Would I need to get these tires stretched?
Old Feb 22, 2018 | 10:57 AM
Caspar's Avatar
I was just given a great deal for the rims Ive been waiting on. Im trying to save atleast $600, so that I wont have to buy new tires. I was told over the phone by a CarID representive that I would need "225/35/20" to fit those 20' Inch rims. Would I need to get these tires stretched to fit these rims? If not, whats the process to get these tires to fit?
Toyo Extensa HP BL 245/35R20 XL95V
https://www.carid.com/lexani-wheels/cyclone-gloss-black-with-machined-accents-235444400.html
Old Feb 22, 2018 | 11:00 AM
it depends on how wide of a wheel you went with.
what are the specs of the wheels...20x? + offset
and is that the specs of the tire YOU want? the 245?
Old Feb 22, 2018 | 11:01 AM
Caspar's Avatar
My bad, the wheels specs are 20x8.5
Old Feb 22, 2018 | 11:02 AM
Caspar's Avatar
Yes, Its from my last vehicle, so I already have these tires.
Old Feb 22, 2018 | 11:11 AM
Caspar's Avatar
I dont know how to edit a post from moblie site version, but this a screenshot of the wheel specs.
Old Feb 22, 2018 | 11:12 AM
the problem is....the overall rolling diameter of these tires are not the same as what came stock on your car.
what that means is your speedometer will be off, therefore causing mileage to be off.
it never pays to buy something because it was cheap and you already had exisiting hardware...it ONLY causes MORE troubles.
sell your 20" tires and buy new 20" tires that fit
Old Feb 22, 2018 | 11:19 AM
Caspar's Avatar
what that means is your speedometer will be off, therefore causing mileage to be off.fit
I see, so Ill just have to purchase new tires. I appercaite your quick response.
Old Feb 22, 2018 | 11:25 AM
^i mean, the tires will fit on the wheels. a tire place will gladly put the tires on the wheel for you.
it will just come with a few drawbacks, namely the speedometer being off, which in turn will affect total mileage on the car.
Old Feb 22, 2018 | 11:29 AM
Caspar's Avatar
it will just come with a few drawbacks, namely the speedometer being off.
Well I dont want any problems like that. To make sure Im understanding you correctly, youre saying the speedometer would say Im going 60mph but In actuality Ill be moving 65mph? ..or something along that sense. Id rather avoid any unwanted issues and spend the extra $600 on new tires with warranties Included.
Old Feb 22, 2018 | 11:32 AM
ILX 17s vs 20"
Old Feb 22, 2018 | 11:34 AM
ilx 18s vs 20"
Old Feb 22, 2018 | 11:42 AM
Caspar's Avatar
So from what Im understanding, It dosent matter what 20' Inch tires I put on. Judging by the picture, Ill be going slower than the odometer reading In my vehicle when I put 20's on the car anyway?
So In that sense, I should just use the tires I already have?
I aplogize for all my noobish questions, as your speaking to someone who Isnt a mechanic.
Old Feb 22, 2018 | 11:50 AM
there are correct ways to do things and there are less correct, more sloppy ways to do things.
I'm showing you the math to get you to lean towards the correct way of putting on wheels and tires.
now, you don't have to follow this "correct" way.
you can do whatever you please.
If you want to keep the tires you already have, go right ahead!
I aint stoppin you, I'm merely pointing you in a general direction. it will be up to you to further research all your options
Old Feb 22, 2018 | 10:48 PM
usdmJON's Avatar
Saying the 20s will throw off the speedo so might as well throw it off more is the incorrect way to look at it.
If your speedo is off by 1 mile after a day then after a year your milage could be off 360 miles. But if your speedo if off by 2 miles after a day then at the end of that year you will be 720 miles off instead of 360.
If you are going to be off you want to be off by as little as possible because over time it adds up.
Take it from a guy that has 3 sets of wheels and 3 sets of tires, only 2 sets of which are mounted. You are better off saving or selling those tires and waiting to get new tires that fit correctly. In the end if shit hits the fan, you have a back of set of tires they may not be ideal but they work in a worst case scenario.
Old Feb 23, 2018 | 08:58 AM
Caspar's Avatar
So theres no way for me to have a technican correct the speedometer after I Install the 20's?
Old Feb 23, 2018 | 09:08 AM
the correct way of calibrating the speedometer is using tires that provide the same rolling diameter as stock.
Old Feb 23, 2018 | 09:15 AM
horseshoez's Avatar
Latent car nut
Correct, I am unaware of any tire which fits 20" rims with an overall diameter of ~25.1" (your OEM tire size). If such tires were made, they would have a sidewall height of only 2.505 inches which is pretty darn thin and will result in all manner of negative performance and extra cost issues for your car.
Some cars do have the ability to have their computers reprogrammed for non-standard tire sizes; I do not know if the ILX has this ability or not.
Ctrogstad
Aug 6, 2012 01:39 PM
**WhItE-aNgEl**
41
May 9, 2012 10:37 AM
chino13com
Mar 5, 2011 10:23 PM
Richbum
Jan 4, 2010 09:04 AM
808nighthawkua6
32
Jan 22, 2008 08:33 PM
