Numairh's 3G TL Build Thread
Old 02-09-2017, 01:21 PM
  #361
UA6MT
numairh's Avatar
Installed my Comptech short shifter last night. Love the way it feels!
Old 02-09-2017, 03:00 PM
  #362
sockr1's Avatar
Received 1,160 Likes on 909 Posts
nice, i love my short shifter! you were luckier than me though, my gear shifter housing was welded to the frame so i had to do everything inside the car haha.
now you just need a heavy shift knob to complement it!
Old 02-10-2017, 12:41 AM
  #363
UA6MT
numairh's Avatar
What, that is crazy! The hardest part for me was removing the bushing off the bottom of the original lever. That must have been even worse doing it in there! Also, it feels heavy with the OEM shifter, how would you compare the factory to a heavy one with the SS?
Old 02-10-2017, 07:27 PM
  #364
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
I like that 2nd pic.
numairh (02-15-2017)
Old 02-12-2017, 01:13 AM
  #365
Burtch07's Avatar
Looking sweet and love that new splitter
Old 02-15-2017, 02:18 AM
  #366
UA6MT
numairh's Avatar
Old 02-15-2017, 09:29 AM
  #367
sockr1's Avatar
yea it was horrible doing it inside the car!
the heavy shift knob makes the short shifter feel 100x better. i think i got rid of my oem knob in the first year i owned the car (back in 2008 haha). once you start getting into 6mt mods a heavy shift knob is almost a necessity. at a minimum you should get a 400g knob but i think if you're going to get a heavy knob, go for the best...raceseng! the weights are way higher (i have the slammer which is 635g) and their quality is the best i've ever seen...it will literally transform how it feels to drive stickshift.
have you also thought about getting hybrid racing shifter bushings? that will make the shifts crisper and more precise, it removes even more slop from the setup. easy switch out too, you just do it all in the engine bay (i did a short write up in my progress thread)
Old 02-15-2017, 10:16 AM
  #368
BreezyTL's Avatar
Received 1,041 Likes on 773 Posts
HR bushings are a 15 minute job with a beer break! They remove the "sponge" feeling.
Old 02-15-2017, 02:54 PM
  #369
UA6MT
numairh's Avatar
I think I will look into that soon. My issue is that I love the feel of a leather shift knob.. The bushings are on my list but right now my priority is to get my rear camber kits on because they've been sitting for 3 months already. And I need an alignment asap since I lowered the back a little bit.
Old 02-15-2017, 03:04 PM
  #370
sockr1's Avatar
sounds like you have a plan! yea i don't think there are any heavy leather wrapped knobs so oem will do
Old 02-20-2017, 02:38 AM
  #371
UA6MT
numairh's Avatar
Bye bye TE37 reps!
Old 02-20-2017, 08:15 AM
  #372
Burtch07's Avatar
I love the new wheels way better!!
Old 02-20-2017, 08:22 PM
  #373
UA6MT
numairh's Avatar
Another pic pic of the new wheels! They're Ambit RE02 18x9.5 +38 with a 20mm spacer all around (does not clear Brembos) wrapped in 225/40. The back rubs a bit so I will put the collar back into the rear coilovers and then finally install my camber kit this week so it stops rubbing! Taking suggestions for a new color! Thinking bronze or just silver again.
Old 02-20-2017, 08:23 PM
  #374
^^^ Dude, looks great....perfect stance too.
Old 02-21-2017, 12:57 PM
  #375
MyGuti's Avatar
those wheels look pretty amazing!!! Thanks for posting the specs, might have to order those. Which color do you have the wheels in? Gunmetal?
Old 02-21-2017, 01:09 PM
  #376
rockstar143's Avatar
Received 20,014 Likes on 14,518 Posts
Super nice, Num...
love it.
Old 02-21-2017, 11:22 PM
  #377
UA6MT
numairh's Avatar
Put the collar back in the rear coilovers. No rubbing but I don't like the rake... I might raise the front a quarter inch.
ATLS_666 (03-15-2017)
Old 02-22-2017, 07:23 AM
  #378
Those are a knock off of the enkei I wanted...but in specs that aren't overly aggressive...love it.
Old 02-22-2017, 09:29 AM
  #379
UA6MT
numairh's Avatar
They are a bit on the aggressive side, when I had the rear collar removed they would rub constantly but very slightly, now it doesn't rub at all.
Old 02-22-2017, 09:42 AM
  #380
sockr1's Avatar
the specs aren't aggressive but your spacers are hahah! go down to 15mm spacers from the 20mm and you'll be fine to go as low as you want.
