What is my car doing??
So i get in my car, put it in reverse, and instead of the passenger mirror tilting down like it's supposed to, it tilts left as far as it car until it starts clicking back and forth. When I put it in drive it stopped but was still adjusted as far left as it can go, so i put it in park and hit the my memory setting button to put it back to normal and nothing happened. So I hit the other memory button and nothing happened. So then I hit the memory set button and still nothing happened. My memory buttons just stopped working. Even when I get in the car with my key it still says "Welcome Driver One" but it won't adjust the seats or mirrors when I open the door or anything. I later changed the mirror setting so the driver side mirror would tilt down in reverse and it worked as normal, changed it back so the passenger would tilt down, and it still tilts to the left non stop. WHAT IS MY CAR DOING? Could this be a blown fuse or is my car just crazy? HELP!
Did you ever figure this out? My car is doing the exact same thing. The memory buttons don't even light up. I had some body work done so I'm going to call them and tell them about this. I guess they disconnected the battery because when I picked it up I needed to enter the navi code.
Hope this helps....
Service Bulletin 09-047
March 20, 2010
Applies To:
2007-09 MDX - ALL
2006-08 TL - ALL
Door Mirror Does Not Work Properly
(Supersedes 09-047, dated December 1, 2009, to revise the information marked by the black bars and asterisks)
*REVISION SUMMARY
Under REPAIR PROCEDURE, the illustration in step 2 was changed to make the procedure clearer.*
SYMPTOM
Either or both of the door mirrors have one or more of these symptoms:
^After shifting out of R, the power mirror does not return to its normal position.
^When shifting into R, or adjusting the mirror with its adjusting switch, the mirror chatters or pulses.
^The DPMS doesn't recall one or both of the mirror memory positions.
^The DPMS moves the driver's seat 1 inch, then stops.
PROBABLE CAUSE
Faulty door mirror actuator.
CORRECTIVE ACTION
Replace the door mirror actuator(s).
PARTS INFORMATION
Door Mirror Actuator: P/N 76210-STX-H02
March 20, 2010
Applies To:
2007-09 MDX - ALL
2006-08 TL - ALL
*REVISION SUMMARY
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
PARTS INFORMATION
I called up the shop, the guy said they probably forgot to program it. Said I can take it in on Monday and it should take about 15 mins...we'll see. I did notice some slight sticking before this, so it does seem like the actuators finally gave out.
depends on the vehicles mileage. Contact your dealer to be sure. Acura has a bigger warranty window than Honda. If not, like i said they aren't very exspensive.
