JDM Headlights Installed!
Old Dec 18, 2016 | 03:19 AM
Wooodis's Avatar
Wink JDM Headlights Installed!
Just installed my new stock Honda Legend Headlights from Japan! Finally got rid of those ugly amber corners. Here are some pic's of the install.
Old Dec 18, 2016 | 04:09 AM
NathanJax's Avatar
Did you swap around the projector so it doesn't blind oncoming traffic with the wrong cut off pattern? Also, what did you do about the blinker bulb not fitting?
Old Dec 18, 2016 | 11:27 AM
teh CL's Avatar
Looks good..
Never understood how the amber corners are "ugly"..
Old Dec 18, 2016 | 11:39 AM
projektvertx's Avatar
Originally Posted by teh CL
Looks good..
I honestly have no issue with the amber corners. Then again, my car is blue, so it fits aesthetically... Potato, potaaato, though right?
Old Dec 18, 2016 | 11:40 AM
teh CL's Avatar
Old Dec 18, 2016 | 11:58 AM
MSW 6SP's Avatar
To me, the amber color draws your eyes to the corners of the car. Without them, the front end appears wider. And it now draws more attention to one of the most luxury looking front grille Acura has ever made.
Old Dec 18, 2016 | 03:53 PM
Wooodis's Avatar
Yeah..... the blinker bulb housing was an welcomed surprise Needed to cut the blinker housings off each headlight and swap them. I didn't switch the projectors though, I feel I just need to raise them a little since they seem to aim lower than normal.
Old Dec 22, 2016 | 11:18 AM
RL_Coastin's Avatar
To each his own, I personally really dig the clear corners. It makes the car look a lot cleaner IMO. The amber corners pop out at you too much, the clear ones blend in with the headlights. Any more future mods?
Old Dec 22, 2016 | 06:34 PM
Wooodis's Avatar
WHEELS! but I don't know which type of wheels I want yet, so it wont be for awhile.
Old Dec 22, 2016 | 06:41 PM
RDX10's Avatar
I think it looks really really good. Not sure I would spend the money replacing mine if I had an RL, but your oem headlights looked a little on the faded side so I think it was worthwhile. I really like the little LED or white lights in the corners where the ambers were.
Old Dec 23, 2016 | 01:01 PM
oo7spy's Avatar
I tied to write a post the other day, but couldn't find the right words.
This sums it up very well.
Old Dec 23, 2016 | 04:13 PM
Harper's Avatar
Unregistered Member
Are the new projectors RHD? If the cut off looks like the right side of the pic then there's a possibility of blinding oncoming traffic.
Old Dec 23, 2016 | 04:52 PM
NathanJax's Avatar
Yes they are. That's why I asked that question. He said he would "raise them" in post #7, but I'm hoping he will lower them so it doesn't blind oncoming traffic. That's the problem with purchasing these, as they will be higher to all oncoming traffic ALWAYS... The projectors need to switched so it's like your pic...
Old Dec 29, 2016 | 02:41 AM
Wooodis's Avatar
Unhappy
Yes, I am starting to notice it more as I drive. I'll need to switch the projectors to make it normal again.
Old Dec 29, 2016 | 02:50 AM
Wooodis's Avatar
Unhappy
After installing these new headlights in my car and swapping out the front signal plugs and sockets I come to find out that one the plugs doesn't work.. I checked to see if power goes through the wires (Which it does), but when I check it from the other end (part that goes into the bulb socket) theres no power. So something is is wrong with the plug. Is it possible to directly connect the bulb socket to the wires?
I already went to Honda and Acura dealerships to see if they have a spare part but to no avail.
Old Dec 29, 2016 | 08:31 AM
RL_Coastin's Avatar
I believe the wires in the plug lead directly to a metal prong. Not 100% sure, but I can't imagine it being different. If so then you should be able to wire them directly. I would try fixing the plug first. Probably dirty connector, loose, or bad wires.
Old Dec 29, 2016 | 08:47 AM
oo7spy's Avatar
Agreed it would be better to fix the socket. It's just wires in one end and metal plates in the other. Somehow they must have disconnected.
Old Dec 30, 2016 | 09:08 AM
08KBP_VA's Avatar
I think it depends on the color of the car as well. I think its too striking of a contrast with the WDP but I have them on my CGP and I am not offended at all and they blend well with my burnt orange calipers
Old Jan 5, 2017 | 11:32 AM
oo7spy's Avatar
Burnt orange... you aren't a tea-sipper are you?
Old Jan 5, 2017 | 01:50 PM
Echoe53's Avatar
Training Mode
Nice, this is definitely on my list to purchase in the near future.
Old Feb 16, 2019 | 07:16 PM
VANDRETIRL's Avatar
I have a question if you are still on here. So you cut the orange bulb connections from the projector side and switched the hosings? And the second question on the blinker side the USDM has one bulb and the JDM has two bulbs. The blinker connection is the same but did you splice the JDM wiring into your USDM wiring so you can plug both of them in?
