Basic Suspension Question
Old Feb 1, 2012 | 09:37 AM
EvanstonTL's Avatar
4th Gear
The left front shock recently blew on my 130K 2000 TL. I had both sides replaced with KYB GR-2. Would it not make sense to also replace the rears in order to restore the ride quality? Thanks.
Old Feb 1, 2012 | 09:41 AM
is it not riding the same?
if so, yes. replace the rear two as well.
Old Feb 1, 2012 | 11:04 AM
jjashaa's Avatar
Avant Garde Wheels
you might as well.. 130k
you're gonna have to replace the rears sooner or later.
Old Feb 1, 2012 | 12:46 PM
RC99TL's Avatar
The KYB's are a bit softer in the front than the original shocks in compression damping so the car has less understeer and a more neutral balance. The rears are about the same as stock.
I found the best ride/handling out of Tokico Blues.
Either way at this point you should replace all 4.
Old Feb 1, 2012 | 05:47 PM
01tl4tl's Avatar
has enough miles to merit them --
test by bouncing the corner of the car
compare front and rear --bounce 3 times and release,,how long to stop?
Old Feb 2, 2012 | 02:19 AM
EvanstonTL's Avatar
4th Gear
Thank you all. Will replace the rears. Do the springs require compressing to install?
Old Feb 2, 2012 | 11:40 AM
Excelerate's Avatar
Former Sponsor
If they are factory springs then yes.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Heyzuez20
Oct 14, 2015 07:18 AM
datadr
Sep 12, 2015 09:12 PM
Nicho863
Sep 3, 2015 09:16 PM
