Basic Suspension Question
The left front shock recently blew on my 130K 2000 TL. I had both sides replaced with KYB GR-2. Would it not make sense to also replace the rears in order to restore the ride quality? Thanks.
The KYB's are a bit softer in the front than the original shocks in compression damping so the car has less understeer and a more neutral balance. The rears are about the same as stock.
I found the best ride/handling out of Tokico Blues.
Either way at this point you should replace all 4.
EvanstonTL (02-02-2012)
has enough miles to merit them --
test by bouncing the corner of the car
compare front and rear --bounce 3 times and release,,how long to stop?
