Can't break transmission fill plug open...
Old 11-13-2017, 08:02 PM
ACURAte_tiTLe's Avatar
Unfortunately my first post here had to be in the Problems and Fixes section... I just bought my 6 speed TL a month ago with 100k miles and thought I'd change the tranny fluid because the shifter is notchy in 3rd gear when it's cold and it still has the original fluid in it. Just like an oil change, right?!? Soaked the fill plug in PB blaster and tried breaking it loose with a standard 3/8 ratchet and managed to snap the head off. My only other option is a 1/2 inch air impact, so I tried that and had to stop because I didn't want to round off the plug. I mean it makes sense since they're loctited from the factory and over 10 years of rust doesn't help, but cmon even an impact won't get it off? Any last tricks I can try before taking it to a transmission shop and let them deal with it? Yes I made sure the impact was going the right direction
Old 11-14-2017, 05:56 AM
frankjnjr's Avatar
FWIW: For some unknown reason, the filler bolt on my 2003 TLS seems to (self tighten). When i service the transmission, I only snug-up the filler bolt, but the next time i service it, it seems like the filler bolt has been torqued to 100 ft. lbs. I have found, that using a 1/2" drive breaker bar, along with an appropriate extension, a 12" cheater pipe, and 6 point socket, makes it much easier to remove the bolt. When using a 3/8" set-up drive, it always feels like something is going to break.
The following 3 users liked this post by frankjnjr:
ACURAte_tiTLe (11-15-2017), justnspace (11-14-2017), Waffeey (11-15-2017)
Old 11-14-2017, 02:19 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
I see @justnspace has been here but didn't share his own personal experiences
Any reason why cuhhh?
OP.. get the trans up to temp.
Get a six point impact socket on it.
Then use impact extensions and an 3 foot breaker bar
Tighten first, then back it out with consistent pressure until it loosens
Definitely don't round off the plug
Old 11-14-2017, 02:22 PM
Majofo's Avatar
Or break the transmission case... aye Justn
Old 11-14-2017, 02:29 PM
LOL!
i helped break my friends transmission case by trying to get the fill bolt.
he sold the car, right after that and bought a G8 GXP
The following 2 users liked this post by justnspace:
Majofo (11-14-2017), Waffeey (11-15-2017)
Old 11-14-2017, 02:36 PM
Received 8,661 Likes on 6,684 Posts
LOL!
is he going to let you work on that one too?
Old 11-14-2017, 02:41 PM
maybe I can try my magic on OP's car.
Old 11-14-2017, 02:42 PM
Majofo's Avatar
There you go OP
Old 11-15-2017, 07:50 PM
You sir are awesome. The 3/8 drive setup was the problem ... Picked up a cheap 1/2 wobble extension from harbor freight and that was enough to pop it open with a breaker bar. Besides wacking myself in the face with the breaker bar when it finally broke loose, the rest went well. Transmission shifts like BUTTER now
Old 11-15-2017, 10:14 PM
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
6-point socket? What am I missing here? The fill bolt is just a 1/2" square inset, correct?
That's OK, you're in good company with Crabman. He has a chest hickey to go along with your newly acquired face hickey
And yes, the bolt has always been a bit of a pain to remove. As you learned, 1/2" all the way!! (P.S. that must be some weak ass compressor you're using with that impact gun....)....
Old 11-15-2017, 11:13 PM
thisaznboi88's Avatar
Fill bolt is a 6poimt on some car and a 1/2 or 3/8 on other cars
Old 11-15-2017, 11:23 PM
Majofo's Avatar
wut?
Majofo's Avatar
fill bolt... fill bolt.
Old 11-16-2017, 01:27 AM
Old 11-16-2017, 01:36 AM
Majofo's Avatar
looks like someone mixed up the fill and drain bolt on that one.
interdasting.
Old 11-16-2017, 01:38 AM
Majofo's Avatar
wait a minute.. isn't that a manuela on the bottom?
Old 11-16-2017, 01:42 AM
Majofo's Avatar
Yep.. a manny on a 2009 Accord..
I'm not saying the fill bolt might not be a 1/2 - 3/8" bolt.
But of the half dozen different vehicles I've worked on with a J3x..
I've never seen one.
Old 11-16-2017, 01:46 AM
Majofo's Avatar
oh.. another #protip
worst case (not worst case like you break the case of the transmission trying to pop the bolt, but like worst case you can't pop the bolt)
You can always fill through the dipstick
It's slow but it'll go.
Old 11-16-2017, 07:29 AM
MT doesn't have a dipstick, but I suppose you could find a way to fill it through the check bolt if you really hated yourself...
Ahmed Nomaw
07-20-2017 04:06 PM
rp_guy
07-16-2017 07:33 AM
Si_jeff
01-06-2017 10:30 PM
Anicra
4G TL Problems & Fixes
10-06-2016 01:44 PM
rets
01-01-2013 09:50 PM
Quick Reply: Can't break transmission fill plug open...
