Notices
Parts Search
Keyword:
Category:
Price:
Location (State/Prov/Terr):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Location (State/Prov):
NEX SS coilovers. (98-02AV6, 2G CL/TL)
Old May 14, 2009 | 11:16 AM
jjashaa's Avatar
Avant Garde Wheels
"wth, didn't i just buy this?"
yes i did and little did i know that it'd be impossible for me to loosen the perch without the help of a shop. I don't have time to go to a shop and get this installed so I am gonna resell it.
__________________________________________________ __________________________________________________ _______
Fits the following cars
- Acura TL 99-03
- Acura CL 01-03
- all 6th Gen Accords (98-02); coupe / sedan, i4 / v6
- lowers the car close to 4" in the front and close to 5" in the back so you can basically slam it down to the ground
- the current setup leaves about a 1.5 - 2 finger gap that was setup for winter driving when HE removed it 2 years ago
- the springs and perch adjust independently so you can lower the car without changing the spring rate
- the suspension height and spring rate adjustable not damper adjustable
- tools included
Aprox. 19k miles of daily driving usage.
One spring in the rear needs a replacement because its broken. Replacement spring can be bought by contacting these guys ( http://www.adrwheels.com/brand.php?id=nex )
There are lots of mud/dirt caked onto the springs which do not interfere with usage of the coilovers. There was a lot on the threads but i've taken the time to clean them up as much as I could
Must be installed by a shop as I was able not to loosen the perches by force.
$300 shipped + paypal.
bought $400 + shipping from a member on here.
jjashaa's Avatar
Avant Garde Wheels
from previous owner.
These coilovers are stiff. They are not as stiff as the race version but I'd say they were stiffer than Tein SS at the most stiff damper and lowest height setting. They are not as stiff as the Tein race coilovers (Flex, RA, Mono, etc) but somewhere in between.
When you jam the brakes, the car will not dive down like the OEM suspension nor will raise up when accelerating. There is very little body roll when cornering. You will definitely feel all the bumps on the road and if you are driving through construction zone, you'll need to slow down.
They have to be stiff if you want to avoid scraping over speed bumps. I was riding with no finger gap all around on my Accord and I never scraped my from lip (OEM lip kit). The only time I scraped it was on snow and ice! and it was my wife who damaged the front lip not me!
I've got an NSX and the NEX coils are stiffer than the OEM NSX suspension. Now I have Bilstein and custom springs on my NSX and the NEX is only "slightly" stiffer but almost the same. I've taken a ride on Tein RA and Flex coils on the NSX and they are literally bone jarring! The NEX are not nearly as harsh but definitely stiff.
Old May 15, 2009 | 09:58 AM
dasuddith33's Avatar
Airborne MP 16th Unit
whats the spring rates how these compare to omini= stiff Tien= soft spring rate????
Old May 15, 2009 | 11:02 AM
jjashaa's Avatar
Avant Garde Wheels
i dunno the spring rates..
and i can't compare to omni's or teins cuz i've never had them before....
but i'd say its stiffer than teins but not as stiff as the NEX SR.
Old May 15, 2009 | 11:20 AM
SLushhYYY's Avatar
Keep It Simple in
Sucks about the perches...i wouldve bought them.
Old May 15, 2009 | 12:22 PM
jjashaa's Avatar
Avant Garde Wheels
you could always just take it to a shop.
if you want to pick them up and i can always drop the shipping charges.
Old May 15, 2009 | 02:36 PM
Ron A's Avatar
Administrator
Cleaned up and starting over.
And we found out that TL and CL are very close in weight but TL is a little heavier, and both are heavier than Accords, so maybe all this was worth it.
Old May 15, 2009 | 02:39 PM
spoka's Avatar
have you tried pb blasting the perches?
Old May 15, 2009 | 02:43 PM
jjashaa's Avatar
Avant Garde Wheels
i'm probably gonna have one more go at it tonight/tomorrow afternoon.
will update if i can get anything loose.
Old May 15, 2009 | 04:11 PM
SLushhYYY's Avatar
Keep It Simple in
Haha, no shops for me. Lemme know if you manage to loosen them, and if your still gonna sell them after.
