Headlight wetsanding/polishing problem
Old Jul 21, 2009 | 04:08 PM
miamirice's Avatar
Yup
So today I finally got around to wetsanding and polishing my headlights. They weren't hazy or scratched, but they had a lot of little pits. It wasn't really bad, but I wanted them crystal clear and looking awesome. Well, I picked up a headlight polishing kit which had sandpaper grits of 1000, 1500, 2000, and 2500. I started with the 1000 but it wasn't getting to the pits, so I decided to start at a lower grit and work my way up. I went to Pep Boys and picked up a packet that had 320, 400 and 600 grit sandpaper.
So I sanded up/down then left/right with each grit paper starting with the 320 until I ended up at 2500. I wetsanded using each for about 5 minutes each (took forever). At the end, I tried polishing with three different things: the liquid that came with the kit, 3M Rubbing Compound and Meguiar's ScratchX. None worked great.
I tried the whole process above TWICE, and even tried using an electric buffer/polisher for the polishing. Of course I got the pits out, but the headlight I polished (I only did one) is now hazy from scratches. In fact, the housing as a whole looks LESS clear than the untreated headlight . See how my polished one looks worse than the one I didn't do yet.
Did I start at too low a grit? If so, how can I correct? Has anyone else tried this and gotten less than satisfactory results?
Old Jul 21, 2009 | 04:41 PM
FirePR2002's Avatar
bringin lead
its hard to see what you're talking about with these pics. i have one of those powerball attachments for a cordless drill and use it to polish my headlights with meg plastix. meg scratchx is not abrasive enough to work on the plastic I don't think(i tried this before using plastix). maybe you should try the plastix.
Old Jul 21, 2009 | 04:47 PM
Rajca's Avatar
wham bam thank you ma'am
u started with the wrong grit. 1000 minimum. u just gouged the plastic lenses and have to start with about 600-800 grit and work ur way yup till its smooth and cant feel any gouges
Old Jul 21, 2009 | 05:01 PM
Mista Juice's Avatar
wow.. 320 grit?..
Old Jul 21, 2009 | 05:03 PM
TouringLow's Avatar
lol @ 320...i cant stop laughing. sorry
Old Jul 21, 2009 | 05:06 PM
TouringLow's Avatar
ok im done laughing.
as others stated, you started too low. to fix it, you will have to put in a lot more work. i would recommend sanding with 800 for 10-20 minutes, and then move on to 1000, 1500, 2000 but sand each for atleast 10 minutes. another mistake u made is you barely spent any time sanding them as well.
goodluck
Old Jul 21, 2009 | 05:20 PM
TLin401's Avatar
'13 Hyundai Sonata
Try putting some wax on the buffer after you sand them down again.
Old Jul 21, 2009 | 06:02 PM
twistedwedge's Avatar
6MT Someday..
hmmmm...320? ouch. Thats most likely the root of your problem. Too coarse for plastic. Like others said...youre gonna have to put some more work in. I agree with TouringLow-800 is the lowest I would have gone.
Old Jul 21, 2009 | 06:11 PM
jjashaa's Avatar
Avant Garde Wheels
all you needed to do was start at 1000 grit.
taken more time during sanding..
Old Jul 21, 2009 | 09:52 PM
fsttyms1's Avatar
You used WAY to low of a grit. Polishing takes time too.
Old Jul 21, 2009 | 10:34 PM
TequiLa's Avatar
(ಠДಠ)
I started at 400 cuz of oxidation and spent about 2 hours going to 600, 800, 1000, 2000, then lense polisher and came out perfectly. By the time you're done, you're hands should cramp up lol...
Old Jul 21, 2009 | 11:44 PM
miamirice's Avatar
Yup
Thanks everyone for the tips...Seems I'm learning the hard way...really hard.
OK, so tried to correct it as suggested. I used 800 grit for 20 minutes, then did 10-12 minutes each of 1000, 1500, 2000 and 2500. However, even after I polished at the end, there were still some fine scratches remaining, and not quite 100% clarity. I'm not sure if they're the same scratches from the 320 grit or the 2500 I used at the end, but they are there. I didn't use the electric polisher this time... I'm wondering if I can just buff out the scratches if I use the right combo of power buffer and compound. I am thinking of trying PlastX, and if it doesn't work by hand, either a orbital/dual-action polisher or a rotary buffer...
Old Jul 21, 2009 | 11:59 PM
TLin401's Avatar
'13 Hyundai Sonata
Get a buffer, put some wax or Nu-Finish Scratch Doctor on the light, then buff and it should solve your problem.
Old Jul 22, 2009 | 12:09 AM
gold2003tl (90)'s Avatar
2003 TL-p
i did mine with 600dry- 600wet - 1000wet - 1500wet and a shit load of scratch-x and a drill buffer and it came out perfect for me.
i also used some of this blue headlight restore goo and a drill buffer
then put a good layer of wax on it to protect it, buff it good too.
