2005 vs. 2006
2005 vs. 2006
This may have been covered over and over. If it has then I apologize, please point me in the right direction. I am looking into buying a TL A-Spec. I am sure you all know this but in 05 the 3.2 was 270 hp and in 06 the 3.2 was 258 hp. I am told that this is because the EPA changed the way that they tested hp and that if I looked at any other car that in those years the hp rating went down for them as well. Then this weekend I drove 2 TLs. One was an 06 and the other was an 05. Call me crazy but I could tell a difference. I liked the 05 better.
Is this all mental? I am told that they drive the exact same but they don't seem like it. I figured I would come to the experts. The guys telling me this are all trying to sell me a car.
Thanks a ton everyone. I really really appreciate it.
I understand that the engine is a 3.2L V6 but in 2004 it had 265 hp. In 2005 it jumped to 270 hp. Then in 2006 it went down to 258 hp.
The guy that had the 2006 that I drove took care of that car. It only had 12,000 miles on it. The 2005 had 40k on it and it was quick. I am wondering if this is just a mental thing with me since I know the hp rating of the earlier years. Do they drive the same?
The difference is in the method used to rate the brake horsepower of the engines. In 2004, they were, in fact, producing 270 HP as advertised based upon the method used at the time. New versions simply use a different method of determining brake horsepower.
FWIW, there is a way to reset the ECUs to default mode, before the TL adapts to the driver, by disconnecting the battery, etc.
G/L!
hey I got a question.. my boy took his to to English town and some guy came up to him and told him that he will re program his whole system in his car for about 500.. they hooked a computer up to his car and started doing something and it took about a half hour and it was suppose to add 15-20 hp which my boy said you feel a big difference and I drove his car and its crazy the power he had.. we RACED from a 30 start jump to 80 and his car beat me about 4 cars. have you ever herd of this?
Yes, but give it a few weeks, and you'll be rolling by an acura dealership where your friend will be standing, and unloading his dead car from a tow truck, ps, no warranty either. Definitely some change in the ECU... I think some here have actually done that but again Vtec is a tricky mofo... https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/emanage-blue-aem-fic-687190/
But I doubt most of us can feel the 15hp difference to call it a crazy change.. But then again, those folks at English town tune those Honday beyound belief...
Yes, but give it a few weeks, and you'll be rolling by an acura dealership where your friend will be standing, and unloading his dead car from a tow truck, ps, no warranty either. Definitely some change in the ECU... I think some here have actually done that but again Vtec is a tricky mofo... https://acurazine.com/forums/showthread.php?t=687190
the change is actually there guys, let grandpa tell you kids
in 2005, the ECU logic let you have 100% power at throttle tip in (launch), the 2006+ TL has had a ECU revision that limits HP and TQ by playing around with A/F, timing, etc, to prevent people from ramming into trees due to torque steer. Though the EPA ratings were changed, the 06+ are .1 seconds slower than the older ones, but its not really noticeable. As far as the used cars, it depends on the old driver, before you test drive, do this:
Turn the car into stall mode
Turn off everything but the car (radio, a/c)
press the gas pedal for about 30 seconds
turn car off
turn car on and go.
This resets the stuff inside the transmission's ECU to factory condition programming.
turn car off
turn car on and go.
turn car off
turn car on and go.
turn car off
turn car on and go.
why would you reset ECU to factory condition programming?
the transmission and ECU adapt to the way you drive, if you drive grandma for about 60 miles, the ECU will only kick down 1 gear when the pedal meets the metal. If you drive like a race car driver, the car will kick down 2-3 gears and put you as close to redline as possible. Resetting the ECU will garuntee that the previous owner's driving style does not affect the test drive, aka feeling slower
turn car off
turn car on and go.
turn car off
turn car on and go.
how do you put your car on stall mode? is it on nutral?
when u press the gas for 30 secs how many rpms should you go up 2?
shift points, yes. Shift firmness, maybe. The TL has a very odd transmission, its shifting qualities resemble those of a manual. at very low RPM's, it feels like a clutch engages quickly like it was dropped to keep the motor from dying. Then at medium revs, 2-3.5K, it shifts like a experienced MT driver would, burn the clutch slightly for a smooth shift. then past 3.5K, its back to shifting harshly and quickly to keep giving power....
I don't think that the question was ever answered. When you are pressing the gas for 35 seconds? How many rpms do you go to? From the last posting about this it almost sounded like the car (engine) was turned off, only the navi and stuff was powered on.
it is basically the computers double checking the shifts and stuff. It takes a bit of delay on the TL's system since it is 5 years old, the new RL and TSX react almost instantly, maybe 100 RPM's.
Are the two TLs manuals? If so, didn't Acura do some computer modifications to help counter the torque steer in the '06 models? Basically didn't the computer reduce power when it sensed torque steer? Could that be what you're sensing between the two model years?
As I understand it
They didn't change the HP in the engine just the way the rate the HP so 05 tl has the same horses as an 06 TL, that being said, they did fix an issue with the front end torque steering. The 05 and 04 models would really pull hard left or right when you romp on the gas, they make that much less of a problem in 06 so maybe that is what you are feeling as a difference. Also several vibration issues were fixed up in 06 from 04 and 05. Go with an 06.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
