DIY: EVAP Canister & Shut Valve Replacement
Hi All :
Here's some help to those who see that dreaded amber light comes on and a new EVAP canister is needed.
I just replaced my EVAP Canister & Shut Valve and it would have been great to have some guidance to reduce the time it took to do this job. I replaced these parts to resolve a code P1457 (Major EVAP Leak) diagnosed at the dealership.
1) Order the correct parts. The Canister is simple (PN 17011-S84-A00). However, you need to order the Canister Shut valve (PN 17310-S0X-A02) black in color with an electrical connector and not to be confused with 17550-S84-A01 VALVE, VENT SHUT (O.R.V.R.) which is white plastic and not the correct part. Order the 2 screws (PN 93893-05010-08 SCREW-WASHER (5X10)) that holds the shut valve on the canister as the old ones will be rusted and useless. I could not remove mine even with vice grips.
2) When the parts arrive, take a look and the canister and you will notice 4 plastic tube fittings at one end of the canister, thankfully all different sizes. Notice the one mounting bracket hole above all the tube fittings and the 4" slot in the other end. This is how the canister is mounted to the underside of the car.
3) The shut valve fits into the large hole and is the only one, so no confusion. Use the O ring (taped to the side of the canister) to form and seal between the canister and the shut valve and use the ordered screws to secure the two parts together.
4) Jack up the diver side rear and remove the rear wheel. The canister is located on the underside of the card directly below the driver side passenger seat along with all the other EVAP components. The fittings end of the canister is closest to the side of the car (thank you Acura). Carefully pull off all the tubing making sure to not to create another leak by causing a hole the rubber tube. The largest tube (tank vent) you will need to squeeze the fitting to remove. Remove the one electrical connector.
5) Locate the mount bolt directly above all the tube fittings. Put some anti-rust spray on the bolt heat (it will be rusted) and using a socket with extension remove the bolt. Once out, pull the canister toward the divers side and it should come free from the slot bracket at the other end of the canister. The canister should come free and fall into your hands.
6) Locate the new canister into the cavity and slide the end into the slot. Push the canister up to line up the bolt hole and screw in the old bolt. This may take a few attempts as you pretty much have to do this blind. Connect the one electrical connector and the four tubes to the correct sized fitting. This tubes are formed to go to a particular fitting so there should be no confusion.
7) Wheel back on, jack down and beer in hand cause you're done.
I know to some this might be simple but it's in a spot not many of us has ever seen and is somewhat unknown territory.
Hope this helps everyone.
smartypants
smartypants
The following 13 users liked this post by smartypants:
3.2TLc (09-17-2012),
BigSky (08-30-2011),
cah14522 (07-31-2013),
DivideByGyro (01-18-2014),
dremills134 (11-12-2014),
and 8 others liked this post.
Thanks for the writeup- very helpful!
we still need fsttmys or other expert to verify that usa cars are the same
One thing to watch out for- to protect the cannister- is stopping the gas tank filling at the first auto shutoff click
Adding gas beyond that takes up the safety margin for gas volume/heat expansion in the tank
When gas gets up to the filler neck it CAN push raw fuel thru a vent tube meant to return vapors and send gasoline into the charcoal evap cannister
Thats supposed to deal with vapors not gas and saturates the medium
After that- its new parts time
Hopefully these are not a normal wearout all of us can expect..like certain ~other parts~ we dont talk about
Hi All :
The only symptom I saw was the amber Recuring Revenue Indicator came on. As for clicking....I can't imagine sticking my head underneath the car and expect to hear a clicking noise ??
smartypants
smartypants
Yes, my Recurring Revenue Indicator (CEL) is still on as I have not gotten round to disconnecting the battery to reset it. It will eventually reset itself if the error is not generated for a set amount of time. I'm not sure which option I'll take because its really immaterial...it's either fixed or it's not.
Sbuswell's is a very good question with regard to troubleshooting the EVAP system. The purpose of the EVAP system is to prevent gas fumes to vent directly into the atmosphere as the fuel tank loses or gains volume. To accomplish this simple goal, Honda (and I suppose other manufacturers) have devised a very complex series of valves, switches and rubber tubing. When it fails, it does not affect performance or present any symptoms other than the CEL coming on by tripped sensors located within the system itself.
Trouble shooting this system is problematic for the DIY'ers because you need to have specialized equipment to apply low pressure to various portions of the system and observe the maintaining of pressure (leaks) or the function of a specific valve. In short, the average person cannot diagnose this system without this equipment and the shop manual which describes the testing procedures.
So, unless you're an Acura Tech, this site will be invaluable to know what EVAP part replacement corrects what codes.
I'll let everyone know it this repair corrects my particular problem.
smartypants.
smartypants.
ErickUa5 (09-04-2014)
Hi All :
Copied from another thread......
