Notices
Parts Search
Keyword:
Category:
Price:
Location (State/Prov/Terr):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Location (State/Prov):
CLOSED: 3G TL: Rays/Volk, Ignalss, P2R, FLP, Tein, Carbon Fiber, JNC, AM Type S, ASpec & MORE
Old Dec 4, 2013 | 06:22 PM
Skier4lyfe303's Avatar
Category: Accessories
Price: $1
Location (State/Prov/Terr): CO
Item Condition: Used
As posted here:
https://acurazine.com/forums/showthr...7#post14778477
I have explained what happened to this car and why I am selling these parts. The majority of the parts (including brakes and suspension) were on the car for 5K miles.
DO NOT PM ME ASKING FOR OTHER PARTS NOT LISTED
SOME PARTS IN THE BUILD THREAD HAVE ALREADY BEEN SOLD OR ARE NOT AVAILABLE FOR SALE
RON A EDIT: HUGE THREAD SO I AM GOING TO ADD, FOR CLARITY AND BECAUSE I ALMOST MISSED THEM:
PICTURES ARE IN POST #2
PRICES ARE IN POST #3
Exterior
TL 07/08 Base & Type S Parts
07/08 Mirrors w/ extended wires painted AM (had a chip, been touched up)
07/08 Type S Rear license plate frame with chrome strip (this has been modified to fit 04’s)
07/08 Type S Rear bumper w/ Lip Painted AM (has some scratches on the lip, w/ hardware)
07/08 Type S Tail Lights & Sidemarkers (New driver light, everything else been clear bra’d)
These are the lighter version (I compared them to another set)
07/08 Type S Front Lip Painted AM (has some scratches comes with all hardware)
07/08 Type S Front Conversion Parts
Front Grille Mesh, Emblem, Hood trim (blemish), screws, pass fog cover
04-06 AM A-Spec Side Skirts (Pass and Driver Rear have scratches)
04-08 Sarona Roof Spoiler Painted AM (2 rolls of Loctite Powerband applied)
-New 07/08 C-Mod Grille Wrapped w/ an 04 OEM Hood Trim in Matte Black Vinyl- NEW
-Comes w/ C-Mod Hood Trim
-Fits BOTH Base and Type S
New Carbon Creations Hood, Wrapped w/ 1 piece of clear bra (top corners are peeling)
Suspension
Tein SS Coilovers w/ Type S Top Hats EDFC (this is a complete setup)
Ingalls Front & Rear Camber Kit
Front ball Joints on stock arms +/- 1.5
Rear Trailing arms
H&R Front and Rear Sway Bars STILL ON CAR
Ultra Chassis Bracing
Front Subframe Brace powder coated red STILL ON CAR
Side Floor Bars powder coated red
Rear subframe brace new in plastic
PCI LCA Spherical bearings in stock LCA’s
-Used in Good Condition Stock LCA Bushings
Engine Dress Up
OEM ITR Powder Coated J32A3 Valve Covers (These are one of a Kind) STILL ON CAR
Matching FLP for 04-08 TL can use with EDFC
Interior
Custom CF Wrapped OEM Interior Parts (one of a kind)
04-06 Cluster Bezel
04-08 Fuel Door release (was originally gray, not visible when installed)
04-08 Steering column (driver side has broken tabs, creates a small gap when installed)
04-06 Steering wheel buttons
04-08 Fuse Box Lid in engine Bay (has a scratch)
04-08 OEM CF Doors, driver vent, pass dash trim, center console rails
OEM Carbon Fiber Rear Vents (has a scratch on the corner)
