Headlight Armor install
Old 09-23-2011, 04:22 PM
airlaird's Avatar
Yes...there is a "manage attachments" now for pics!..hooray! Anyway, I have just recieved my Fog light protection kit from Headlight armor. The kit was $25.00 bucks...and there is not much to it. It is ...what it is vinyl.
OK...gotta go pick up my son...I'll advise more details when I get back...
aairlaird
Attached Thumbnails Headlight Armor install-dsc05662.jpg   Headlight Armor install-dsc05660.jpg   Headlight Armor install-dsc05661.jpg
Old 09-23-2011, 04:28 PM
ScoobyZINE
AMUA6's Avatar
$25 for vinyl? SMH
Old 09-23-2011, 04:50 PM
airlaird's Avatar
Yeah...no kiddin'. anyway, I 'm back to finish my write up. So, the vinyl has an adhesive on it....which is rather sticky. The instructions say to "spray warm water on the adhesive side"..WTF....I'm thinking WHY do I need to spray it...it should just be "peel and stick on". Anyway, I sprayed it and sure enough..it has a milky look to it after attaching it to the fog light.
So, that pissed me off and I applied the other lens WITHOUT spraying it. It went on flawlessly and stuck. So my gripes are :
1. You do NOT need to spray it.
2. The vinyl lens does NOT fit well...they are 1/4 inch too small.
Obviously, this is a universal kit. But I have no doubt it will save my new foglights...assuming the rock does not hit the unprotected areas.
airlaird
Old 09-23-2011, 05:05 PM
ScoobyZINE
AMUA6's Avatar
When the lights warm up, the "foggy" look will go away. Hopefully you used soapy water? Pull the other off and reapply it. Or, take a hair dryer to the wet one and work all the foggyness out of it . After picture?
Old 09-23-2011, 05:08 PM
jeroplex's Avatar
i believe when spraying it with soapy water is that it allows you to apply it better and being easier to make adjustments letting it slide . the foggy look should eventually go away when the water evaporates.
Old 09-23-2011, 05:29 PM
airlaird's Avatar
Well...Again, I am happy with it and not trying to be too critical. If it protects my $220.00 fogs...I'm good with that..
airlaird
Old 09-23-2011, 05:32 PM
SEEYOU2CREW
TSXKid2010's Avatar
Yeah bro....read any DIY and pros tell you to and when they do it themselves use a water-soap solvent to do it. Maybe our resident vinyl business owner can shed some light on that for you. Mr dude with the gold grille, where are you?.
I got mine from Lamin-X after both mine broke to prevent anything else from happening. cossted me like $15 bucks, custom made for the car.
Old 09-23-2011, 06:52 PM
Speed2000's Avatar
Use isopropal alcohol, 25% and 75% water. The haze will bake out.
If something hits the fogs hard enough, they will still break. Ten years ago I was using quarter inch vinyl and still saw breakage. I didn't even bother to cover mine, but I did cover the headlights. Not to protect from breakage, but from pitting, sandbasting or becoming cloudy.
ps. It's only gold at night to oncoming headlights, otherwise it looks black.
Old 09-25-2011, 08:09 PM
You see me, I CU2
Mr. NC's Avatar
Whoa $25 for fogs only? Well I shouldn't really say LaminX headlights + fogs is $50 and tails alone is $50. Haze goes away and soapy water is key for placement
Old 10-09-2011, 09:20 PM
jeroplex's Avatar
Would these melt or discolor from the fogs getting hot ? Thinking about putting laminx clear color on my fogs
TLrascal
08-03-2018 11:00 PM
HairyMonkey019
04-22-2016 10:50 PM
BoricuaTL
04-08-2016 01:08 PM
eastcoastguy
09-24-2015 02:07 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Headlight Armor install
