torx screw (t-20) that hold HID cover
Old 06-04-2002, 08:53 PM
randomwalk101's Avatar
Angry torx screw (t-20) that hold HID cover
Can't really remove the screw with a Torx T-20 driver. The screw has the shape of the T-20 but in the middle, there is a notch sticking up that the T-20 driver doesn't have (flat) so it won't fit in..This is on the 2002 TL so I'm not sure if older TL's screw are different or what...anyways, bought a set of Torx driver..totally useless.. I used a small nose plier to turn the screw bit by bit until it comes off..i'm going to use a regular screw to put the damn thing back together...let's face it, that little torx screw ain't going to prevent thieves from jacking the HID lights if they wanted to..they just simply break it off with the screw driver..why bother something useless like that and making life harder for owners .....Acura???
Anyone has this problem?
Old 06-04-2002, 09:07 PM
TUFF GONG's Avatar
Here, take a look at this thread. Found it using the search function
http://www.acura-tl.com/forum/showth...highlight=torx
Old 06-04-2002, 09:14 PM
Moderator Alumnus
ArN 2000 TL's Avatar
I used a standard Torx tool and just filed down the pin with my dremel. I did this just a tiny bit just so I could fit the top of the torx tool into it, then apply a lot of pressure and begin turning. Be careful and try not to strip it otherwise your out of luck
Old 06-04-2002, 09:33 PM
WiLz's Avatar
you can get torx drivers with a hole in the middle
Old 06-05-2002, 03:25 AM
NsX Pilot's Avatar
thats a tamper proof screw and is very common in the security business ... you can get the tip from a number of sources for a few bucks ,,,,,but as you can see there are a number of harder ways to get it off if u wanted to. But if ur looking to buy the tip try www.jensentools.com ... or ... heres a place where u can just buy the tip for 4 bucks ...http://store.yahoo.com/toolsplus/mgn38342.html
Old 06-05-2002, 12:32 PM
Thx man..I got the damn thing off with a good old pair of plier. I'm going to use a regular screw (same thread size) to reinstall it. That "security" screw is not going to do any good in preventing thief anyways.
Old 06-05-2002, 01:03 PM
liutang's Avatar
I just picked up a regular torx t-20 bit and tried it on the screws... My right headlight screw turned easily. The left required some muscle but still turned. randomwalk is right. There's not much that screw can do.
Old 06-05-2002, 04:44 PM
BlingBling INSPIRE 32V
songoku's Avatar
Why don't you just use small flat head driver?? I removed the screw easily.
Old 06-05-2002, 04:51 PM
Mr Hyde's Avatar
That screw isnt really to prevent theft, but more as a safety measure, theres a ton of voltage going through there. Just use a small flathead, thats what I did.
Old 06-05-2002, 08:35 PM
NsX Pilot's Avatar
i never said theft proof because as everyone knows they take the whole headlight assembly not just the hid kit.
Old 11-12-2017, 10:01 AM
Ron Mcdonald's Avatar
T-20 Torx Security Bit set, sold at ADI Or any security system dealers. Where they sale CCTV systems, Intrusion Systems, and Access Control Systems. It is a Common installation tool in the security industry. Definitely is a pain in the *** to get out. Good Luck!!
1.
Old 11-12-2017, 06:15 PM
Unregistered Member
Karanx7's Avatar
Oh my god! Thank goodness you came along Ron Mcdonald. He's been waiting 15 years for an answer, and now he finally knows where to buy a T-20 security bit. It must have been rough for him to drive without his headlights for all these years.
Also, welcome to AZine.
Old 11-13-2017, 09:41 AM
Iggy's Avatar
LOL
Harbor freight is your friend in this case
SUPRMN84
10-07-2015 09:46 PM
lland
10-04-2015 04:47 PM
pistacio
09-26-2015 09:45 AM
HOWELLiNC
09-18-2015 11:12 PM
Quick Reply: torx screw (t-20) that hold HID cover
