
-Hawk Performance Brake pads- Part # HB530N.570
Other
07-08 TL Passenger Side fog light housing with screws
Custom Cut Clock (fits 9500ci Radar Screen w/out blue cover)
Custom iPad Mini Bezel
Aux Port
iPad mini of your choice
Paint or Plasti Dip
Stretched AC Display
-2007-08 TL Ignition part (the black piece goes behind the immobilizer, this is not sold separately by Honda/Acura, sold only with the complete ignition)
-Base 3G TL Exhaust inserts
-Custom Boomslang harness, allows 04/05 to use 07/08 TL MT ECU (or 07 Base ECU) & Hondata CAN BUS Connector cable. This is for running hondata
-Fully Built Engine
Made 264WHP in Denver on a Mustang Dyno
-STILL IN THE CAR
Parts that are still on the car will be removed when the engine is taken out. I do not currently have a set date for this. Should be within the next month.
Exterior
H&R Rear Sway Bar 22MM
Side Floor Bars powder coated rear
Engine Dress Up
OEM ITR Powder Coated J32A3 Valve Covers (These are one of a Kind) STILL ON CAR
04-06 Cluster Bezel
99-08 TL, 96-04 RL or 01-03 CL Fuel Door release (was originally gray, not visible when installed)
Engine
-Stock J32A3 Crank
-Stock J32A3 Cams
P2R IM Gasket
Maxbore TB & P2R Gasket
Stock J32A3 Valve Train
Stock J32A3 Crank
Stock J32A3 Cams
Lights
Lug Nuts
Tires
Other
-Custom Boomslang Harness & Hondata CAN BUS Connector cable
-Custom iPad Mini Bezel with Aux Port
Options are:
Paint or Plasti Dip
Engine Dress Up
04-06 Cluster Bezel
Engine
-Stock J32A3 Crank
-Stock J32A3 Cams
P2R IM Gasket
Stock J32A3 Crank
Stock J32A3 Cams
Lights
Lug Nuts
Tires
Other
Options are:
Paint or Plasti Dip
^PM'd. As stated the harness is for an 04-05, although the CAN BUS cable will work on 06 without navigation. Here is more info on the adapter harnesses:
http://hondata.com/flashpro_04-06_tl...apter_kit.html
UPDATE 2:
All prices are shipped to the lower 48 unless otherwise stated
Carbon Creations Carbon Fiber Hood $500 SALE PENDING TO SWOOSH
H&R Rear Sway Bar SOLD
Moog Rear Sway Bar Endlinks $45 (ill refund $25 when I get your stock ones back)
Ultra Side Lower Bars $200
Custom ITR Powder Coated Valve Covers & Strut Bar $500
Valve Cover & IM Cover come with New valve cover gaskets & Used IM Cover gasket
Just Valve covers & IM cover $325
Just strut bar $200
04-06 Cluster Bezel SOLD
04-08 Fuel Door release (was originally gray, not visible when installed) SOLD
04-08 Steering column (driver side has broken tabs, creates a small gap when installed) SOLD
04-08 Fuse Box Lid in engine Bay (has a scratch) SOLD
OEM 04-08 TL All Season Trunk Tray $40 picked up, not shipping at this time
Custom Fit 04-08 TL Sunshade $35
IM w/ TB, along w/ P2R TB & IM gaskets $350
IM $200 comes with P2R IM Gasket
TB $150 comes with P2R Gasket
-Stock J32A3 Valve Springs & Retainers $50
-Stock J32A3 Crank $50 picked up, $100 shipped
-Stock J32A3 Cams $100
Skunk 2 Magnetic Drain Plugs SOLD
Luminics H8 Bulbs $20
RS3 Tires $300 Picked up, $425 shipped
New Fake Rays Lug Nuts $80
Real Rays Lug Nuts & Valve Stems- Make an offer (must be above $120)
SSR Lug Nut Adapters SOLD
Custom Volk TE37SL Stickers Matte Black W/ Red letters $25
Rotors & Pads $220
07/08 TL Type S Passenger Fog light housing $25
Custom Clock for 9500CI $40
Custom iPad Mini Bezel (PM me for details, minimum $500)
07/08 Ignition part $10
Base 3G TL Exhaust Inserts $20
Custom Boomslang Harness $275
Hondata CAN BUS Connector cable $50
$300 for both
Just strut bar $200
Rotors & Pads $220
$300 for both
takin care of Business in
Received 4,732 Likes
I would suggest, remove the SOLD parts from the "updates" this way people are only looking at whats available...
also instead of 3 posts (parts-pics-prices)....just post a part its pic and price, onto the next part
Mods please close, I have opened another thread with the remaining parts based on Swoosh's post. The new thread can be found here:
https://acurazine.com/forums/showthr...9#post14876749
nanos
11-12-2015 08:41 PM
asahrts
09-04-2015 05:55 PM
