SOLD: BC Racing Coilovers for 3G TL/TSX/7th Gen accord!!
Category: Steering & Suspension
Price: $750
Part Fits (you may select multiples): TL 3G, TSX 1G, Other Honda/Acura
Location (State/Prov/Terr): CT
Item Condition: Used
These were originally for a 7th gen Accord which is what the extra Top Hats are off. Currently they are configured to run on a 3G 100% bolt in, no modification necessary. I called BC and they said it would be fine to run these coils on the 3G even though its heavier than the setup they use for the 3G. The springs, which are marked, are 10k Front, 5k Rear. On the 3G setup they are 12/6 but you can ask for a 10/5 setup. Softer rate allows for really comfy ride which is not bumpy or bouncy at all. The shock bodies are also 40mm shorter than the ones used in the TL set so if you wanted to you could really slam the shit out of it. In the photos on the Klutch feature I linked above I had maybe 5" of thread I could go down in the back and 4" in the front, at the least. 32 way adjustable, collars spin completely freely no issues whatsoever no leaks no damage. 15k miles. No shipping to Canada sorry. $750 shipped obo.
Will fit 7th Gen Accord with other top hats, 3G TL and 1G TSX with modifications to the rear I've been told.
These should with slight modification to the rears. Quite a few members have installed 1G TSX coilovers onto 3g TL's. Can't remember his username, but it was a WDP TL-S with silver CE28's that he put his girlfriends old Function/Form coilovers on and they were direct bolt on.
Hopefully this will help you out moose! Keep in mind the spring rates on these are for a 7th gen accord curb weight, which is about the same as the TSX
http://www..com/forums/1st-gen-suspe...overs-tsx.html
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Pham Alvan
Mar 16, 2016 09:17 AM
Sep 13, 2015 01:59 PM
