Chevrolet: Corvette News
Old Oct 12, 2017 | 09:40 AM
  #2761
Mighty awkward & non-Vette looking, but typical for a test mule.
So, as I understand it:
Corvette/Z06 = FR
ZR1 = MR
Old Oct 12, 2017 | 11:44 AM
  #2762
srika's Avatar
Moderator Alumnus
Typical GM Corvette fashion, rip off a bunch of Italian design directions (mostly Ferrari) and throw them into the new Corvette. It's promising they are comparing it to the 911 Turbo S, should be smoking fast.
Old Oct 12, 2017 | 12:22 PM
  #2763
iforyou's Avatar
You'll Never Walk Alone
I think the current Corvette is pretty much as fast as the 911 Turbo S though. The one big advantage the 911 Turbo S has is its traction thanks to the RR layout and AWD system. This allows the 911 to do 0-60mph in like 2.6s and 1/4 mile under 11s. But the current gen Z06 has a similar, if not better 1/4 mile trap speed than the 911 turbo s, meaning from a roll, they are pretty much dead even.
And on a track, I suspect the Corvette is faster.
Old Oct 12, 2017 | 12:28 PM
  #2764
srika's Avatar
Moderator Alumnus
The 2017 911 Turbo S is at 10.5 @ 131. Z06 is usually between 124-127. Close? Arguable.
Also though, the numbers for the new Corvette would be the "base" (or Z51) model, it would not be the Z06 or ZR1. The Z51 does 12.2 @ 118 or so which is not even close to the Turbo S.
Old Oct 12, 2017 | 12:37 PM
  #2765
iforyou's Avatar
I've seen 124-131mph for the 911 turbo S. I've seen 126-127 for the Z06. For sure, that's arguably comparable.
May be I missed the earlier discussion, but why do we compare a base Corvette to a 911 Turbo S? Wouldn't a base Corvette be compared to a base 911?
From what I'm reading, the rumour is saying that the regular C8 Vette will be FR, but the ZR1 version will be MR.
Old Oct 12, 2017 | 01:25 PM
  #2766
This is what I have seen as well, per my above post.
Old Oct 12, 2017 | 02:51 PM
  #2767
srika's Avatar
Moderator Alumnus
ok if its a given that the ZR1 is going to be the MR, well then I think the Turbo S is a worthy comparison.
Old Oct 12, 2017 | 05:56 PM
  #2768
iforyou's Avatar
GM, specifically Chevy, is really good at making fast sports cars. Certain trims of the Camaro and Corvette are really fast track cars. Just look at the C/D lightning laps from last year and this year. I'd imagine the C8 would continue this trend.
Old Oct 12, 2017 | 09:15 PM
  #2769
Steven Bell's Avatar
The mid-engine at the McDonald's drive-thru.
Old Oct 19, 2017 | 03:21 PM
  #2770
nanxun's Avatar
Love these vids on the Cars Evolution channel....
Old Nov 12, 2017 | 12:17 PM
  #2771
srika's Avatar
Moderator Alumnus
welp guess the ZR1 is not the MR.
2019 Chevrolet Corvette ZR1: Here It Is, In All its 755-HP Glory
The King of the Hill is back.
By Máté Petrány
Nov 12, 2017
The pack leader is finally here, launched in Sebring Orange to make sure you notice all the significant upgrades that no doubt make it the fastest street car GM has ever made.
Not all Corvette generations spawn a ZR1, but the previous one from 2009 left quite an impression with its 638 horsepower LS9. Eight years wiser, the Corvette team used all they had to create a worthy successor. Looking at all the figures, the C7 ZR1 shouldn't disappoint.
It all start with its big, bulging exposed carbon-fiber hood. Apparently, GM put a lot of effort into coming up with the C6 ZR1's transparent hood window, only to find that some customers thought it looked like a cheap piece of plastic. So this time around, they went all in.
The trick is that one of those two pieces is the actual carbon fiber intercooler cover, meaning that the engine is out in the open through what GM calls a "halo" hood. The carbon weave is perfectly aligned with the body panel, but the intercooler cover will move around when the engine is running, since it's part of the drivetrain. Now that's just bonkers.
What's more, the two openings in front of the cover extrude hot air from the engine bay, which is much needed, since the ZR1 packs eight very angry cylinders.
