SOLD: 2001 toyota 4runner sr5 sport harrisburg pa
registered pw
Year: 2001
Make: Toyota
Model: 4Runner
Price: $5500
Mileage: 190000
Color: silver
Location (State/Prov): PA
2. Mileage:Under 190,000
3. Color, Transmission-auto or manual, Navi:Auto
4. Reason for selling: Replaced it with a newer one
5. Location: (Also, please enter the location of the car in the thread title.) harrisburg pa
6. Pictures: (Links are ok here, but please post actual pictures after item 12 so all the text is in one place and easier to see) a few
7. Are you the first owner? If not, how many owners were there (to the best of your knowledge)? 3rd owner
8a. Title is clean/clear/rebuilt/salvage/if other, explain further (select one): clean
8b. Do you have title in hand or it is being held by a lienholder:title in hand
9. VIN (would be nice to have but I can understand that some people do not want to publicly post this):pm me
10. Modifications: hella horn and tacoma rims
11. Service record:tons since 2005
12. If leased, provide details, such as length of lease, payoff amount, etc. owned
It is with a heavy heart to sell our 2001 silver sr5. It currently has 189,500 or so miles. We have owned it for over 12 years and have loved it almost every minute.
I really would like to get $5500 FIRM
We are the 3rd owners.. It had 72k on the clock when we had purchased it.
Everything works as expected and the motor is strong. AS strong as a 3.4 can be.
We have most records or receipts. There are a few i can't find must most are in the folder.
I started to keep records in a notebook in 2010 and besides oil changes and regular stuff, this is what was done;
The timing belt and water pump were done at 129,770 5/6/10
9/11/10 133,404 replaced e-brake cable
11/13/10 flushed brakes replaced fuel filter
6/6/11 139,963 replaced front struts/springs, sway bar links and rear shocks
7/30/11 replaced battery
7/6/12 145,050 recharged ac
10/13/12 flushed coolant
11/26/12 147,015 changed rear diff fluid
1/20/13 148,151 new geolander tires and alignment
1/25/13148,171 new lifetime muffler and tailpipe
2/10/14 153,637 replaced front pads and rotors
6/21/14 155,750 replaced receiver/dryer and had ac recharged
2/7/15 158,697 replaced battery
2/20/15 158,832 replaced lifetime wires
4/19/15 160,426 dropped trans fluid and replaced with 5.5 qts.
8/7/15 166,325 replaced muffler under warranty with a walker
8/12/15 166,581 replaced front pads and rotors with better quality, still on rig
11/14/15 170,537 replaced rear springs and shocks
11/16/15 170,677 alignment, and replaced rear axle seals at toyota dealer, they were leaking
11/23/15 171,077 replaced rear shoes and drums and some hardware
12/2/15 171,604 replaced foglights with hella de
12/5/17 171,743 installed new hella horns
2/19/16 174,109 replaced fuel filter
1/28/16 172,809 repaired front end damage again from hitting deer.
3/1/16 175,290 drained trans fluid & refilled with 1 gallon of valvoline max life atf
4/29/16 178,081 put on new tacoma wheels and tires, recharged ac
8/13/16 180,996 replaced radiator. it blew and overheated this radiator was replaced about 10 years ago. No damage done
12/12/16 183,760 replaced plug wires again under warranty
The alternator, radiator, and plug wires have a lifetime warranty with advance auto. I had purchased the tacoma wheels with toyo tires from someone last year. They are really quiet.
I did have a strawberry milkshake before 2010. It was only driven about 15-20 miles as it was bucking. It was a PITA to fix, but it was done. The radiator was replaced, the coolant was flushed several times and so was the trans fluid.
This was the dog hauler so it is starting to smell a little like one, but it's not that bad. We notice it more when they are in there. The dog hair was cleaned up recently, but it will be dog hair free soon.
We typically get 15-17 mpg and if we aren't doing 80, you can get 19-20.
There is very minimal rust underneath but there is some, you won't be disappointed. the 4wd works well and there aren't any trouble codes. We may have replaced an oxygen sensor sometime as these thing will go through one from time to time. I do have the factory head unit as i haven't decided if the alpine that is in there will be sold with it.
The windshield is original and has a small pucker/circle thing from the po. they had repaired it and we have never had any issues with it.
There aren't any tears or anything that is broken in the interior. We have the original cloth floormats and rubber ones that are in there now.
You will not be disappointed in this rig and the price is pretty firm.
The tires roll nicely and like some others, sometimes it takes a few miles for any vibration go away if it ever does vibrate at all. This happens on all of our vehicles with new tires. It must be the way they make them or it could benefit from a rebalancing. It has been over a year since they have been balanced.
The driver mirror has always had a rattle to it. It's not loose like it wants to fall off, but it rattles a bit and i never really cared to fix it. We did have it painted since the paint was spider webbed. The passenger mirror paint is work for whatever reason.
Just the other day a rock or road debris hit the passenger front door and it richoched(sic) off the passenger rear door flare. The only other ding is on the passenger side front door where a bike rack fell off the wall. It hit around the mirror but i can't photograph it.
There is a roof rack and towing package that we have never used. there are two remotes. This is a weak point of this rig, and it really pisses me off. The range is horrible.
You will not be disappointed and the price is for the most part in line with other rigs. This is a really clean one and you must see it.
