How do I remove the spoiler on the trunk lid?
Old Apr 20, 2017 | 01:03 PM
MisterABdub's Avatar
I've got the wing type spoiler that I'm trying to remove and repaint. Looked inside trunk, didn't immediately see any attachment method like bolts or screws. How TF did they put this thing on here?! Want it off so I can thoroughly prep and repaint, but not seeing any attachment points.
Old Apr 20, 2017 | 01:46 PM
BreezyTL's Avatar
Pop the trunk liner off and there should be 1-2 bolts per side on the underside of the lid.
Old Apr 20, 2017 | 01:52 PM
No fasteners
I see nothing.
Old Apr 20, 2017 | 02:08 PM
BreezyTL's Avatar
What spoiler is it?
Old Apr 20, 2017 | 04:08 PM
WDPanda's Avatar
Must be taped on with just 3M. The 2 bolts on my aspec was 3M and bolted.
Old Apr 20, 2017 | 05:11 PM
3M tape...
If so, that's some bad ass tape!
Old Apr 21, 2017 | 08:31 AM
BreezyTL's Avatar
Give it a good tug!
Old Apr 21, 2017 | 08:44 AM
Pull on it
Give it a good tug!
I don't know if I'm courageous enough to start pulling on it. It sounds sketchy. Which way? Up, or back?
Old Apr 21, 2017 | 09:09 AM
BreezyTL's Avatar
just grab it and pull towards the back of the car. Could also run some fishing line under each mount to separate the tape. Try heating it up a little to get it pliable. Don't burn the paint tho!
Old Apr 21, 2017 | 09:49 AM
GhostTL09's Avatar
there are two bolts per side, plus 3M tape. If you've only taken out 2 total you have 2 more. You will have to plug those holes and have the trunk painted by a shop because there is no spoiler that will cover that else you'll exposed to the elements. How many have you removed altogether?
Old Apr 21, 2017 | 09:56 AM
No bolts
I see no evidence of any type of bolt, unless in the one pic, there is a Allen key inside the only hole I see.
Old Apr 21, 2017 | 10:03 AM
The fishing line
The fishing line isn't a bad idea, plus, it will give me an idea where any mechanical fasteners might be.
Old Apr 22, 2017 | 02:42 AM
Silver 3.5's Avatar
BANNED
This is what i found at acuraparts.com , It might help letting you know their is 2 fasteners on each side.
Old Apr 22, 2017 | 05:44 AM
Website.
thanks for that! I'm going there because they usually have a description along with the images.