Despite all the wishful thinking, the new LT5 doesn't come with a DOHC head like the Lotus-enhanced original did in the nineties. Instead, the ZR1's new pushrod V8 features a 52 percent larger supercharger than the Z06's LT4, as well as GM’s first dual-injection system to get 755 horsepower and 715 lb-ft of torque out of high octane and dense air.
This dry sump motor also features GM's largest ever throttle bodies at 95mm, as well as an upgraded crankshaft with a wider key slot. What's even cooler is that the whole thing is connected to a patent-pending active exhaust, which should give you a wider range of nasty noises, promising Motörhead-levels of decibels in race mode. And since they don't expect to sell more than 3000 ZR1s a year, all of the LT5s will be hand-built in Bowling Green.
To keep all that power on the asphalt, Chevrolet came up with an equally serious aero package in a rolling wind tunnel, with both versions of the ZR1's available rear wings bolted to the chassis itself. Not unlike on Corvette Racing's C7.R.
Chevy claims that after benchmarking a few sports cars with active wings, they came to the conclusion that those serve more of an aesthetic purpose than anything else, creating the least drag and the most downforce at their fully extended form. That, and the fact that an active wing would have been a packaging nightmare on the C7 led to a pair of fixed wings, as well as a clever front underwing designed to balance out the additional rear downforce without making the car unusable on the street.
While both wings are bolted to the chassis, only the taller one is said to effect cargo space considerably. Which is fair, because in exchange, it gives the ZR1 an estimated 950 lbs. of downforce near its top speed.
Said top speed is "somewhere above" 210 miles per hour, as long as you stick to the standard wing.
Talking of sticks, there's a seven-speed manual with rev-matching that's "more robust for track duty," but for the first time ever, the ZR1 will also be available with GM's 8-speed automatic. The 10-speed simply didn't fit, as it was never intended for the C7 platform.
If you must know, the final drive ratios are 3.42 (manual) and 2.41 (automatic).
Dual-injection means the LT5 uses primary direct injection as well as supplemental port injection, to get 755 horsepower out of 6.2 liters with the help of that gigantic supercharger. And those "conservatively estimated" 755 horses have to motivate 3560 lbs. of Corvette.
Huge forces demand lots of rubber, so the ZR1 comes with 355 wide rear tires, as well as half an inch wider front wheels with an open design for improved cooling. The brakes are equally monstrous two-piece carbon ceramic rotors, with fixed six-piston aluminum calipers at the front.
Remember the Z06's overheating issues? GM does too.
Not only does the ZR1 have a more-efficient intercooler system with a heat extractor hole on its hood, but it also packs four new radiators, bringing the number of heat-exchangers to 13. A Bugatti Veyron has 10.
While this car contains the most carbon fiber GM has ever put in a vehicle, the extra fluids, coolers and the wing adds more weight than the composites can shred, and that's why the ZR1 is slightly heavier at 3560 lbs.
Suspension-wise, it has a double wishbone setup all around, with cast aluminum upper and lower control arms, transverse-mounted composite springs and Magnetic Ride Control standard. The base package also includes a performance-focused traction control system, the electronic differential, and that super loud exhaust.
In terms of design, the ZR1 comes with a completely new front that's basically one giant air intake, as well as the wider body, and lots of optional exposed carbon bits, including the hood, the quarter panel inserts, the side rockers, the front splitter, the rear wing and the removable top.
The brake calipers can be black, gray, yellow or red, while due to popular demand, Chevy kept the chrome wheel option. Luckily, younger buyers can choose from three more tasteful wheel finishes.
Going back to the wings, the standard one generates up to 70 percent more downforce than the Z06’s base aero package, while the available two-way-adjustable high wing grants about 60 percent more than the Z06 with the available Z07 Performance Package.
That's 950 lbs pushing down the back, and to complement that, the ZTK Performance Package also includes a front splitter with carbon-fiber end caps, Michelin Pilot Sport Cup 2 tires (instead of the run-flat Super Sports), and specific chassis and Magnetic Ride Control tuning for greater cornering speeds. Plus the bucket seats, naturally.
Of course if you prefer your ZR1 somewhat milder, you can spec it with heated and vented Napa leather-trimmed seats, and a Bose audio system. Yet options such as the carbon fiber-rimmed steering wheel and the Performance Data Recorder feel more appropriate.
