CLOSED: 1G TSX Going back to OEM Sale - Tanabe, Rays, Comptech, lots of parts!
Category: Accessories
Price: $1
Part Fits (you may select multiples): TSX 1G, Other Honda/Acura
Location (State/Prov/Terr): TX
Item Condition: Used
Comptech Exhaust
Willing to trade for your stock exhaust plus $250.
Hondata Heatshield K20Z3, K24A2. K24A4, (06 - 07 Civic SI, TSX, Accord, Element)
Brand new in the original package.
$35 shipped to the lower 48
OEM Acura TSX Service Manual (04 - 07)
Very little signs of wear. The cover is a little worn but all of the pages are good.
$40 shipped to the lower 48.
1G (04 - 08) TSX Comptech Stainless Steel Header
4-2-1 header - Stainless Steel - TIG welded - 50 state legal
Application: 04-08 Acura TSX
Note: I recommend changing the manifold gasket and catalytic converter gasket for a good seal.
Note: Price includes shipping in a fairly large box.
$300 shipped to the lower 48.
Available in 7-10 days. I am waiting on some OEM bolts and gaskets to have the original manifold reinstalled. Picture available once part is removed from car.
1G (04 - 08) TSX Comptech Icebox Cold Air Intake
High volume lid with internal velocity stack, increases airflow to engine, and lower air horn draws cooler air from behind the bumper and eliminates restriction of standard inlet. Includes High flow reusable foam filter element
$100 shipped to the lower 48
Random Technology High Flow Catalytic Converter
This part has a slight dent from a rock. This is a cosmetic defect only and does not impact performance. Professionally installed and removed at Kenny Tran's shop, Jotech Motorsports. The tech there also concurred that the dent is cosmetic. The spiral on the inside of material is NOT compromised. You are responsible for knowing the laws applicable to installation of this equipment. I am not responsible for any CEL's you may encounter. I rarely had a CEL but your application might.
Note: Includes mounting hardware and 2 gaskets. Your application may require new or additional gaskets.
$150 shipped to the lower 48
1G (04-08) TSX Comptech Rear Sport Sway-Bar and Energy Suspension Polyurethane Bushings
Diameter increased from 15mm (stock) to 22mm, helps reduce understeer and improves cornering response, and manufactured from 6150 steel with a silver powder coat finish. This is for the bar and ES bushings only. Reuses factory End-Link locations.
$80 shipped to the lower 48
Comptech Oil Cap
Comptech Battery Tie Down
Two OEM 1G TSX Replacement Fog Light Assemblies
Replacement fog light assemblies and fits years 2004-2005 only.
Genuine Factory Honda fog light assembly. The passenger side is cracked. The driver side is fine.
$80 for both of them shipped to the lower 48
Includes 2 Hoen Xenonmatch H11 fog light bulbs, but no guarantee because they have been in storage for a while.
Neuspeed Front Upper Tie-Bar
Connects the left and right side upper shock mounts in your engine compartment to increase chassis rigidity. The result is improved steering response, especially on cars with high performance wheel & tire packages. Twin tube, solid mount design. Gloss Black Powder Coat. Designed and engineered Camarillo, California. Proudly manufactured in USA.
Genuine Honda JDM Tail Lights
Gives the amber signal indicator instead of red. These will ship in the original Honda boxes. These are not replicas & are authentic JDM Honda.
The pictures shows one tail light, you are purchasing a set; hence, the two Honda boxes.
