******please help me******
Old Jul 23, 2017 | 01:41 PM
Kcnguyen's Avatar
3rd Gear
My 2008 Acura TL climate control light not on after I tried to changed led bulbs lights. Before i try to changed that some lights but after that all off. Please help me.
Old Jul 23, 2017 | 02:04 PM
peter6's Avatar
Check fuse. Bad part is that same fuse is also for rear red lights, so unless you don't figure it out, don't drive when it's dark.
Fuse #4 under hood. 10A
If it's blowing right away, remove/disconnect everything that you done and try one by one. You must have short somewhere.
Old Jul 23, 2017 | 03:56 PM
Kcnguyen's Avatar
3rd Gear
I already did check the fuse. But the fuse still good. Should I disconnect my battery and reset it.
I already plug all that one in and drove to my friend house last night.
Thank you for helping me.
Old Jul 23, 2017 | 03:59 PM
Kcnguyen's Avatar
3rd Gear
That problem here i think because when I tried replacing the bulbs light but for got disconnect the powers. So you know how that problem???
Thanks again Peter6.
Old Jul 23, 2017 | 05:40 PM
You shorted something out. Probably still the fuse.... Replace the fuse
Old Jul 23, 2017 | 09:28 PM
USNA93's Avatar
shot in the dark here, but when you put in the LED bulbs, are they in the right way? I don't know if the climate control LED bulbs are different from the small seat warmer bulbs (which I replaced today with LEDs)...but if they are the same, I found that if I didn't align the wires in the socket properly, the bulb didn't lite...so I turned it 180 degrees and it lit up. Anyway...just a guess after living that today.
