CLOSED: J32 RWD stuff for sale
Category: Accessories
Price: $0
Part Fits (you may select multiples): CL 2G, CL 1G, MDX 3G, MDX 2G, MDX 1G, RL 3G, RL 2G, RL 1G, TL 4G, TL 3G, TL 2G, TL 1G, Type-S Model
Location (State/Prov/Terr): CA
Item Condition: Used
* Email me at turnbuckle1960@aol.com *
* Buyer pays Shipping and Paypal Fee's. *
* All my stuff is good and low time *
* All images are clickable for enlargement *
* The used motor parts listed below are from the car I stripped down *
** 6 Nearly Brand new, Siemens Deka, 220lbs/hr, 2310cc/min fuel injectors. **
** This is not a re-worked or re-milled injector. **
** Coil Resistance: 2.5 Ohms, low-resistance, peak-and-hold type **
** 14.5mm Viton upper and lower o-rings **
** Fuel compatibility: Flex fuels, oxy. gasoline, Ethanol E100, E85 **
** Dimensions: Body Diameter, 20 mm; O-ring to o-ring, 60.5 mm **
These were used on dyno for several runs and removed, they did not suit my setup. I had them cleaned and pickled afterwards. They have never had Methanol run through them, only GAS. They have been sitting on my shelf for a couple years.
Brand new they sell for $160.00 each on popular websites.
* $600.00 for the 6 of them. *
* You should have a spare or two *
** Nearly New Lithium Pros T1600 battery with Charger. 9.8 lbs. **
** Group 24 size **
** Bought last August, Minimum usage on it and is virtually Brand New. **
** Sell for $650.00 ** They cost 1000.00 brand new.
** For you J Motor Heads. **
** This plate adapts a J motor to accept a chevy style transmission. **
** Was setup for RWD **
** You will need a Ford Style starter **
** All R&D done for you **
** $220.00 **
** 2 Custom Identical Flywheels for the "J" motor. **
** 1 new and 1 used **
** SFI Approved **
** 153 tooth Chevy Ring Gear **
** Over 400.00 in material, don't forget the R&D cost that was additional **
** Used one is $225.00 **
** New one is $275.00 **
You "J" motor guys might wet yourself on this one. It won't be cheap.
** Raw Uncut Camshafts for the J3xa2-a5 motors. **
** design your own grind **
** Cam Journals are oversize for you creative souls who thought about opening up the cam journals in the head to accept higher lobe profile. I wouldn't go much, but you
could get .550 lift +- with the right rocker ratio and cam profile. **
** Already hardened **
** How do I know? I just know. **
** Don't ask where I got them **
** $500.00 **
** 6 Nearly New Denso CBR COP Motorcycle Coils **
** All come in at 1.3 ohm, just like new ones **
** Everyone should have an extra couple on supply **
They work great, I changed my ignition to something different, don't need.
** All 6 for $150.00, $25.00 each ** New cost +- $60.00 each.
** 2005 Brand New RL CamShafts. **
** Everyone knows these are slightly shorter, but I think there is a spacer
that people make to make up the shortness. **
** For some reason, these cams cost the most from all the RL years.
327.00 a peice. Yikes! **
** The marks you see on the Journal are from the Cam Doctor, it measures
the specs. They are nothing to be concerned with. **
** asking $320.00 **
** Brand New CLS Cams **
** $200.00 **
** Used J32a2 Crankshaft **
** I would use it if needed. **
** In excellent shape, no journal damage **
** $150.00 **
** Brand New J35a2 CrankShaft **
** Brand New they cost 450.00 **
** $250.00 **
** Brand New J35a4 CrankShaft **
** This Crank is shorter as we all know **
** This CrankShaft has be Calico Coated **
** New, cost $550.00 **
** $275.00 **
** Brand New J32A2 Intake/Exhaust Valves, Springs, and Retainers **
** Missing one Intake **
** Intake and Exhaust Valves cost $17.00 each new **
** Springs cost $6.30 each new **
** Retainers cost $3.00 each new **
** Close to $550.00 in new parts **
** Sell all for $250.00 **
** Used VSA Modulator **
** Works, I will stand behind it's functionality **
** New these things cost $1300.00+ **
** Sell for $325.00 **
** TCS Valve and Mounting **
** 5 Coil Sticks **
** TCS Valve New costs $560.00+- **
** Sell for $165.00 **
** Coil Sticks New cost $41.00 each **
** Sell for 10.00 each **
** Used Denso Alternator, works, no pully **
** Sell for $40.00 **
** 5 used coil sticks for a J32A2 **
** Old Comptech Supercharger low boost pully **
** Sell for 25.00 **
** 2 Used EGR Valves **
** Sell for $22.00 each **
** Used O2 sensor, the one for the converter, worked when removed. **
** $15.00 **
You will not be able to use these with your stock computer. These do not have the ignitor built in like the stock ones.
I second Richards question of any added advantage of running CBR coils over the stock coils? I know there's no advantage to having a separate ignitor controller so what is it...hotter spark? I'm only asking that because street bike engines run high compression ratios and may need something stronger to ignite the denser charge. Not to mention, more power per cylinder than what our standard motors produce.
You're eventually going to have to share SOME of your deep, unforetold secrets bud.
What ended up happening to the car??? I never did end up seeing a video of it going down the track. PLEEAASSSEEEE post one if you have it! Everyone here needs to see the beast you built to fully appreciate the potential in these parts.
The OP hasn't updated the thread since 10-02-2013, and hasn't logged in since 10-06-2013.
This thread is closed due to lack of updates or bumps by OP.
You can send a PM if you think there's a chance, and the OP can PM me with a link to this thread if he/she wants this opened.
rcs86
Aug 2, 2016 06:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