Just to tease us further before the ZR1 goes on sale next spring, the launch car features the Sebring Orange Design Package, which gives you this exterior color, as well as orange brake calipers, rocker and splitter accent stripes, seat belts and interior stitching, with the competition seats and a bronze aluminum interior trim.
It's pretty, and pretty much everything you could want from a Corvette. The Dodge Viper ACR might be dead, but there seems to be a new King of the Hill.
Get your checkbooks ready for next spring, with prices staying "at the usual ZR1 levels". More to come soon!
Old Nov 12, 2017 | 12:34 PM
  #2772
srika's Avatar
Moderator Alumnus
I don't think the front end redesigns are the best fit and look for this car. The rear, aside from the wing, looks sorely empty. Where is the valance panel and skirts and other such rear-end accoutrements that would be aiding performance as well as looks on a car like this? Good news for the aftermarket tuners though, they will have a field day with this.
Old Nov 12, 2017 | 12:35 PM
  #2773
srika's Avatar
Moderator Alumnus
Counterpoint: I suppose they needed all that front end venting to keep the engine cool. It could - and most likely will - grow on me.
Old Nov 12, 2017 | 12:40 PM
  #2774
Rick_TL-S's Avatar
That's basically my thoughts. It's easy to tell when the C7 was being designed, that the creator didn't build the car to have this much aero work built into it; the spoiler looks out of place without additional rear aero work, and the front air ducts give the car this appearance of someone grabbing the mouth and tugging.
There's no doubt it all works & does what it's supposed to. But, I think there could be more done to accomplish its goals whilst making it aesthetically pleasing. I think the ZL1 1LE suffers a bit of this as well, so it may be down to the designers & engineers GM has. I think Ferrari is at the top of the game in regards to keeping their aero work in line with the car's original sculpture.
Old Nov 12, 2017 | 01:59 PM
  #2775
Costco's Avatar
I'm with you guys as well. The car just looks overdone, and not in a good way. Surprising that this came from the factory like that.
Old Nov 12, 2017 | 05:55 PM
  #2776
srika's Avatar
Moderator Alumnus
easier to swallow in orange.... maybe the color needs to compliment the wild
https://finance.yahoo.com/news/2019-...170000297.html
In addition to the extra displacement from the blower, the LT5 makes use of both direct and port fuel injection. Not only should this help fuel flow, it should slow the carbon buildup that occurs with direct-injected engines. It uses a more efficient intercooler, too, helping prevent the heat-soak issues that plagued the Z06. The supercharger and intercooler are so large that the hood is open in the middle, raising a big middle finger to pedestrian crash standards. It sits three inches higher than the standard car. The whole front end has been honed and shaped to feed air into the engine and driveline. Four new radiators bring the total to 13.
Old Nov 12, 2017 | 06:31 PM
  #2777
srika's Avatar
Moderator Alumnus
oh also, in case you missed it, it's also being offered as a convertible.
Old Nov 12, 2017 | 08:41 PM
  #2778
Rick_TL-S's Avatar
The convertible with that large wing will look tacky as hell.
Old Nov 13, 2017 | 12:13 AM
  #2779
srika's Avatar
Moderator Alumnus
this orange is looking better and better....
Old Nov 13, 2017 | 06:40 AM
  #2780
TacoBello's Avatar
The front bumper really doesn't suit the car. Looks too lambo-ish, or Civic Si-ish
Old Nov 13, 2017 | 09:13 AM
  #2781
Convertible, and with an auto-box
That said, I think it looks pretty good.
Old Nov 13, 2017 | 10:02 AM
  #2782
srika's Avatar
Moderator Alumnus
fuggin' great. Now I'll never be able to not think of a Civic Si when I look at the ZR1. Thanks.
Old Nov 13, 2017 | 01:08 PM
  #2783
srika's Avatar
Moderator Alumnus
Old Nov 13, 2017 | 01:10 PM
  #2784
srika's Avatar
Moderator Alumnus
Old Nov 13, 2017 | 01:11 PM
  #2785
srika's Avatar
Moderator Alumnus
from MT
The car goes on sale this spring, and GM expects to make 2,000-3,000 of them at the plant in Bowling Green, Kentucky, but production will not be limited.
