Advice about Timing belts
LocoTL00
Hey guys
I was getting my servicing done at the dealership and I was reccomended to get the timing belt replaced and gave me a quote for $750 along with their usual and yea also to get the motor mounts changed, that they quoted $450
I have 76K right now, and I have 2000TL, what do you guys think about all this? Are there any symptoms to know when its time to replace all this, cause honestly I dont feel anything different yet.
I just dont wanna get robbed by them LOL...
Thanks for your help
It's too early to change the timing belt. Most people change their belts in the 90-100K mile mark.
There's no way to "feel" if your belt is going. However, you can inspect your belt and look for any wear marks or gashes.
Not Asian
Per the manual, you need to change the timing at 105k. Some say get it done sooner because if it does go, your engine goes with it. As for the motor mounts, don't fix them unless they are broke.
LocoTL00
how do I inspect the timing belt? Plus I am also under extended warranty till like 100K.
t belt
Yon can not "inspect"the timing belt..you are 50% through the job just to see the belt..105k is correct on your model...your extended warranty will not cover the timing belt...as for the motor mounts,that sound a little high..
BTW it's every 105k or every 6 years..
LocoTL00
BTW it's every 105k or 6 years..
COOL.. thanks guys... you all helped me a lot.
175,000 on my original timing belt! its way to early to change yours
warranty
The timing belts are not covered by warranty...Motor mounts....depends on the type of warranty coverage you have..
175,000 on the original t belt.....yikes...that's nothing to be proud of..
t belt
Originally Posted by MikePA
Remove the front upper cover (5 bolts) to inspect the belt.
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