OEM Trunk Net (for the side where Nav DVD player is, right if looking into trunk)
Engine
04-06 Gerzand PNP Intake Manifold w/ Maxbore TB (TB has machined shaft & Screws)
Comes w/ Both P2R TB & IM gasket
-Stock J32A3 Valve Springs & Retainers
-Stock J32A3 Crank
-Stock J32A3 Cams
-XLR8 Engine Mounts (65A Bushings) STILL ON THE CAR
Lights
04/05 JNC Headlights
-Darkness Theme (which I helped Create)
-Matte Black V2
-Fog Light Bulb Covers
-Gloss Black
-Bezel
-Chrome Strip
-Type S Diffuseres
-Real ZKW Lenses
-Hybrid TL Projectors
THESE WERE REPAIRED BY JNC and will directly ship from him
-Two outside tabs have been repaired, fully functional may be better than OEM
-The pass light tab broken and was repaired (this headlight is clear bra’d)
-The driver light was replaced with a used light
-Only the ZKW Lens and Type S diffuser were reused
-The lens has been refinished by JNC
Luminics Yellow H8 Fog Lights 12V 35W
Luminics Yellow 9006 Fog Lights
New Stock Bulbs that came with Depo Foglights
Wheels (No tires at this time)
TE37 SL 18X9.5 +22
Comes w/ Original boxes, stickers, valve stems, wheel covers
Can include: black center cap adapters, lug nuts below
-Racing Sciences Center Cap Adapters for TE37 SL with 73.1 Bore
-Used Rays Lug Nuts with key- Fake very Close to Real
-New Fake Rays Lug nuts in package with key
-Real Rays Lug Nuts & Valve Stems-Very Faded will need to be reanodized
-SSR Lug Nut Adapters- Allows you to use aftermarket lugs (acorn) with stock wheels (ball)
Brakes
Rear BBK Custom Red Power coat w/ matte black Acura decal
SS Lines, Bracket, Calipers, Pads, Slotted 2 Piece rotors
-Custom Red Powder Coated Brembo’s w/ matte black Acura Decals
-Stoptech FR (For Brembo) Cross drilled and Slotted Rotors
-127.40062RL with Silver Anti Corrosion
-Hawk Performance Brake pads- Part # HB530N.570
Other
Custom Cut Clock (fits 9500ci Radar Screen w/out blue cover)
Custom iPad Mini Bezel
Aux Port
iPad mini of your choice
Paint or Plasti Dip
Stretched AC Display
-2007-08 TL Ignition part (the black piece goes behind the immobilizer, this is not sold separately by Honda/Acura, sold only with the complete ignition)
-SuperComputers Automatic Brake Pedal with hardware (I only have the brake pedal)
-Base 3G TL Exhaust inserts
-Hondata Complete Plug and Play for 04/05 MT with 07 MT Type S ECU
-Either Send me your already cut Switchbalde
-Send me your stock key, I will reblade and recut the switchblade
-Fully Built Engine
Made 264WHP in Denver on a Mustang Dyno
-STILL IN THE CAR
Parts that are still on the car will be removed when the engine is taken out. I do not currently have a set date for this. Should be within the next month or two, some parts will come out sooner (valve covers, rear sway bar).
All Prices include Paypal fees & shipping to the lower 48 states unless stated otherwise
It may take me a few days to ship the larger items.