Pricing has not been announced but could easily exceed $130,000. The 2009 ZR1 started at $105,000; a carbon fiber package alone added $15,000. The 2018 base Stingray coupe starts at $56,490 and the Z06 starts at $80,490. Juechter said the ZR1 won’t be double the price of the Stingray.
Old Nov 13, 2017 | 03:15 PM
  #2786
srika's Avatar
Moderator Alumnus
it's gonna have 2 wing options - the crazy one and a smaller one - I really wonder how that small one is gonna be.
Old Nov 13, 2017 | 04:30 PM
  #2787
RPhilMan1's Avatar
2024 Honda Civic Type R
Wrong transmission.
Oh thank goodness the MT is also offered.
I like how menacing the dark gray looks.
Old Nov 13, 2017 | 04:59 PM
  #2788
Costco's Avatar
I bet the automatics will be faster in a straight line. Which is great, as long as they don't omit the option for a manual.
Half of the old guys who can afford one won't ever track them, so the smaller wing is a smart offering too.
Old Nov 13, 2017 | 08:55 PM
  #2789
I love the car! The nose, the hood, the wing-I'm in.
I never bought a C6 because the nose was just too plain. The C7 nose follows suit too. Yes, the nose looks very Aventador-like, which is a good think.
Old Nov 15, 2017 | 06:25 AM
  #2790
CCColtsicehockey's Avatar
So Steven how long till yours is for sale. Are you already on the list for one?
Old Nov 15, 2017 | 06:37 AM
  #2791
I love the wheels!
and the car is nice too
Old Nov 15, 2017 | 07:31 AM
  #2792
fsttyms1's Avatar
I think it looks good. The front end is obviously needed like that for cooling since the last one had such issues.
And as much as a manual guy i am, i think id rather have this in Auto as it will be faster than the manual especially since there is no DCT
Old Nov 15, 2017 | 07:32 AM
  #2793
i really dont mind the front; all cars look like that today...BMW's, Civic's, lambo's
Old Nov 29, 2017 | 09:07 AM
  #2794
https://www.topgear.com/car-news/la-...nvertible-here
Supercharged hardcore 'Vette now comes in drop-top form. Imagine the NOISE
Just two weeks after the quite mad coupe comes this, the Corvette ZR1 convertible. Yep, no special name or confusing spelling of the word spider. Just ‘convertible’ with a lower-case C. Simple.
It uses the same 755bhp supercharged 6.2-litre V8 as the coupe, with the option of seven-speed manual or eight-speed automatic gearboxes. With the auto, the hard top has a top speed of 212mph and does 0-60mph in sub-3.0secs, but that’s with a special aero package.
Chevrolet says the convertible will still have a top speed ‘over 200mph’, though, which is probably more than enough. And all that unholy supercharger whine and V8 roar – unencumbered by a roof – should make up for any performance deficit.
Chevy also says the says the rigidity of the Corvette’s aluminium chassis means no extra strengthening has been required, and that the convertible’s only structural mods over the coupe are to fit the folding roof and reposition the seatbelt mounts. So their suspension tune is the same and the convertible weighs just 27kg more than the coupe. That’s a couple of extravagant drive-thru orders.
It also costs just $4,000 more, at $123,995. Or about £92,000 ar current exchange rates, which is startling value for a car so quick and powerful. But then value has always been the Corvette way. A 215bhp-lighter Audi R8 Spyder is over $50,000 more in the States…
Does the hardest-cored Corvette make sense with its roof opened up? It’s the first ZR1 convertible since the Seventies, which might suggest not. And you wouldn’t expect Porsche to trot out a 911 GT2 RS with a soft top. But then that noise really ought to shout over any our doubts.
Let us know your thoughts below, and recap on the coupe at this link. Both will be on display at the LA motor show from the end of the week.
  #2795
Old Dec 1, 2017 | 09:33 AM
  #2796
https://www.topgear.com/car-news/sup...w-corvette-zr1
We hitch a ride in a ZR1 prototype for some laps of Willow Springs. It's quick...
What is this?
We are at Willow Springs Raceway, an hour north of the LA motor show where we first got sight of the new Corvette ZR1, to have the first look at the furious beast in action from the pit lane – and in the passenger seat.
In the driver’s seat is the head of the ZR1’s development drivers, Alex MacDonald. It’s 23degC, the sun is shining, the track is empty and the ZR1, still wearing its development camo, has just been shod with a brand new set of Michelin Cup 2s.
