Lower Ball Joints
Lower Ball Joints
Hey guys, I need to replace both my front lower ball joints. Got a few Q's:
1) I read from the 3G side, the sleeve in the LCA can come out when removing the LBJ from the LCA. If this happens, you must replace the entire LCA =[. Is this issue present on the 2G TL too?
2) I also read from the 3G side, the nut is too small to cover the sleeve inside the LCA completely. This causes the sleeve to just pop out of the LCA. Again, is this an issue for the 2G part?
3) What is the part number for the ball joint that you recommend?
For starters, you have a 2g. quit reading the 3g stuff
Im not sure what they are talking about, but there is no sleeve on the 2g.
That's awesome, less worries for me.
I know you had to replace your LBJ once, but said that they only sold it with the knuckle. After that, I think they released a kit for just the LBJ. I couldn't find it on any website diagrams, do you know where I could find it? Or should I just get Moog ones?
Chapter Leader (Southeast Region)
Are the moog better or longer lasting than the OEM ones?
I am thinking of doing mine as well.
The attached file shows a Service Bulletin from June 06 that is in regards to Lower Ball Joints. However, it is old and I don't know if it is relevent these days with all the aftermarket LBJ's available for 2G TL/CL's.
The following 2 users liked this post by zeta:
BLADE RUNNER (02-06-2015),
ProfessorFunk (07-30-2019)
Moog and call it a day
lower BJ
Yeah, the Moog's are top quality and have grease fittings to boot. I'd replaced both sides @ 105k and now have 160k, three years later with no problems !
victus1 (07-14-2012)
Stephen00TL (07-17-2012)
8th Gear
How about getting an oem balljoint from 97 accord??...$20 part# 51220-S84-A02.
Moog K9643
ACURA
CL 2003-1997
TL 2003-1999
HONDA
ACCORD 2002-1990
ODYSSEY 1998-1995
ISUZU OASIS 1999-1996
Moog K9643
ACURA
CL 2003-1997
TL 2003-1999
HONDA
ACCORD 2002-1990
ODYSSEY 1998-1995
3.2TLc (07-05-2013)
Anybody else with our 2nd Gens experience this problem with the Moog replacement BJ ???
The reason that I ask...is that Moog BJ's were used on my 2000 TL and I don't recall any problems with installation or "popping" out. It's been 2 years and 15k since replacing originals...!
3.2TLc (07-05-2013)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
