The $200 '04 TL scenario
Old Feb 14, 2018 | 10:17 AM
  #41
whoa, i've never seen a quick release negative battery terminal before
Old Feb 14, 2018 | 11:38 AM
  #42
brotatertot's Avatar
Right!? A total of $6.00 for both positive & negative cables from the salvage yard, and I bet they spent more than that on the cobbled together positive terminal.
Old Feb 16, 2018 | 09:42 AM
  #43
Originally Posted by kamiltl
Lot of work done, lot left. good luck !!! getting better with every step, I am going thru this with my TL too
I like how yours is going, looks like you keep it really clean.
Old Feb 16, 2018 | 12:14 PM
  #44
DesertMistTL's Avatar
great progress
Old Feb 21, 2018 | 10:08 AM
  #45
This has been bugging me way more than it should
Found some things I needed in the junkyard, could have had a lot more if no one trashed everything on/in it after it entered......
So I made good use of this shifty Missouri weather, got them sprayed & put on before the rain.
Old Feb 21, 2018 | 10:17 AM
Interior is all cleaned mostly back in, turns out the steering wheel is in really good condition upon removing the cover.
Old Feb 21, 2018 | 10:19 AM
rockstar143's Avatar
LOOKIN GOOD!
So you took the cover off to check but then left it on?
Old Feb 21, 2018 | 10:23 AM
  #48
horseshoez's Avatar
Latent car nut
Awesome progress.
Next on your shopping list:
Old Feb 21, 2018 | 10:26 AM
  #49
LOOKIN GOOD!
No these were taken before I busted it off, wheel needs to be cleaned pretty bad though.
Old Feb 21, 2018 | 10:35 AM
  #50
Decided to replace some motor mounts, it needs all of them lol
None of them are in one piece, it was fidgeting a lot...
New one in, on to the 2nd one.
Then a buddy stopped by to see the progress, I'm a lil jelly..
Old Feb 21, 2018 | 11:10 AM
  #51
We done always wanted to be professionallls when we was all growed up
The charcoal pipes on this turd were bugging me too, where's the goddamn dremel !!
I'd bet the previous chain-smoking owner's mouth looked the same..
Old Feb 21, 2018 | 11:18 AM
  #52
nice tips!
Old Feb 21, 2018 | 11:19 AM
  #53
Lexus mat on the floor?!?!
gotta get one of those Acura ones
Old Feb 21, 2018 | 11:20 AM
  #54
MyGuti's Avatar
well done! now get on those headlights!
Old Feb 21, 2018 | 11:42 AM
  #55
Thanks! When my brother buffs it he'll do those as well, I'm anxious to see how it turns out.
Old Feb 21, 2018 | 12:17 PM
  #56
horseshoez's Avatar
Latent car nut
I don't have a problem with a Lexus mat on the floor, especially when I forget to put the drip pan under the oil filter when I take it off.
Old Feb 22, 2018 | 01:24 PM
  #57
kamiltl's Avatar
heheheh lexus toyota vs acura honda, that lasts since I remember , like cold war
I used turtle wax headlight restoration set which seems to be good choice, but few times Ive seen people who use mothers metal polish
Amazon Amazon
which looks to give even better results.. I have to try it.
Car went thru great transformation, look for the seats in better condition and interior will be greatly done !
good luck in next modds !
Old Feb 22, 2018 | 01:58 PM
  #58
Nothing you use on the headlights will last unless you get them clear coated with 2k clear from a body shop.
you can probably rattle can but the orange peel of a rattle can will leave you needing to cut and buff which will end up right back at not having protection on them.
Old Feb 23, 2018 | 12:25 PM
  #59
This is true, with all the innovations of this decade, I'd think headlight haze/cloudiness would have been a thing of the past.
Old Feb 23, 2018 | 12:32 PM
  #60
back to glass headlights!
Old Feb 23, 2018 | 12:35 PM
  #61
Blame the damn sun and it's harmful UV rays.
Old Feb 23, 2018 | 02:19 PM
  #62
Another thing I wish wasn't a part of the past lol
Old Feb 23, 2018 | 03:11 PM
  #63
plus, when a woman knew her place, amirite?!
Old Feb 23, 2018 | 03:46 PM
  #64
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Why are you jealous? He spent $50K on a Civic, and you spent $200 on a luxury car.
Old Feb 23, 2018 | 04:19 PM
  #65
Right?! Now it's frowned upon to raise a hand at your dishwasher, times they are a-changin'
That car had more weed in it..
Old Feb 28, 2018 | 10:07 AM
  #66
As you can see nothing was going on during my days off...
...and the weather was decent, so I made good use of my time before it gets cold again. It needed some basic maintenance we have overlooked to fix the bigger issues, so I caught up on that..
I figure my jack handle & vise grips would suffice as body tools for a bit, and make it look just a little bit less shitty than before with no real improvement. My daughter gave me an f- which was well deserved. Until I find a decently priced fender.
My brother dropped by with an extra dead pedal he had acquired a while ago, I trimmed it up a bit on the backside and it fits!
Old Feb 28, 2018 | 10:21 AM
  #67
The F- stands for fender
Old Feb 28, 2018 | 10:22 AM
  #68
Also discovered SPC camber adjusters out back, nice to not see junk stuff.
Found a mud guard & hardware at the junk yard, for the right fender that's busted loose
All buttoned up!
Old Feb 28, 2018 | 10:30 AM
  #69
My motor mount had been delivered, so I ran home to hopefully beat the rain, but wound up working in it. It's on & the car feels wicked-good.
Old Feb 28, 2018 | 01:00 PM
  #70
shit yeah...
fender by dali!
Old Mar 1, 2018 | 07:31 PM
  #71
kamiltl's Avatar
keep going ! good job !
Old Mar 14, 2018 | 09:58 AM
  #72
Through a roundabout way I pieced together a pedal set after acquiring the freebie dead pedal, the main reason for doing this was the hole worn through the original brake pedal pad.
Brian had a bitch of a time drilling out the rivets on the brake pedal.
I tackled the gas pedal..
A little more snazzy than before..
Old Mar 14, 2018 | 10:20 AM
  #73
BreezyTL's Avatar
Looks Great!
Old Mar 14, 2018 | 11:06 AM
  #74
truonghthe's Avatar
looks awesome.
Old Mar 14, 2018 | 02:56 PM
  #75
90foxnotch's Avatar
It's awesome to see some love being put into this car, great work sir- Keep it up
Old Mar 15, 2018 | 08:56 PM
  #76
kamiltl's Avatar
niiiiicccceeee, time to race
Old Apr 11, 2018 | 10:16 AM
  #77
Brian & I are kind of stuck at the moment with this car, the power steering rack mounting bolts have both been busted off at the threads inside the subframe, so it's not the safest idea to be driving it around. While it's been sitting we've fixed the front bumper from the previous owners front impact, causing it to bow out & fit poorly.
Here you can see the driver side bumper mounting tab buckled back
Same on the passenger side, as well as the power steering cooler needing to be straightened.
After
Old Apr 11, 2018 | 11:05 AM
  #78
truonghthe's Avatar
WTF did the previous owner hit? Nice works tho keep up the good work.
Old Apr 11, 2018 | 03:18 PM
  #79
I'm guessing a lot of things lol. Every day is a new day when we'e working on this mess.
Old Apr 11, 2018 | 04:14 PM
  #80
losiglow's Avatar
Autolites
Based on the previous owner of the car, it's likely that a mechanic replaced those plugs. Do they not even look at the shop manual when servicing cars anymore?
Sweet project so far. That's a lot of work. Love your profile pic BTW.