MTX Thunder 282 2-Channel 280W Amplifier
Specifications
RMS Power 12.5 VDC Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Hi / Low @ 85Hz - Fixed, Defeatable
RCA Output
Full Range Only
2 Ohm Load 90 w x 2
4 Ohm Load 45 w x 2
Bridged 4 Ohm Load 180 w
Dynamic Power 14.4 VDC
2 Ohm Load 140 w x 2
4 Ohm Load 70 w x 2
Bridged 4 Ohm Load 280 w
Dimensions (with ISO Feet)
9.4" x 9.75" x 2.1"
23.9cm x 24.8cm x 5.3cm
TSX custom fiberglass sub enclosure that fits driver side of trunk
Wrapped in material that matches the trunk liner. Comes loaded with a DLS 10" MW110 Magnesium woofer from the Reference line and a grill. Volume is approximately .55 CF sealed. No woofers deeper than about 4.5 - 5" will fit. Corner loading effects give a 6 - 9dB higher output.
$325 shipped to the lower 48.
Note: price includes shipping and this package is large and heavy.
Tanabe Sustec Pro Type II Coilovers Suspension
I had these professionally installed and removed at Kenny Tran's shop, Jotech Motorsports. I was very pleased with the drop and comfortable ride. Front drop is -3/4 to about -3in and Rear drop is -1/4 to about -2.5in
$700 shipped to the lower 48
Note: This price includes shipping of a large and heavy container that weighs about 50 lbs.
The shop put them back in the original box. I can open and take pictures if someone is interested. These also fit some Honda Accord models.
Ingalls Engineering Rear Camber Kit
Adjustment range of -1.5° to +3°
Kit contains two links and 1 kit per side
I am selling 2 kits, meaning enough to do both rear wheels. These are needed to get a good alignment and prevent abnormal tire wear on the rear wheels.
Price for both kits is $80 shipped.
Project KICS R40 Lug Nuts including Locks
Package includes 16 regular lugs, 4 locking lugs, 17mm extension for lugs, and 19mm HEX key for locking lugs. The unique feature (patent pending) of this seven-sided, heptagonal lug nut is that each lug consist of 2 pieces, where the top of the lugs spin freely from the tapered centering ring. This ensures a much tighter and precise hold than traditional lug nuts. It also minimizes the chances of scratching your wheels. Made of lightweight composite materials, these open ended lugs fit on both standard studs as well as extended studs. The entire set weighs just under 2 lbs! Highly recommended for both street and track enthusiasts.
Note: M12 x 1.5mm application: Fits Hondas, Acuras, and most Toyotas, etc.
Note: LUG NUTS ARE MADE WITH TAPERED BOTTOMS SPECIFICALLY FOR AFTERMARKET WHEELS. DO NOT USE THESE TUNER LUGS FOR YOUR FACTORY WHEELS.
Rays G-Game s Wolf 77W 1 Piece wheels set of four
18x7.5 +42 offset. Please check out the pictures. There is some curb damage on 2 of the wheels. Includes 2 extra center caps. The damage to one wheel is very minor. The other is not horrible. Again, see the picture. They are in really good condition. Some thief stole 2 of the center caps, so I have 2 extras after purchasing new ones.
Note: Price includes shipping on 4 large, heavy boxes.
Price is $700 including shipping to the lower 48.
ONE WHEEL CURBAGE
SECOND WHEEL CURBAGE
Set of four Continental Extreme Contact DWS Ultra High Performance All Season Tires
225/40 ZR 18 set of four. One tire is brand new. One tire has about 100 miles on it. Both of these were replaced at Discount Tire with their damage waiver. The other 2 tires have about 15k miles on them. See pictures below.
I would prefer local pickup in the DFW Metroplex.
Local pickup price: $200 for all four tires
Optima Red Top Battery size 51R
This is about 4 years old. However, the guy at Batteries Plus was asking why I was replacing a perfectly good battery after I had them test it. I went back completely OEM including the battery. The Optima Red Top is $40 to anyone willing to come to Carrollton or Plano.
Thanks for looking!
I don't see where the Comptech Battery Tie down has been sold, pending or still available.
I'd like to buy it and call dibs, if possible. I am at work right now and cannot conduct personal buisness here, but I can pay you after work today.
