DIY Oil Change
#121
7# werC 2uoYeeS
I apologize for reviving an old thread, but I just brought in my vehicle into the dealership for an oil change. 2013 TSX Tech Package Automatic with 4k miles. The service manager there said that the indicator states 40%, therefore there is no need to change the oil.
So, I am used to having the interval of 3-4k miles per oil change on my 2002 accord.
The service manager tells me:
"That is the old way way of oil changes, now the intervals are no longer needed, but rather just change when the indicator shows up that a oil service is due. Also, if I do want to do an oil change right now before the indicator shows up, all the A1 codes will also be cleared, so they will not show up anymore."
Is what the service manager described accurate??
I am skeptical, but I am definitely not knowledgeable.
I appreciate anyone that can provide some insight.
Thanks in advanced.
Thanks in advanced.
#122
Yeah, your mileage may vary obviously. I am getting 10k out of my oil change interval by following the maintenance minder. Just passed 30k, and did my 3rd oil change. The last change I did was 10k miles after the previous change and the minder still said 15% on it, so I may have been able to push it to 11k.
I am OCD now about checking my oil level every thousand miles, however. With that long of an interval, some loss of oil is expected I guess.
#123
Thanks everyone for the reply! Definitely puts my mind to ease, but I will need to get used to having 5-7k or more before an oil change.
As for the other codes, that will signal a service, not being there anymore if I choose to get an oil change early.. is that true?
#125
VTEC just kicked in, yo!
#126
ROTAREDOM
I just changed my oil
ulrblitzer (08-06-2015)
#128
Received 7,772 Likes
Umm. Do you mean the "ACURA TSX ENGINE COVER ASSY. (LOWER)" with Part Number "74110-TL2-A00" that was quite literally mentioned 2 and 3 posts before yours?
This one: https://www.acuraoemparts.com/delray...R_ASSY._(LOWER)
#130
ROTAREDOM
I just checked my dip stick. I dont burn oil
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