Pictures and pricing to follow
Old Dec 4, 2013 | 06:23 PM
Exterior
07/08 TL Mirrors Painted AM (had a paint chip, has been touched up)
07/08 Type S Rear License Plate Frame w/ trim- modded to fit 04
07/08 Type S Tail Lights & Sidemarkers(New driver light, everything else been clear bra’d)
07/08 Type S Front Conversion Parts (hood trim has blemish)
07/08 TL Depo Fog Lights (Pass is glass with clear bra, driver is Lexan- not pictured)
04-08 Sarona Roof Spoiler Painted AM (2 rolls of Loctite Powerband Applied)
NEW 07/08 C-Mod Grille Wrapped w/ an 04 OEM Hood Trim in Matte Black Vinyl
-Comes w/ C-Mod Hood Trim (not pictured)
-Fits BOTH 07/08 Base and Type S
-One of the Bolt holders was shaved for CF hood
New Carbon Creations Hood, Wrapped w/ 1 piece of clear bra (top corners are peeling from putting it in the box, has a blemish towards the center)
Suspension
Side Floor Bars powder coated rear
Used Stock LCA Bushings (one is perfect, the other has some cracking)
Engine Dress Up
Interior
04-06 Cluster Bezel
04-08 Fuse Box Lid (has some scratches)
OEM Carbon Fiber Rear Vents (has some scratches)
Engine
-Stock J32A3 Crank
-Stock J32A3 Cams
Lights
-Matte Black V2 and Fog Light Bulb Covers
-Gloss Black Projector Bezel and Chrome Strip
-Type S Diffuseres
-Real ZKW Lenses
-Two outside tabs have been repaired, fully functional, better strength than OEM
-The pass light tab broke and was repaired (this headlight is clear bra’d)
P2R IM Gasket
Stock J32A3 Valve Train
Stock J32A3 Crank
Stock J32A3 Cams
Wheels NO TIRES THEY HAVE BEEN TAKEN OFF
TE37 SL 18X9.5 +22
Comes w/ Original: boxes,stickers, valve stems, wheel covers
Can include: black center cap adapters, used fake red rays lug nuts
Brakes
OTHER
I can include the following
Aux Port
Paint or Plasti Dip
Hondata Complete Plug & Play for 04/05 MT
Old Dec 4, 2013 | 06:24 PM
-07/08 Mirrors Painted AM $350
-07/08 Type S License Plate Frame $130
-07/08 Type S Rear Bumper & Lip $500 NOT SHIPPED
-07/08 Type S Taillights & Sidemarkers $280
-07/08 Type S Front Lip $150 NOT SHIPPED
-07/08 Type S Conversion Parts $130
-07/08 TL Depo Fog Lights (Pass is glass with clear bra, driver is Lexan, I am getting shipped the driver light right now from repair, comes with pass Lexan) $175
04-06 A-Spec Side Skirts $190
04-08 Sarona Roof Spoiler $300
07/08 C-Mod Grille $220
Carbon Creations Carbon Fiber Hood $550 NOT SHIPPED
TEIN SS with EDFC $1250
Ingalls FR & RR camber kit $300
Ultra Side Lower Bars $200
Ultra Rear Subframe Brace $170
PCI in Stock LCA’s $320
Used Stock LCA Bushings $30
04-06 Cluster Bezel $150
04-08 Fuel Door release (was originally gray, not visible when installed) $40
04-08 Steering column (driver side has broken tabs, creates a small gap when installed) $150
04-06 Steering wheel buttons $70
04-08 Fuse Box Lid in engine Bay (has a scratch) $50
04-08 OEM CF Doors, driver vent, pass dash trim, center console rails $400
OEM Carbon Fiber Rear Vents (has a scratch on the corner) $60
OEM Trunk Net $10
Comes w/ Both P2R TB & IM gasket $375
-Stock J32A3 Valve Springs & Retainers $125 OBO
-Stock J32A3 Crank $150 OBO
-Stock J32A3 Cams $150 OBO
JNC Headlights $600
Lumnincs 9600 Bulbs $20
Luminics H8 Bulbs $30
New H8 Bulbs $15
TE37 SL $3000
Racing Sciences Center Cap Adapters $115
Used Fake Rays Lug Nuts $40
New Fake Rays Lug Nuts $80
Real Rays Lug Nuts & Valve Stems Make an offer (must be above $120)
SSR Lug Nut Adapters $30
Rear WilWood BBK $900
Red Brembo’s- $160 plus your stock Brembo’s (you pay $500 and I will refund $340 once I receive your stock brembo’s back, must be in good condition)
Stoptech FR Rotors for Brembo Brakes $170
Hawk Brake Pads $75
Custom Clock for 9500CI $60
Custom iPad Mini Bezel (PM me for details, minimun $500)
07/08 Ignition part $15
SuperComputers Auto Brake Pedal $20
Base 3G TL Exhaust Inserts $20
Hondata- Complete Plug and Play $1400
I do not want to split parts up that have been listed as a set.