- Michael
- Michael
SOLD
Comptech Oil Cap and Battery Tie Down are gone
Comptech Exhaust Update
I have had a LOT of inquiries about the Comptech Exhaust. Unfortunately, shipping the OEM exhaust is just too expensive. I have not found a local member who wants it, so I am exploring how to replace it locally.
Once I find a reasonable local source, I will update the thread and out right sell the Comptech Exhaust.
Update
Sale Pending - Rays G-Games Wolf Wheels
Update
2004-2003 Acura RL
2008-2003 Acura TL
2008-2004 Acura TSX
2007-2003 Honda Accord
Order 1 kit per side
I am offering 2 kits (one for each side) for $80 shipped to the lower 48.
Updated and added pictures for the Tanabe Coilovers
03tLsNBP
You have a PM and email with your UPS Tracking Number.
SOLD
Ingalls Engineering Camber Kits
Optima Battery
Still for sale and prices INCLUDE shipping to the lower 48:
Tanabe Sustec Pro Type II Coilover Suspension - $700
Hondata Heatshield - $35 back up for sale due to no payment
OEM Acura TSX Service Manual (04 - 07) - $40
Random Technology High Flow Catalytic Converter - Price lowered to $100
(04-08) Comptech Rear Sport Sway-Bar & ES Poly Bushes - $80
Two OEM TSX Replacement Fog Light Assemblies w/Hoen Bulbs - $80
04-05 original Honda JDM Tail Lights - $150
MTX Thunder 282 2-Channel 280W Amplifier - $80
TSX custom fiberglass sub enclosure that fits driver side of trunk - $325
4 Continental Extreme Contact DWS 225/40 ZR 18 - $200 local / $300 shipped
SOLD
Optima Battery
Comptech Header Update and some price lowering on the rest
SOLD
Hondata Heatshield
Comptech Header $300 shipped to the lower 48
maiku has the first shot at the purchase
bolesun1 is in queue second.
What is left and pricing includes shipping to the lower 48:
Tanabe Sustec Pro Type II Coilover Suspension - Price lowered to $650
OEM Acura TSX Service Manual (04 - 07) - Price lowered to $35
Two OEM TSX Replacement Fog Light Assemblies w/Hoen Bulbs - Price lowered to $70
04-05 original Honda JDM Tail Lights - $150 (I cannot believe no one has jumped on this one)
MTX Thunder 282 2-Channel 280W Amplifier - Price lowered to $60
TSX custom fiberglass sub enclosure that fits driver side of trunk - $300
Hondata Heatshield
These are the ONLY items left for sale:
Tanabe Sustec Pro Type II Coilover Suspension - Price lowered to $575 plus actual shipping cost.
Two OEM TSX Replacement Fog Light Assemblies w/Hoen Bulbs (one is cracked but does not leak, the other is fine) - Price lowered to $50 shipped to lower 48
MTX Thunder 282 2-Channel 280W Amplifier includes original manual and install instructions plus speaker level adapter - Price lowered to $50
TSX custom fiberglass sub enclosure that fits driver side of trunk. Includes DLS 10" woofer driver - $275 plus actual shipping cost
4 Continental Extreme Contact DWS 225/40 ZR 18 (1 is brand new, 1 has 500 miles on it, the other 2 have about 12-15k miles on them) - $200 local or $200 plus actual shipping cost.
This is all that is left, someone make me an offer!
Continental Tires LOCAL SALE are gone!
What is left and no reasonable offer will be turned down:
* Tanabe coilovers- $500 + actual shipping
* OEM Fog Light assembly - $50 shipped lower 48
* MTX Thunder 282 Amp - $50 shipped lower 48
* Customer trunk fiberglass sub enclosure INCLUDING 10" driver - $275 + actual shipping
If you do not see it listed above, that means the item sold. I will not respond to PM's and thread posts for items not listed above.
A few of my buyers have left feedback for me. I am an honest seller and I usually ship the same day payment is received.
Thanks for looking.
Thanks for looking.
rseb4agze
May 3, 2016 07:41 AM
