Acura TL Builder's Ultimate Boost Thread
Old Jan 14, 2018 | 05:38 PM
  #241
OsK's Avatar
OsK
Originally Posted by 04WDPSeDaN
Well... Yes and No.
Specially selected dealerships offered Comptech performance items as an add-on and or can be installed. The dealership I had worked for, did offer this. They still had Comptech parts in their inventory. This was a short period run since most customers weren't dropping 6K for the blower and another 1K for installation. Perhaps out of all the 3rd gen TL's and 1st gen TSX, maybe 2% actually bought their vehicles new with comtech performance items added. True story, my TL was actually bought from a dealership (In NJ) that offered the Comptech performance parts. The original owner was ready to pull the trigger on a blower but never did. I'm friends with the guy on Facebook and he's still shocked I have the car still and it's in flawless condition (plus boosted). He offered to buy it back a few times, but I keep saying No
No No, not today. Lmao.
Seriously though,
You can google when Comptech teamed up with Acura (Some dealerships) and what they offered.
You basically answered my question for me. No factory options. Dealers offered aftermarket Comptech Add-Ons (Intake "Icebox", Exhaust, Supercharger)
So, again, no factory boosted applications.....
K23A1 RDX doesn't count. We're talking about the 3G TL
Old Jan 14, 2018 | 07:28 PM
  #242
Acura TL Builder's Avatar
Oi...
Your absolutely right OsK! Glad you split that hair for us!
I'm about to modify all the RDX 410cc injectors. Ill go get the I/M gasket and remove the I/M to get near the fuel rail.
https://acurazine.com/forums/second-...-tl-cl-716741/
I'm following this thread to a T. Anyone know another thread I can leech info from?
Old Jan 14, 2018 | 07:47 PM
  #243
KN_TL's Avatar
Like I said when I pointed you to this thread, it was only for the connector repinning, it's a 2nd gen thread.
Before you start cutting and grinding on the injectors, try the fit on the rails and runners first. I didn't have to do anything and I don't think I ever read anyone else doing anything except lube up the orings and pop them in.
I still have my RDX injectors, let me find them and I'll post a pic.
Old Jan 14, 2018 | 08:35 PM
  #244
Thank you for the post. I'm currently in my garage with dremel in hand(goggles on) and thought, "Lets check the build thread first".
Old Jan 14, 2018 | 09:58 PM
  #245
Doing research on Intake manifold removal. Can I reuse any of my OEM gaskets when removing plenum and I/M to gain access to the fuel rails?
Old Jan 14, 2018 | 10:29 PM
  #246
gnuts's Avatar
3.5 psi
I've reused all the metal gaskets several times. Just clean them up before reinstall.
Old Jan 14, 2018 | 11:50 PM
  #247
Are the plenum cover gasket and the I/M gaskets both metal?
Old Jan 15, 2018 | 09:19 AM
  #248
rockstar143's Avatar
Old Jan 15, 2018 | 11:50 AM
  #249
Perfect! No need to spend $89 for the set. This makes the injector install easier.
Old Jan 15, 2018 | 12:01 PM
  #250
Installed used OEM ASM type S rear bumper for the quad ATLP.
Throttle body coolant bypass: looped the line. Used another hose to loop the inlet/outlet coolant line to the TB. Used third hose to loop the metal tube connected to the vacuum tube going to the intake.
No extra parts needed to achieve. Only Neednose pliers for clamps. Did this to lower intake temps after s/C install.
Old Jan 15, 2018 | 03:17 PM
  #251
I often wondered if this was a placebo mod...
I had it done on my both my TL's...
Old Jan 15, 2018 | 03:49 PM
  #252
KN_TL's Avatar
Here are some pics for you
Attached Thumbnails Acura TL Builder's Ultimate Boost Thread-id1000.jpg   Acura TL Builder's Ultimate Boost Thread-injector1.jpg   Acura TL Builder's Ultimate Boost Thread-injector2.jpg   Acura TL Builder's Ultimate Boost Thread-injector3.jpg
Old Jan 15, 2018 | 03:54 PM
  #253
It may be, but if it gets my intake temps a couple degrees cooler after boostering then I'm happy for it.
Old Jan 15, 2018 | 03:55 PM
  #254
Definitely...
in FL summer heatsoak was legit on the TL.
I did the cooling mod thing too and it helped.
Old Jan 15, 2018 | 03:56 PM
  #255
Those look plug and play to me! Thank you for he measurements. I'll see if they coincide with the rdx today
Old Jan 15, 2018 | 03:59 PM
  #256
does he have bigger one than you?