Parts that are still on the car will be priced once they are taken off
Old Dec 4, 2013 | 06:42 PM
IIDXholic's Avatar
wow man looks like you put a lot of love in your car. GLWS I would buy some things but currently spending some money repairing the transmission
Old Dec 4, 2013 | 06:58 PM
Ron A's Avatar
Administrator
This is a very well prepared thread, but I put a note in the first post which will be hard to miss, since I almost missed the pictures and prices and I'm sure someone else out there will wonder also and then we'll get a bunch of those worthless without pics smilies.
This is a huge project. I wish you good luck and will help all I can, which isn't really a whole lot due to the work involved.
Once the sale gets going, I suggest you post a list of what's left occasionally. After you make the first post, post the Post # of the preceding post when you post the new list each time and I'll delete the previous update post. Works quite well.
Old Dec 4, 2013 | 07:19 PM
Bankz's Avatar
That's a lot of good parts for sale, GLWS
Old Dec 4, 2013 | 07:30 PM
TL Luver's Avatar
2006 6spd
possibly interested in motor mounts but don't want to pay close to retail lmk... thanks...
also maybe just the type s hood trim... just the hood piece...
possibly the throttle body if your willing to separate...
Old Dec 4, 2013 | 08:53 PM
handsom-hustla's Avatar
Rear bbk, valve covers highly interested!! Pm now..
Old Dec 4, 2013 | 09:15 PM
azeezp13's Avatar
shifting at 7k
Wow so much good stuff here. I see you have the original J32A3 cams for sale.. not sure if you plan on taking apart your motor but I'd be super interested in your Type S Camshafts.
Old Dec 4, 2013 | 11:20 PM
dc2kid's Avatar
do you have the oem carbon fiber trim for the front heater switch and cup holder area? pm me il buy that thanks
Old Dec 4, 2013 | 11:48 PM
paperboy42190's Avatar
damn i wish you had done the type S seat conversion so i can buy some type s seats!
Old Dec 5, 2013 | 02:35 AM
KLim604's Avatar
New Member
This looks Absolutely Amazing!
I'm interested in the Ipad system. If I were to install it into my '04 Base TL, How do you know what temperature its at without the display?
Are you including the radio system?
Best of luck with the sale, Cheers!
Old Dec 5, 2013 | 07:43 AM
Jware93's Avatar
Im interested in the H8 yellow fogs and the rear driver side marker for the type-s if you'll willing to break that up. If not just the h8. And glws. You should do great with this. Make everybody Christmas lol
Old Dec 5, 2013 | 07:54 AM
Tiggerx3's Avatar
Do u got a pic of the cf pieces installed?
Old Dec 5, 2013 | 08:07 AM
Tiggerx3's Avatar
Pmed
Old Dec 5, 2013 | 09:40 AM
EvilVirus's Avatar
Was the ECU bought new or used?
Old Dec 5, 2013 | 09:59 AM
FCVadi's Avatar
damn dude, sorry to hear...
soo many nice things, dont even know what I would want
GLWS... I will be talking to myself to see what to get
Old Dec 5, 2013 | 10:57 AM
Andy11891's Avatar
Will u split lip from bumper? Please let me know. Thanks
Old Dec 5, 2013 | 12:26 PM
cokorote's Avatar
Pm
Old Dec 5, 2013 | 12:44 PM
tommyg55's Avatar
Wish I had monies this would be perfect for me
Old Dec 5, 2013 | 01:13 PM
gr8ness97's Avatar
Quarterlife Crisis....
PM'd you for the rear bumper combo.
Old Dec 5, 2013 | 02:17 PM
tommyg55's Avatar
How much modification to the base bumper is needed to make the from lip fit?
Old Dec 5, 2013 | 04:05 PM
96cd5's Avatar
Pm'd. All this good stuff it's a dream come true. To bad I'm not closer and richer.