Time to see what the hugely bewinged 755bhp car can do. This is going to be fast…
How fast?
Well, the top speed of the coupe is quoted by the company as 212mph (the convertible is a tad slower at a wig-losing 208mph). The downforce has been measured at 430kg at that top speed, thanks to the huge (optional) rear wing and a new front splitter arrangement.
Both are included in the ZTK pack, along with a set of Michelin’s finest performance tyres. And today, there’s no other traffic to get in the way. So on this track, already renowned as being one of the quickest in the US, it’s going to be very fast indeed.
Let’s go…
There’s going to be no warming up here. Alex hits the throttle hard and we wheelspin our way down the pit road, allegedly to take the top surface off the new tyres and get to the grippy bit.
Then it’s onto the circuit and into the tight left of turn one. The car, in Track mode, is moving around a lot under braking and during the violent bouts of acceleration out of the corners as the tyres come up to temp.
But as we get out of turn six and set up for the long run down to seven and the fearsome turns eight and nine, the ZR1’s aero settles the car on the track. The car we are in has the optional ZTK pack, which generates 340kg more downforce than the regular ZR1 at max speed with its lower – but still frame-mounted – spoiler. And we need every last kilo of that now.
Entry speed to turn eight, a sweeping right hander, is north of 140mph. But once the car is set up, Alex is accelerating again to hit turn nine and run onto the back straight. Speed at the end of that? 159mph before dropping the huge, double heat-treated carbon anchors.
You going for another lap?
Of course we are. Now that the whole car is up to temp there’s no reason not to. All of the Z06 Vette’s heat management problems appear to have have been addressed and banished on the ZR1.
The new 755bhp supercharged V8 is dubbed LT5 – the second time this engine designation as been used, the first time being on the Gen 4 ZR1 back in 1990. That engine was worked on extensively by Lotus, which was then owned by GM. But this latest LT5 is the new king of the small blocks. And it has lots of new numbers to offer the world.
Such as?
The LT5’s 2560 supercharger – it’s called that because it flows 2.65cubic metres of air every time the engine completes one rotation – shifts 52 per cent more air than the Z06’s LT4’s compressor. Its intercooler also has twice the capacity. The drawback? The supercharger draws a huge 110bhp from the engine to power itself. The LT4’s 94bhp.
Where is it making all the extra power and torque?
Across the range, but especially above 4,000rpm, whereupon the ZR1’s power curve shoots north on the graph like a scalded squirrel. A fact that Alex is demonstrating amply as we dive into the second lap.
The ZR1, which Corvette Project Chief, Tadge Juechter, calls ‘the Corvette from Hell’, has settled down now and is only getting out of shape when Alex loads up the front or rear on purpose. Willow Springs is a wide, flowing circuit, but in these first laps out of captivity, the ZR1’s warp speed is making it feel like a narrow kart track.
Does it seem like it’s hard to control?
No, more that it now has more control so that you can get it out of shape more readily. The Z06 can get a little wayward when you switch off all the chassis nannies, and we only got to witness the ZR1 in Track – the least intrusive – drive mode. But, while it was a very animated drive, it never seemed out of control from where we were sitting.
What about that shaker bonnet? Is that just for show?
No, it is a necessity to keep the sight lines as low as possible. One of the great things about the small block Chevy is its absurdly compact dimensions. This keeps bonnet lines low which improves vision and optimizes weight balance.
Because the ZR1 has a much bigger, taller supercharger on top of it, rather than shape the bonnet over the top of it, Chevy cut a hole in it and made a feature of it. So that big slab of book-matched carbon fibre you see there? That’s bolted directly to the top of the engine.
So what do we think so far?
After just four laps in the passenger seat, it’s impossible to draw any conclusions other than the new ZR1 is much faster than the already rapid Z06.
How much faster? We’ll have to wait a few months to get behind the wheel of a production ZR1 to find out. However, expectations are now high and we have little doubt, based on this first ride, that even those high hopes could be shredded.
  #2797
Old Dec 1, 2017 | 10:17 AM
  #2798
TacoBello's Avatar
I want one.
Old Dec 4, 2017 | 07:45 AM
  #2799
fsttyms1's Avatar
I want 2
Old Dec 4, 2017 | 08:13 AM
  #2800
Joneill44's Avatar