Old Jan 15, 2018 | 06:24 PM
  #257
We talking about penis or injectors? ...or both
Old Jan 15, 2018 | 08:32 PM
  #258
Hey fellas, what are the torque specs for plenum and I/M manifold?
I'm reading to tighten the I/M to 16 lbs and the plenum to 9lbs. is this correct?
Old Jan 15, 2018 | 08:42 PM
  #259
KN_TL's Avatar
U need to get the factory service manual......
Attached Thumbnails Acura TL Builder's Ultimate Boost Thread-2018-01-15_21-40-29.jpg
Old Jan 15, 2018 | 08:43 PM
  #260
Thank you!
My torque wrench starts at 10lbs. The plenum spec is 8.8lbs. Would there be an adverse affect to overtorqueing to 10lbs?
I just remembered I have the haines manual.. Going to study that so I'm not caught with my pants down on injector D-Day.
Old Jan 16, 2018 | 06:31 AM
  #261
KN_TL's Avatar
Those cover bolts are pretty soft....I broke a couple my first time then invested in torque wrenches and spare bolts.
Old Jan 16, 2018 | 06:39 AM
  #262
Anything under 10 I hand tighten, palming a 1/4" ratchet.
always Penis.
Old Jan 16, 2018 | 04:27 PM
  #263
Joecop67's Avatar
Always penis? Man I'm too old for this forum, I have no idea what that means.
Old Jan 16, 2018 | 09:30 PM
  #264
It finally came!(skeet)
How are the fresh from RV6 HFPC
Wanted to install these this weekend, but need ceramic coating.
Just to make it clear. We cannot heat wrap our HFPC fellas.
Old Jan 16, 2018 | 10:40 PM
  #265
thisaznboi88's Avatar
Send it to swinetech. They have really good coating
Old Jan 16, 2018 | 10:52 PM
  #266
dopeboy1's Avatar
The inconvenient truth
Why does that paper with installation tips repeatedly say precat deletes when you have HFPCs? Is it possible they sent you the wrong paper? The paper that came with mine says HFPCs and nowhere mentions pcd. It also nowhere mentions anything about wrapping them with exhaust wrap.
I also don't see why they cant be wrapped if they can be ceramic coated....
Old Jan 16, 2018 | 11:09 PM
  #267
There are a few places locally I'm getting quotes on. Don't want to ship them out after they just came in.
Old Jan 16, 2018 | 11:55 PM
  #268
White Lightning Exhaust Coatings | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings
this is the real good stuff.
Old Jan 17, 2018 | 07:17 AM
  #269
Your right, it is. Ill see if anyone can match the quality locally. If not, this is a good option and price point.
Old Jan 24, 2018 | 11:25 AM
  #270
6spd-GERCO's Avatar
In for updates
Old Jan 24, 2018 | 11:15 PM
  #271
I've completed the battery relocation to the trunk.
RV6 HFPCs should be finished getting black ceramic coating in the next five days.
Injectors go in this Saturday. HFPC on Sunday, if I get them back in time.
Purchased OEM side skirts today on eBay for $220 shipped, completing the type-S kit. Wish ATLP still offered single tip exhausts.
Old Jan 27, 2018 | 11:02 PM
  #272
Injector install
Old Jan 27, 2018 | 11:04 PM
  #273
How was this possible?
#10%er MPG
Old Jan 28, 2018 | 12:04 AM
  #274
lol duty cycle like 40% on those on a N.A car
Old Jan 28, 2018 | 12:23 AM
  #275
Does the ECU use the duty cycle numbers to read gauge the MPG?
I found the that my engine bay temps are considerably lower than they were before installing the injectors and getting a new tune from DomGSR.
RV6 HFPC are ready for pick up this Monday. Next Sunday is the install day.
Old Jan 28, 2018 | 12:36 AM
  #276
that would be my guess since duty cycle is dictated by injector pulse width. and that is dictated by load and rpm
Old Jan 28, 2018 | 05:17 PM
  #277
Anyone heard of this guys shop?
Old Jan 28, 2018 | 05:21 PM
  #278
I tried to make it as clean of an install as possible.
It took me 14 hours!!
Making way for the Supercharger.
Old Jan 28, 2018 | 06:53 PM
  #279
How did the reseal process go for the S/C'er unit? What oil did you settle on?
Old Jan 28, 2018 | 08:12 PM
  #280
I plan to reseal the S/C next weekend. The loctite you suggested is waiting in the garage.
Ordered 10qt of Redline High Temp ATF and x2 bottles AC Delco GM Supercharger oil today.
I'm picking up my HFPCs from the ceramic coating shop tomorrow, will post pics.
