Headliner Removal Guide?
Hello all. I'll trying to attack the suroof lid rattle (not sqeak) issue. I want to remove the headliner but I don't want to screw it up. Can someone tell me what components need to be removed to do this properly?
Thanks!
P.S. I did a search and can't find anything under "headliner removal"
Thanks!
MechEng
1. remove the rubber weather stripping/seal from the inside of the door frame, not all of it, just off the top of the frame
2. remove A-pillar molding
3. remove seat belt from B-pillar, if you pop off the plastic piece with the button on it, you will see the bolt
4. remove the B-pillar molding
5. remove the C-pillar molding
6. remove grab handles
7. remove visors, remove plastic visor holder things, just turn them and pull
8. remove sunglasses holder/map lights assembly
9. remove dome light assembly
10. there is a plastic circle on the headliner near the back seat with a slot in it. turn the slot so that it is perpendicular from its original position
11. remove the felt/rubber molding around the sunroof
you should then be able to start pulling the headliner down. it is held on near the back window by a series of clips. you will need to fold the headliner slightly in order to get it out of the car.
MechEng
get a VERY small flat head screwdriver and pry where you see little indentations in the the clear plastic. you should able to pop it out. after you get off the clear plastic lens, there are just screws for the map lights and 2 nuts for the dome light.
Okay headliner is out. I'm think about using some left over laminate floor insulation. It's like a thin foam. Should I just try to find some sort of thin cotton sheet like mentioned in the post above? Is there a certain area on the headliner that should be covered? Thanks
MechEng
^ loll yeah i have so many rattles in my car i dont even notice them any more. passengers do though. they ask me why my car is making so many noises, and i tell them they're hearing things
mlody
12-04-2019 02:11 PM
dainmezron
10-16-2015 06:56 PM