Old 02-22-2017, 11:44 AM
  #381
UA6MT
numairh's Avatar
Yeah I meant with the spacers it's a bit aggressive, but I can't go down to 15. With the 20mm in the front, I can't even fit my car key between the brake and the spoke.
Old 02-22-2017, 12:07 PM
  #382
sockr1's Avatar
^^ crazy haha!!
just buy the right wheel specs lol!! I kid I kid (I'm just a spacer hater), new setup looks great! I think a brighter color would look great like hyper silver or gunmetal
Old 02-22-2017, 01:19 PM
  #383
UA6MT
numairh's Avatar
^^ crazy haha!!
I had spacers for over a year with no issues, so I just buy specs that will work with a 20mm spacer to clear the brakes because there are so many wheels I like which don't fit without them. I'm painting them soon when I have time.
Old 02-23-2017, 12:24 AM
  #384
UA6MT
numairh's Avatar
I've been busy with this car... I raised the front of the car about .25 inch to even the rake out. I also wrapped the front and rear trim in matte silver for the factory look. The pieces are sanded down underneath for the fake chrome look. Sanded that last year and it was the biggest mistake.
Old 02-24-2017, 03:45 PM
  #385
07WDPUA7's Avatar
Highly recommend that you get a weighted and countersunk shift knob. Makes shifting way better compared to the stock shift knob. This is the one that I have from HeelToe.
https://www.heeltoeauto.com/maven-co...on-10x1.5.html
Old 02-24-2017, 11:43 PM
  #386
UA6MT
numairh's Avatar
Finally got around to installing my camber kit by SPC. So I was under the impression that you can add 2 degrees negative and 4 degrees positive camber but I guess it was the other way around. I was expecting to be at -5 maxed out with he arms but I ended up with like -7-8. I backed it back out to about -4 degrees. SPC arms maxed out.
Backed out to about -4. Alignment coming next week.
Old 02-27-2017, 07:08 PM
  #387
Wow, that is some serious tuckage.
Old 02-28-2017, 07:40 PM
  #388
nip tuck, baby.
Steven Bell (02-28-2017)
Old 02-28-2017, 08:03 PM
  #389
Back for another look!
Old 03-04-2017, 06:37 PM
  #390
UA6MT
numairh's Avatar
Got it aligned finally and they didnt even need to touch the camber because I had eyeballed it so close that it wouldn't make a difference changing it. It's -5.1 passenger and -5.4 driver. Also got the rear tires flipped. I have quads sitting in my room waiting to get welded on, oem type s taillights being installed this week and then going to paint my wheels!
Old 03-04-2017, 08:06 PM
  #391
sockr1's Avatar
Looking good man! What color wheels? Also if you're getting new or like new headlights put on, have a shop put on a clear wrap so they don't haze or get damaged (usually about 80-100 bucks with a 5-7 year warranty)
Old 03-04-2017, 08:47 PM
  #392
UA6MT
numairh's Avatar
Thank you! And I'm thinking about gloss silver because I don't want anything crazy. I actually put Laminx film on them a couple months ago and they look great!
Old 03-04-2017, 09:05 PM
  #393
Burtch07's Avatar
Looking very very sexy!! With a silver car I think almost every color would look good.
Old 03-05-2017, 03:45 AM
  #394
treal512's Avatar
Nice build. Noob question, but what are you side markers? Depot?
Old 03-05-2017, 06:21 PM
  #395
Burtch07's Avatar
He has the Type-S depo side markers. The parking lights on the side in the rear
Old 03-05-2017, 10:28 PM
  #396
UA6MT
numairh's Avatar
I'm actually thinking about doing silver with a sparkle clear coat... (Duplicolor clear effex, but not super heavy, just so you can see a little rainbow sparkle in the sunlight)
Yes they are the Type-S smoked Depo. You can get them off eBay or Unique Style Racing.
Old 03-05-2017, 11:31 PM
  #397
treal512's Avatar
Thanks, man. Did you go with just the rears or the full 4-piece set? I'm wondering if the Depos will match my front OEM markers.
Old 03-06-2017, 01:00 AM
  #398
UA6MT
numairh's Avatar
I got the full set because I wanted the white LED fronts. They will not match the OEM because they are gray while Depo is black.
treal512 (03-06-2017)
Old 03-06-2017, 07:01 PM
  #399
Love it....great look!
Old 03-10-2017, 10:12 PM
  #400
UA6MT
numairh's Avatar
Installing OEM Type S taillights
Quick Reply: Numairh's 3G TL Build Thread
