FS: Pioneer Component Speakers, Atrend Sealed Sub Enclosure
Category: Audio/Video/Electronics
Price: $60
Part Fits (you may select multiples): CL 2G, CL 1G, ILX, ILX HYBRID, MDX 3G, MDX 2G, MDX 1G, NSX 1G, RDX, RL 3G, RL 2G, RL 1G, RSX, TL 4G, TL 3G, TL 2G, TL 1G, TSX 2G, TSX 1G, ZDX, Integra, Legend, Vigor, Other Honda/Acura, CSX, Type-S Model
Location (State/Prov/Terr): OH
Item Condition: Used
Pioneer TS-D1720C Component Speaker System (woofers and crossovers only)
The mid-woofers and crossover networks are in great condition and work perfectly. The woofers worked in the factory door locations with no cutting required. I just had to use a baffle spacer. The tweeters are not included with this system. Here are the specs:
-Speaker Size: 6-3/4" (Oversized 6-1/2")
-Woofer Composition: Dual-Layer IMX Aramid/Basalt Fiber Composite
-Woofer Surround: Butyl Rubber
-Peak Power Handling: 260 watts
-RMS Power Handling: 60 watts
-Sensitivity: 88 dB
-Frequency Response: 30 - 33000 Hz
-Impedance (Per Voice Coil): 4 ohms
-Top-Mount Depth: 2-1/2"
PRICE: $60 SHIPPED!
Atrend 10SQL - 10" Sealed Subwoofer Enclosure
I had my JL 10w3v3 mounted in this box and it sounded awesome. The quality of construction is top notch. I'll throw in some 12 gauge speaker wire for the inside. Here are the specs:
-Single 10" sealed subwoofer enclosure
-SQL series built specifically for extra sound quality
-Dimensions in inches: 13.5" Width x 13.5" Height x 10.5" Top depth x 10.5" Bottom Depth
-Volume per sub: 0.75 cubic feet
-Machine precision cut mounting holes
-3/4" heavy Dusty Construction
-Multi layers of high-grade glue ensure long life and no air leaking out
-High quality spring loaded terminals
-Dado end panels
-Mounting Depth: up to 10.5" (enough depth for any sub on the market)
-Designed, tested, and engineered to work with most of today’s popular woofers. These enclosures are built with the quality additives needed to maximize the performance of any sound system.
PRICE: $25 PLUS SHIPPING!
). Speaking of the box, I am changing the price to $25 + shipping (is that against the rules?). I'm hoping to just sell it locally, but figured I'd post it up on here as well. I get a UPS discount through my work, so I wouldn't expect it to come out being much more than $35 after shipping is factored in. I can provide quotes upon request (just send me your zip).
The Pioneers are boxed up and ready to go for $60 shipped
mod edit-updated
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