So I need to confess I haven't been a very good Acuraziner. I replaced the two parts and reset the CEL light (I call it the Recurring Revenue Indicator) by disconnecting the battery. I started the car and the light stayed off (good sign..). I then drove for about 10 miles, ran over some train tracks and.......both the TCS and CEL came on.
Unfortunately I don't have an ODB scanner to know if the codes are new or if they are the same ones from before (P1457) and the stealership wants $120 to hook up their $100 ODB scanner to know for sure. The fact that it took a bump and the TCS light coming on does confuse the situation.
Now you might ask where did I get the idea to change out the canister and shut valve in the fist place ? A couple of years ago (yes, my CEL has been on for that long !!) I took it in to the slealership, paid the $120 and got a report back indicating these two parts where at fault. Searching here also confirmed that the canister and the shut valve were probably the cause.
So the make a short story long, I cannot confirm that I have resolved my problem. I just want to make sure all the facts are known to all before any others take action based on my experience.
smartypants
smartypants
I need 2 more gears
I changed my evap canister and vent shut valve over a week ago and cleared the code. I've driven about 400 miles since and the light has not come back on. I'm pretty sure the problem is solved. Smartypants, go to walmart and buy an Actron Plus OBDII scanner, they are $89.00 and are extremely easy to use.
Hey c0v3rr1d3 :
No I didn't change that filter. I doubt that this would correct the issue as the code is a "major EVAP leak" and not a blocked or low fuel flow error.
I think this is a very bad design although most car did come with this "plumbers nightmare" and may still have this system. I talked to the dealer and they said it might be "the two-way valves", whatever or wherever they are. I get the impression that they just change out parts until the error goes away.
Let me know how you make out and I'll do the same.
smartypants.
smartypants.
I need 2 more gears
$110.00 shipped I think, go to www.acuraautomotiveparts.org for the best prices.
4th Gear
Thanks for the great write up smartypants I will try this. Just finished fixing my EGR problem after buying a used 99 Acura 3.2TL. Now this. Also heard they may have a weak transmission. Oh well.
4th Gear
I think the gas cap tightening/replacing is the solution for DTC code #1456. Here is a cut and paste out of the tech manual for both codes.
P1456 EVAP System Leak Detected (Fuel Tank System)
P1457 EVAP Control System Leak Detected (Control Canister System)
Awesome write-up
smartypants - Thanks for the awesome write-up and parts resource. This is the third problem your posts have helped fix (Random shutdowns - bad ignition switch, lots of misfires - bad ignition coil). I'm hoping this does the trick for my P1457 code as well. Sounds like it's a pretty common failure.
Did you have to replace the 2-way valve as well? From reading a few posts where people had the dealer diagnose the problem sounds like the dealer generally also diagnosed the 2-way as being bad along with the CVS valve.
Theoretically you're losing molecules of gasoline to the atmosphere which could help push you down the road if they hadn't escaped. Realistically, you'd never know the difference. Probably a greater risk of skin cancer from exposure to the cel. Oh wait! The cel will make the alternator work harder. Never mind.
Hi
I'm planning on ordering the parts tomorrow. I searched online for prices and saw that hondaautomotiveparts.com is cheaper than acuraautomotiveparts.org and the canister, shut valve and washers have the same part numbers at both honda and acura sites (not surprising since the TL shares many parts with the Accord).
The difference is about 10 bucks combined. Do you think I'll have any problems going with the Honda parts?
Thank U just did this DiY with my dad ill post if it worked later. PS. to all people dont forget to order 2 of the screws needed PN 93893-05010-08 SCREW-WASHER (5X10)) htere only one you have to update the quantity . I ordered only one, i thought there were 2 in the bag but no just 1. Didnt read the whole thing. Thanks smartypants
I just replaced mine and my CEL doesn't come on anymore. After two years the problem is finally fixed . Thanks for the writeup.
FYI I ordered my parts from the Honda site I mentioned above. They have the same PNs and cost 10 bucks less.
Cheers
Cheers
I had the P1457 code on my 99 TL as well. I recommend replacing the shutoff valve first before the EVAP canister because, in my case, just replacing the valve cleared the code permanently. It was not necessary for me to replace the EVAP canister which saved me $120. This same strategy may save you money as well. If the code remains after replacing the valve, then you replace the canister anyways. Make sure you can return unused parts for a refund.
I ordered both parts to include the screws and it was 110.. I just replaced the parts tonight and took some pics. Will post later.
Took about 45 minutes.
P
The following 7 users liked this post by 05TSXPAT:
3.2TLc (02-23-2013),
JIGS (05-23-2015),
ReCKeD (03-23-2016),
TheMightyQuinn (04-13-2012),
and 2 others liked this post.
awesome. thx 05TSXPAT. hopefully those pics stay up for a while. most who upload them to photobucket don't keep their account active for years after, and they get rm'd
