What exactly does "S" mode on the transmission do?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
What exactly does the s mode do?
I put it in S mode by mistake and It shifted its own?
I thought that u would have to shift yourself in "S" mode but it still shifts for you, so whats the point?
Do any of you guys use the "S" mode?
And can anyone tell me the advantages of "S" mode?
Like if i was at the track running 1/4 mile would I have a quicker time in "S" mode or would it be the same, or does it just hold gears longer in normal driving?
It will still shift on it's own eventually to keep you/somebody from damaging the transmission in case it was put into 'S' instead of 'D' by mistake.
But as stated above, it hold the gear for a little longer and is intended for paddle shifting.
From the Owners manual:
S Position (S) - To shift into the S position, press the release button on the front of the shift lever, and move the lever to S. This position is similar to D, except only gears from first to fourth are selected. The S position keeps the transmission from cycling between fourth and fifth gears in stop-and-go driving.
Refer page 375 and 379 of the Owners manual.
If you shift to S, and press the paddle to gear 1, it will not auto shift... I used this once and forgot that I was on S mode, I almost reach the cut off point on 1st gear (while talking to my wife on the handsfree) and it didnt change gear :p
If you shift to S and didnt press the paddle, it still works like D but hold the gear on a position longer.
You are right what I noted in my earlier message was if you put it in S mode and do not use the paddle shifters. If you use the paddle shifters then per the owners manual:
With the shift lever in the S position, you can manually shift up or down with the paddle shifters. The transmission goes into the sequential shift mode and holds the selected gear.
When you accelerate from a stop, the transmission starts in first gear, and you must manually upshift between first and fifth gears.Make sure you upshift before the engine speed reaches the tachometer’s red zone.
SeeYou2Crew #2
haha when i first got the car i had the excat question. sometimes i drive in s without using paddles, sometimes i dont lol depends, i used to think it feels more responsive in s mode, but i think they are around the same LOl
Same thing happened to me while talking to a friend. Will it not auto shift to 2nd? I'm too scared to try.
B A N N E D
It will shift if u have it in "s" mode that why I ask.. I drove all the way to work in "S" mode and did not have to shift..That why I asked.. I thought u HAVE to shift with the paddles in "S" mode but no u do not!
I haven't tried this since my car is barely out of the break-in period
B A N N E D
I know this, I was telling others that said it did not shift on its own..
Putting the lever into "S" doesn't automatically give full control to the paddles. To operate the car completely with the paddles, click either the downshift or upshift paddle while in "S"...doing this will make the "M 1, M 2, M 3" etc appear on the screen on the gauge cluster, letting you know that you've put the car in the exclusive manual mode.
Can someone clarify whether it is possible to switch from "D" to "S" mode while the car is moving. I read the manual and it says that the you have to press the shift release lever to shift from "D" to "S" mode which make me think that the car would have to be stationary.
In my old RSX I was able to switch from automatic to manumatic (change up manually) mode on the fly so i am curious whether it is the same on the TSX as well.
If you are in the S mode and using paddle shifters you can hold a particular gear as long as you want. So it is kinda like driving a manual as in you can rev the engine as much as you want and for me personally more fun. Ofcourse the mileage would suffer so I don't use S mode all the time but sometimes when I am in the mood for some spirited driving.
You can, but no point in doing this. You can still gear down with your paddle shift on D mode (e.g. want to pass that bloody turtle in front of you :p)
This is true, but if you want to transmission to stay in 3rd gear (for example) as you go through a hairpin turn, putting it in "S" is the only way to be sure you won't have an up shift mid-corner which could upset the F/R balance.
joflewbyu2
10-08-2015 11:16 AM
