Sprint Booster v3 issue.
Has anyone purchased a Sprint Booster v3? and their thoughts on it?
I just purchased one and been using it for a day and suddenly my "Check Emissions System" light came on... Why would this happen?
Is there a easy fix or to check why this light came on.
How can i remove the light, should I get rid of the Sprint Booster all together?
I just did a plug and play install by disconnecting the plug from my pedal and connecting it with the plugs they provided... thank you
Strictly a guess here, but it doesn't seem logical based on Sprint's site. I don't know how to clear the light, but I am sure it is on here somewhere.
I would reset the light, unplug the Sprint, and see what happens. If the light comes back on, its not the Sprint.
If you can run several days without the light, plug the Sprint back in. If the light comes on, it is the Sprint
Could be something as stupid as electrical noise being generated by the Sprint on the car's electronics systems, or it could be there is some weird programming thing that doesn't like that the Sprint is there, or what it is doing.
I have seen cig lighter chargers for phones trigger radio noise and other abnormalities, so nothing would really surprise me.
This thread will not be deleted.
Can I create a second account too? Oh, wait, that's against the rules...
What to be confused about? Soupi logged in to A'zine using the z643167z account. Since the warning light went off probably because of a loose gas cap, the Autozone scan saw no issues. After he got a response, he posted using his "soupi" account (probably forgetting he used the other account initially) and asked f he should still follow the posted advice even though there were no more warning codes.
What soupi doesn't realize is that using the Sprint booster is just like stepping on the gas harder. He also increases the bass, center and treble on their radio and thinks it sounds better.
I've never heard of this thing before so I googled it. All it does is trick your car into thinking the pedal is pushed down more than it really is. Whats the point....? Just push down your gas pedal slightly more to get the exact same effect.
Why does this product even exist...........
Check our table via flashpro then compare civic Si (the indices are different, but you guys can interpolate)
Si
