correct ..you don't need to remove the bumper at all, you don't even need to remove all to bolts the instructions say to ...they did send some wrong size hardware which we had so it wasn't a problem , but if we didn't i wouldn't have benn able to instal
the screws that fasten the lip...just the ones on the very side next to the tire / under the two front spoilers form the add on body kit..they were to short to use the provided spacers, you would need a little longer ......and ....im not sure what its called spring nut?....the square nut that you slip onto the plastic...they were to small also