Old Dec 5, 2013 | 04:31 PM
jamiengyn's Avatar
Interested in your Ingalls camber kit
Old Dec 6, 2013 | 06:08 AM
von5t3R's Avatar
9th Gear
Pm'd Side Skirt
Old Dec 7, 2013 | 04:21 AM
newkatbie's Avatar
Pm sent.
Old Dec 7, 2013 | 08:43 AM
Grand_hustle17's Avatar
Pre cat deletes?
Old Dec 7, 2013 | 09:16 AM
Morrissey25's Avatar
contemplating future mods
What a nicely organized thread... I am seriously considering the OEM CF Doors, driver vent, pass dash trim, center console rails $400... Time to check the bank statement
Old Dec 7, 2013 | 06:45 PM
swoosh's Avatar
takin care of Business in
great thread with great stuff...
dibs on the front and rear camber kit for a friend....
Old Dec 7, 2013 | 07:56 PM
mikesku's Avatar
Volunteer Firefighter
want the oem cf rear ac vent for sure.... interested in the 07/08 license plate garnish, you said it was modified to fit 04-06 models, but does it still fit on 07/08 models fine?
Posted from Acurazine.com App for Android
Old Dec 7, 2013 | 09:44 PM
Ready to pay for 04-08 OEM CF Doors, driver vent, pass dash trim, center console rails for $400. Will send PM for paypal address.
Old Dec 8, 2013 | 12:22 PM
Paypal sent for 04-08 OEM CF Doors, driver vent, pass dash trim, center console rails for $400... please confirm...
Old Dec 8, 2013 | 01:56 PM
swoosh's Avatar
brother my dibs for the camber kit is off....the guy said he wanted to wait a little bit..
Old Dec 8, 2013 | 03:10 PM
j_u's Avatar
j_u
Pmed for ipad bezel
Old Dec 10, 2013 | 07:01 AM
MR_FRESHH's Avatar
Dedicated Member
Pmd
Old Dec 10, 2013 | 07:20 PM
Brandon Allen's Avatar
2003 Acura CL-S6
Interested in throttle body if you are willing to separate.
Old Dec 10, 2013 | 08:12 PM
NJALLDAY57's Avatar
Grille and hood shipped to 07095
PayPal ready!!!!
Old Dec 13, 2013 | 12:05 PM
ebelp's Avatar
2014 Jeep SRT
Your ad says the CF steering wheel buttons and CF gauge bezel are for 04-06 TL's...does that mean all the buttons illuminate blue?
Old Dec 13, 2013 | 02:40 PM
They are listed as 04-06 because they will only fit 04-06. 07/08 TL's have different cluster bezels and different steering wheels which have different buttons. The buttons illuminate white like the rest of the car, not blue. There are only a few things that light up blue from the factory, such as the lights that point down towards the shifter.
Old Dec 15, 2013 | 10:57 PM
Jz-tls's Avatar
Nhbp-tls
Interested in the tein pm best price shipped to 95953
Originally Posted by Skier4lyfe303
UPDATE 1
-07/08 Type S Rear Bumper & Lip SOLD
-07/08 Type S Front Lip SOLD
04-06 A-Spec Side Skirts DEPOSIT RECEIVED-SALE PENDING
04-08 Sarona Roof Spoiler SOLD
Ingalls FR Camber kit $160
Ingalls RR Camber Kit SOLD
04-08 OEM CF Doors, driver vent, pass dash trim, center console rails SOLD
OEM Trunk Net $10
JNC Headlights $600
New H8 Bulbs $15
TE37 SL $3000
Rear WilWood BBK SOLD
Red Brembo’s- SOLD
Hawk Brake Pads $75
SuperComputers Auto Brake Pedal SOLD
I DO NOT WANT TO SPLIT PARTS UP THAT HAVE BEEN LISTED AS A SET.
PARTS STILL ON THE CAR WILL BE PRICED WHEN THEY ARE REMOVED.