Old Jul 22, 2009 | 01:21 PM
'02_TL-S's Avatar
Traded in my
PlastX sucked for me as well. I used 800, 1000, 2000, grit and spent about 15-20 mins on each headlight. Then PlastX didnt clear them up all the way so when I was waxin, I hit em with the polisher and wax cleared em right up. Meguiar's Tech 2.0 wax is the shit..
Old Jul 22, 2009 | 03:37 PM
JRhodes88's Avatar
Need an OEM lip kit on my
I only start out with 600 if the headlights are EXTREMELY yellow.
The fact that you tried 320 is astonishing.
Old Jul 22, 2009 | 06:08 PM
acurabum's Avatar
I put some wax on the final step but do you know why after 1-2 wash the headlight will get yellow again ? Did i forget anything after the wax ?
Old Jul 22, 2009 | 06:16 PM
Rajca's Avatar
u need some uv protection on them, u put sealant?
Old Jul 22, 2009 | 06:24 PM
acurabum's Avatar
I thought Plastix and then wax were enough ... ? What type of sealant are you talking about ? And what brand ?
Old Jul 22, 2009 | 06:28 PM
Rajca's Avatar
i have my detailer do it for me. he wet sands, buffs with diff pads and compounds and but a some kind for sealant on the lights at the end.
Old Jul 22, 2009 | 08:16 PM
mlrskn06's Avatar
use meguiars, it worked for me =]
Old Jul 22, 2009 | 10:30 PM
miamirice's Avatar
Yup
Well, after reading the DIY's and threads on this forum, I figured that as long as I used increasing grits, I could start with a lower grit and work up to 2500. Oh well. I hand-polished for about an hour today, trying every one of...
1. Liquid polish that came with the kit
2. 3M Rubbing Compound
3. Plastx by Meguiars
4. Carnuba cleaning wax by Mothers
I think the liquid that came with the kit actually worked the best, applied by hand. The headlight is now...acceptable, but in no way perfect. It's free of all pits, mostly transparent, and from a few feet away it's not bad at all, but it's NOT glass-clear...very slight haze still, and if I put my face right up in front of it, I can see the nearly microscopic scratches. Again, I'm not sure if those are from the 320 or the 2500 I ended at, but I am not sure how to experiment to see which it is. I'm wondering - I corrected by mistake by starting at 800 yesterday (which I used for 20 min)...but since I used 320 initially, wouldn't those scratches need to taken out or sanded out by something of a similarly low grit? Maybe 400 and then 600 before going up to 800?
Another possibility in my mind - would a rotary buffer be able to produce enough friction/heat to slightly melt the plastic back into clarity?
Old Jul 22, 2009 | 11:16 PM
Atlbrav1's Avatar
Mequiars Headlight Restoration Kit works great, inexpensive, and only about an hours time start to finish.....
Old Jul 23, 2009 | 03:44 PM
'02_TL-S's Avatar
Traded in my
I'm tellin you..I had the same probs but hit em with my cheapo random orbital polisher and Tech 2.0 wax and they're clear as glass now.
Old Sep 13, 2009 | 11:51 AM
topper1296's Avatar
I just used the 3M kit (about $30) yesterday and it worked great.
Old Sep 13, 2009 | 02:12 PM
2003 TL-p
^ cool, as long as you didnt use 320 grit sand paper i am sure it came out great
Old Feb 16, 2010 | 04:43 PM
tj19855's Avatar
2007 TL
I'm a professional headlight restoration technician, I use 320-600-1000-1500-3000, electric sander run it 3000rpms to 5000rpms No wet sanding, clean with water each time your done with each grit. Sand until the yellowish look goes away, 320 and 600 are the ones that remove the yellow dirt. Go up to 3000, Polish them finally the uv coat sealer and they should look brand new. Takes me about an hour for each headlight. Is not as easy as it sounds. I charge $40 per headlight. You will probably still see scratches if you do it by hand.
Ps - I don't use those cheap kits that cost $10-25, my kit cost me about $500
Old Feb 16, 2010 | 04:50 PM
It's Clutch's Avatar
Hello Officer
^any b4/after pix?
Old Feb 17, 2010 | 01:22 AM
tj19855's Avatar
2007 TL
Old Feb 17, 2010 | 10:55 PM
'02_TL-S's Avatar
Traded in my
Damn..nice work. Guess that's what happens when you have experience..LOL
I'm thinking about going back over mine with just the 1500 grit and my dremel to really get rid of all the fine scratches.
Old Feb 19, 2010 | 11:25 AM
jaMezBOI's Avatar
philly flickin'
wanna do mine?
Old Feb 19, 2010 | 12:10 PM
JRhodes88's Avatar
http://solutions.3m.com/wps/portal/3...cts/Headlight/
This is the system that my uncle uses in his hot rod shop. seems to work great and doesn't leave the scratches you may get from doing it by hand.
Old Feb 19, 2010 | 12:13 PM
JRhodes88's Avatar
What kind of sander are you using and what are you polishing it with?
Old Feb 20, 2010 | 06:11 PM
tj19855's Avatar
2007 TL
http://www.deltakits.com/products/4/725/
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