Old May 16, 2009 | 10:37 AM
jjashaa's Avatar
Avant Garde Wheels
yeeeee
Old May 16, 2009 | 01:39 PM
tegkid's Avatar
spaz
damn i missed all the responses after mine
anyway bump for a sweet set of coils.
Old May 16, 2009 | 02:42 PM
Byruns's Avatar
Byruns
I'd probably snag these if it fit a 5th gen. =(
Old May 17, 2009 | 08:44 AM
`ill*tl's Avatar
Josh, just a word of advice.. if you have a table clamp + torque wrench.. you should be able to loosen the perches yourself with a ton of pb blaster sprayed onto the perches while setting the torque wrench to about 100lbs - 120lbs.
Old May 17, 2009 | 10:56 AM
jjashaa's Avatar
Avant Garde Wheels
^ thanks man! i'll try that too.
bump.
Old May 17, 2009 | 12:17 PM
slvrdrgn123's Avatar
Can you post a picture of what needs to be loosened? Thanks.
Old May 17, 2009 | 02:32 PM
jjashaa's Avatar
Avant Garde Wheels
^ whatever i circled needs to be loosened... watever i didn't means they don't need to be loosened or are already loosened.
okay, check first post.
photobucket brush tool ftw. O.o?
Old May 19, 2009 | 11:09 AM
jjashaa's Avatar
Avant Garde Wheels
up!
$250 + paypal
including replacement spring.
Old May 19, 2009 | 11:42 AM
Ygpm
Old May 19, 2009 | 11:48 AM
jjashaa's Avatar
Avant Garde Wheels
replied
Old May 19, 2009 | 06:53 PM
n1njai's Avatar
Aww the replacement came in?!!! DUDE IF he falls threw i'll pick up!!!
Old May 20, 2009 | 02:19 AM
jjashaa's Avatar
Avant Garde Wheels
first come first serve. lol
if you got cash in hand.. come on down.
Old May 20, 2009 | 06:40 AM
`ill*tl's Avatar
Josh, why are you trying to loosen the spring load perches (Top perches on coils)? If your trying to adjust the height of the coils, you use the lower body perches. No need to mess around with the spring load.
Old May 20, 2009 | 10:49 AM
jjashaa's Avatar
Avant Garde Wheels
i can't get the lower ones loose.
isn't that what i said in this thread?? lower body perches? lol.. i only need to loosen one of the top perches to replace the broken spring.
Old May 20, 2009 | 10:54 AM
douggiestyle's Avatar
the price is tempting... how much picked up?
Old May 20, 2009 | 10:56 AM
jjashaa's Avatar
Avant Garde Wheels
$250 picked up.
Old May 21, 2009 | 02:48 AM
jjashaa's Avatar
Avant Garde Wheels
pending to local..
Old May 21, 2009 | 03:11 AM
manafourme's Avatar
Unregistered Member
PMd
Old May 21, 2009 | 10:57 AM
jjashaa's Avatar
Avant Garde Wheels
^ replied
Old May 21, 2009 | 11:42 AM
Juancachorro's Avatar
MR.Juanderful
How much shipping to 10532? Pm ASAP im ready to paypal... Thanks.
Old May 21, 2009 | 11:43 AM
jjashaa's Avatar
Avant Garde Wheels
^ there are people in line.
PM me if you want shipping quote.
Old May 23, 2009 | 11:10 AM
jjashaa's Avatar
Avant Garde Wheels
going down?
bump
Old May 23, 2009 | 04:56 PM
Vietnastee's Avatar
blah
If you want to loosen the perches, you should try installing them on your car so it can hold it tight, then you use of those the coilover wrenches then add a pipe to it so you can use it like a breaker bar. Have someone hold the wrench while you push on the pipe.
Old May 24, 2009 | 02:25 AM
jjashaa's Avatar
Avant Garde Wheels
^ sold.
closed threadddd.
BoricuaTL
Apr 8, 2016 01:08 PM
eastsideride
Oct 15, 2015 04:26 AM
4drviper
Sep 23, 2015 07:42 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
